Borgweiser
Posts posted by Borgweiser
  1. According to my insanely old spark plug books, the next heat range up for the Champion D-16 is a D-21, should still be available. Champions website still list them.
  2. As KK has said, gravity bleeding first is the way to go, starting with the master cylinder. Also been a beetle check the condition of the hose to the reservoir. It is common for the older hoses to dissolve internally causing a fluid restriction. If all of that checks out and still no pressure to the front the pressure cup must be damaged or swollen. Been a 73 there should be two outlets on the MC to the front brakes which generally means you bleed the right front first.
  3. Daimler V8 is one of my favourite sounding engines, they rev just like a motorbike, very un V8ish for the era..
    I once unbolted the exhaust of a Mercedes E55 W210 model at the headers, and then drove it to our friendly exhaust shop to remove blocked catalytic converters.
    May have given it a bit much, some noise complaints were made. Sounded fantastic!
  4. You are thinking of earlier Magnettes, they go for more and are quite sought after.
    the 4/44 technically is a MG as it uses the early MG XPAG motor, whereas the Magnette had the Austin B series..
  5. Take your initial estimates of time and money and double it at least to avoid dissapointment.
    Not wanting to dishearten you, just give you a clear idea. I've been doing this professionally for a few years now.
    Believe me, if it was possible to turn a profit off restoring up cars for sale- I would close my doors to the public, the reality is very different.
    Find a car that you want, check out a few, talk to the clubs or the GC's on here and get into it.
    MG's are a good starting point as long as the body is relatively rust free, parts are cheap and readily available, also world's largest one make club means plenty of support.
  6. Rebuild it? Most likely it's running rich and the float has become a sink..
    Check diaphragm also for splits and needle valve for dirt or wear marks.
    Only adjust the needle with the correct tool which holds the piston in place or risk diaphragm splits
    Easy to make one out of a piece of steel fuel pipe and a allen key. Just google the original tool for specs
