77magnum13hundy
Posts posted by 77magnum13hundy
  1. just gunna slowly take insides out, then wip the slant out, then il see whats good... i did find that the rotors arent any thicker than my ones in there so but i heard today that a mod to some renault 21 rotors and some head scratching will possibly do the trick... il keep you in mind alex. oh this one has sway bar too so pretty chuffed about that... go away rain....
  2. tidy up of the engine bay.
    10418848_10152071174825957_5507610440714
    sussed the radiator out, has fan attached which runs off the link via a relay, still need to get the OG temp sensor working for the dash cluster.
    also blow-off valve needed a vacuum link so ran one off the top of the throttle body seems to be much better. moved igniter and relays into one corner and the catch can moved to a suitable place. Few holes to weld up and the engine bay will be complete.Seats are attached properly now
    Starts and runs fine now now need to work towards getting the driveline and brakes sorted
    still heaps to do...
  3. kinda have to get some other wheels made to fit as whats on offer in the 13inch range isnt that great. 15 inch range however would be better for availability something like some 19555's should be good as i cant run stretch tyres with this setup in the legal sense. Will always have the 8 inch wide 13's though cos they are slick but not yet *cough cough... looking at 15x8 and we'd be legal.
  4. Coil pack replaced with a newer better mitsi coil pack and resistors for injectors wired in, and yes folks we have running motor. Found there was an earth wire from the engine to shell which was getting warm when i was cranking so need to find a suitably larger earth to the shell... Pretty quiet too when idle. Stoked as. Choice.
  5. Hey y'all
    running wasted spark but one of the coils seems dickered (crack down the side of it, has dropped on the ground and shit oops),
    can i set it up to run individual coils if the 1+4 and 2+3 get the same feeds/pulses or is there more to it then that?
    What would PIckeys have that i could pilfer for this? particular makes models suitable?
    Setup is g1 link with link ignitor running wasted spark on my 16v 4age,  (running 4agze CAS)
    Cheers
    rob
