Adoom
Posts posted by Adoom
  1. As far as I can tell. It's not canbus lighting. And it doesn't sense the current to see if a bulb is blown. I think it was just put there by the towbar installer because he assumed. He also didn't know subaru provided a plug in the loom where the factory optional trailer light loom goes so he just hacked into the wiring behind the light.
    I has deleted it.
    Discovered brake light bulbs are both gone. Only the high stop light was working. No warning lights anywhere. Wonder how long she's been driving around like that....
    • Haha 2
  2. The trailer plug isn't working on 2012 Subaru forester. The terminals were rusty, so I replaced the plug. But still no power. This thing is inline in the cable. I'm testing for power on the tail light circuit. Power is not getting through this thing. It wasn't sealed and had some oxidation I cleaned off. 20241003_102756.thumb.jpg.ffd38bdee4911df9c8f4e3ceb1fd8b76.jpgWtf is it? Can I delete it? Car doesn't have LED bulbs if that's what it's for.
  3. 12 hours ago, yoeddynz said:
    There's some aussie made alternatives to por 15 that I have found to be better and a bit cheaper.
    Bilt hamber stuff is great. Wins a lot of comparison tests etc. Unfortunately no one is importing it into NZ.  When I moved back home from the UK we brought over a whole box of cans of bilt hamber cavity wax. (dyna S50?) Best stuff I have used yet.
    I'd just use Epotec 408. But it's a bit of a pain to mix up a tiny batch for small things like this.
    Any brand names of the aussie stuff?
    I used some eastwood platinum and thought it was pretty good. But AFAIK it's no longer available in NZ.
  4. 3 hours ago, Nominal said:
    We got some of these (probably a bigger size)
    100Pcs Fruit Protection Nylon Mesh Net Bags with Drawstring-M | The Warehouse
    Worked pretty well in keeping the birds off long enough to get some grapes to eat.
    I got some last year. From an OS recommendation, possibly from you.
    Should have got a larger size. Found the drawstrings didn't like to stay tied and some fell off.
  5. 33 minutes ago, Muncie said:
    What's the go with narrowing track on an independent rear car? If you've seen my commodore thread I've been mucking around with BMW wheels to get the width I want under the ass. How much hard work would it be to cert rear arms if I were to cut back the mounting flange have a new one laser cut and basically remove 30mm track per side to get the tyres tucking back under?
    Yes I know it sounds like a lot of work but for me any chance to break out the welder and "meditate" is a good thing 100% reversible unlike pumping the guards etc
    You'd need to go through design approval because changing the lengths of the arms can mess with the geometry. You will need to accurately draw, with measurements, the modified suspension. There is a specific form for custom/modified IRS. It's in the documents section of the LVVTA website.
    On my Triumph(they are quite narrow), I narrowed a nissan IRS, so the arms and geometry were original, the inner pickups were just closer together. No design approval required. Your cert man just needs to be happy it's constructed "in a workman like manner". It was still a lot of work/measuring/thinking to get the subframe aligned and make new body mounts. And make new diff mounts.
    In both cases you will need custom length drive shafts made.
    It'd be WAAAY less fuck around to just use different offset wheels. Possibly cost less than the custom driveshafts alone.
    EDIT: Not sure if you mean, "make new arms", or "move existing arms inboard". I had assumed the first one.
  6. 1 hour ago, GARDRB said:
    Just a thought this afternoon as we were discussing narrowed IRS setups. Does moving the suspension pickup points inward do anything to the suspension geometry?? I can't see why it would, but I'm also second-guessing myself. Part of me says that the inner suspension pickups being closer together would change the roll-center.
    I hadn't actually thought of that. Referring to one of Allan Staniforth's books, moving the inner pickup points closer together would lower the roll center slightly. That's good, I think.
    I don't think it would do much else, or at least anything I'd notice.
    9 hours ago, winstonwolf999 said:
    Wow I can’t believe I’ve stumbled on this resto!!!
    Not seen any decent pictures or info related to the Victoria early model.
    following with great interest and hats off to you for getting in there!
    any idea what the gross weight is?
    I should update this. Did I forget I made this thread? Hopefully I have more photos.
    It's not really a resto. More of a cleaning because it was just packed with grease and gunge.
    It's supposed to be about 1200kg. Do you also have one?
    The gearing for the knee seems REALLY tight, up or down. It's a two handed job just to turn the small hand wheel. It's like the gears are meshed too closely, but there's no adjustment. I'm planning on making a flip out handle so I have more leverage. The later and bigger ones have a long handle rather than a small wheel as far as I know.
  8. I don't know anything about the dimensions of a rotary, they hang quite low?.... The triumph steering rack is quite high. I had to lower mine by a lot to fit a 1UZFE and I still had to modify the sump.
    Moving the rack involved lots of measuring and jigs and trial and error to figure out where the outer tierods needed to be so I could machine custom steering arms to correct the bump steer.
    The whole moving the rack exercise was a huge PITA that took months, I wouldn't want to do it again.
    So, definitely work out if the engine wants to occupy the same space as the rack.
    • Thanks 1
