Posts posted by DodgySam
Hello all.
Just thought i'd post up some pics of the mini that im attempting to do up for the wife.
Its fun cos I havent really done any kind of resto before so I'm learning as i go along.
This was how she looked when I got her.
Looks good but there is a fair bit of work under that Ford blue paint.
Front flare test fitted and the disc brakes from a 2000 mini fitted. No more drums for this old girl!
I dont know if its very original but i shaved the boot. So there will only be the numberplate/recess and a lock.
Also I just tacked up the new high stop brake light.
Looks ok considering it still has the weld burns and is just tacked in place so not finished off in this pic.
And the reason its there is cos it is the wifes car and shes a dodgy driver at the best of times and i figured this was better than just sticking one in the already tiny back window.
Also i mounted up a new aerial and welded up the old hole.
Got the front windscreen out and that also shows the crx seats all fitted and mounted.
The drivers seat has been rebolstered so fits like a race seat.
The brake light and aerial. The brakelight is moulded in so it doesnt look so huckery. Still needs some finishing sanding but you get the idea. And the aerial is all wired in and ready to be powered up.
I found quite a bit of rust around the fuel filler spout so i removed the tank and cut out the rust. I completely welded over the fuel filler hole, filled it and then redrilled the hole so it looks all fresh and new.
And lastly i moulded in the drivers side rear wheel arch. Looks a bit tidier than just riveting it to the panel.
I filled the indicator recess and moulded in the front wheel arch.
As you can see i had a wee bit of a gap between the arch and the bodywork...so i glassed it up.
This is the drivers side arch after it was glassed and filled and primed.
The parcel tray behind the rear seat is like swiss cheese so instead of trying to fix it I've just cut the whole thing out and am making up a whole new one from a sheet of steel.
Thats about as far as i can go on the body work till it gets sent off to the panelbeater on Monday to weld up the major rust holes for certification.
Once its back i will post up some more pics as i keep going with things.
Sam.
Name (first is sweet): Dodgy
Cars you own: Navara...(not oldschool), AE101 Corolla...(also not oldschool), 1980 Mini 1000...(most definately oldschool)
Mods to them (can be brief or detailed): So far shes just going thru a disc brake conversion. Also has a blaupunkt tape deck with 10 disc changer and jbl 6x9s
Link to pics (if you have some, and keep it a link to keep 56kers happy): Maevis the mini as she is now
How you found out about oldschool: I am a member of the same mountainbike club as Bloody 10speed.
Anything else you want to add: It is bought to be my wifes car as she needs a small car as shes only 4'11". Its going to be a slow build but i have an idea which direction its going in.
Dodgysam's wifes 1980 Mini thou.
in Projects and Build Ups
OK...this is just some of the rust that is about to be fixed.
Under the petrol tank...
Drivers side of the boot...
The missing parcel shelf...
One of the rust holes in the passenger side front wheel arch, its right next to the door hinges so this is why im not too happy to do it myself.
And this is the new stromberg carb thats gonna get fitted once it gets rejetted and given a good service.
