Posts posted by Southerner
Yea the easiest way as Damien! said is Ex lancer top hats on starion struts. You can use starion control arms aswell as the knuckles for more length(worked out to give me negative camber in my car). If you shorten the struts you can use KYB inserts out of a celica to give you more travel. Then just put a threaded sleeve over the top. Check out my project thread on how i had mine setup.
I pretty much followed Seedy Al's guide on how to do the struts
http://www.oldschool.co.nz/phpbb/viewtopic.php?f=48&t=26443
Or just use the search function to find more info
Yea im starting to think that aswell, it is marked LSD on it though, ill take a photo tomorow, is there any other way i can tell without actually pulling it out?
Cheers for all that! Yea ive checked most of it for rust, the only place seems to be the lip on the back gaurds where some mud has caused it to go a wee bit rusty, other than that its pretty sound.
The diff its pretty shagged i think, could just need a tighten up? Do you know if they are hard to do?
I agree with the ugky M3 grills, it came like that and arnt easily removed so will be ther for awhile.
Im probally gona get some better suspension for it soon, already handles pretty good. The motor is pretty decent and takes the little bit of abuse ive thrown at it so far, needs a new clutch soon though.
I think im pretty right for parts at the moment, but will keep it in mind.
Well ive recently sold my ex lancer 4g63t project as i live away from home and cannot see it being completed anytime soon so thought i should buy a car that had some potential.
Was looking round at e30's for awhile and set myself really wanting a 2 door coupe version, 320i or a 325i, which had to be manual. Went a drove a 320 that was pretty rough so kept waiting for a nice tidy one to get.
Saw a nice 325i 2 door driving round dunedin and then really wanted my own, a week later the exact car showed was for sale.
So here it is, 1986 BMW E30 325i
Its a manual 325i, with a lsd in the back, tidy interior, lowered slightly, custom headers with a 2.5inch straight through exhaust which sounds awesome.
Now from doing some research on the vin plate i found out that it used to be an automatic but the conversion must of been done extremely well.
Also think it may be an msport as it has all the good bits like a lsd etc, and it has msport colours around the gearstick and handbrake boots, it also has AC Schnitzer side strips along the front doors, can anyone help me find out how to tell?
And how hard is it to tighten up the rear diff? Ive jacked it up and it only spins one wheel with the other wheel not turning at all. It is stamped LSD and sometimes gets 2 marks going if its in the wet or on gravel.
Let me know what you all think
yea my grandfather has quite a collection os them aswell, dont think he is collecting them hoping that one day they will be worth mega bucks. Think he just enjoys them for the good cars that they are.
yea the light flickers from 1/4 of a tank aswell, yea it does suffer quite bad round town, but on the open its pretty decent, cruises amazing on the open road aswell. Goes much better since i redid the timing. This car has been my favourite car ive owned and would recommend them to anyone.
Yea thats what i thought it could be ill try that, cheers for the help
Ive got my mk 2 triumph, with a 2.5 tc engine with 's' carbs and the overdrive gearbox. A whole tank is 63.6 litres to fill so over $120 in 95 octane fuel.
When driveing it you can get 280km out of the first half of the tank according to the gauge, but the second half goes down in 100km or 150km max.
I am wondering if this is normal for a triumph? I understand that its a 6cylinder carbied car, and its heavy! Ive had it tuned up and put a new air filter in but this hasnt helped much at all.
Any help would be greatly appriciated
Cheers
Been driving this thing round quite alot and im loving this car. Really good on the open road!
Got the other grill onto it
Also while digging around in the shed i found these beauty rings, around 100mm wide
As ive said my grandfather is nuts about triumphs which means we have heaps of spare parts
Diffs
O/D gearboxes are pretty common in his shed
Ow and here is my uncles mint Bonneville
And the part most of you triumph lovers will be waiting for( sorry the car is up on jackstands getting its gearbox swapped but ill get better ones soon)
2.5 engine transplant
His other triumph, left hand drive tr6 imported from the states a few years ago
The mint steelies it rolls with ballon spec tyres
Thoughts and ideas welcome http://www.oldschool.co.nz/phpbb/viewtopic.php?f=18&t=31296
Went up to dunedin in the Triumph in the weekend to check out my flat and pic up a engine. Triumph went really well and drives like a dream on the open road.
Under the cover was this
Came with a td-05 turbo, yellow top injectors, extra fuel rails, loom and ecu. Also has the 6 bolt crank which is a massive bonus
Hopefully getting a top mount manifold made up soon so i can sit the engine in the car.
Also the mount that stickes out the front, i tryed to remove it but it looks to be part of a cam belt tensioner under the cover. Can anyone give me a heads up?
yea i have the steel grill for it out in the shed, just havent put it on yet. and a s spec steering wheel aswell.
Grandad also informs me there is a 2.5block with .50thou pistons in it and there is a fully done head there for it aswell, so might get a cam done for it and slap it in.
And ill get photos of the mk1 real soon
I already know that there are already afew A class Trumpys on this forum but thought i might aswell post my one up here.
About 2 years ago my grandfather towed home a rusty Mk1 Triumph back to his house, and we all thought he was going mad from his old age. Early december last year he had finished redoing the whole car. Most nuts and bolts were replaced with new items, the diff from a mk2 was put in the rear, and a 2500 was put in the engine bay with a 4 speed overdrive gearbox. All done by himself. The outside was painted in a bluey green and the rims were painted a creamy colour. It looks mint to say the least!!! He also has a TR6 he imported from the USA a few years ago!! He is triuph mad. His next project is a PI he has in the shed. Ill take a couple of pics of these to cars soon.
Well until he started dailying his MK1 he was driving around in this
And when he towed home the Mk1 i said to him that when it was finished that i would purchase the Mk2 off him no matter how hard up i was at the time i would find the money. Well that time came early this week!
I am very stoked with it!
Even came with a rug in the back to protect the mint red interior
It has the 2500 carby engine, 4 speed manual with overdrive and air shocks in the back. Which when i picked it up he told me they were good because you can have 3 people in the back and not have the wheels poking out at funny angles! ie negative camber.
Plans are to lower it slightly and put in a decent stereo system, then cruise around in it.
Let me know what you guys think.
Yeah, probably a Jap import. My SE Lancer had AC (Except for the pump, someone took it)
See if its stamped "A17*A" on the firewall
Yea its got A174A on the firewall, no pump though, just heaps of hoses to gadgets and a aircon radiator.
Been working on my front suspension still. Got it all mocked up and bolted it into the car.
This is the suspension at full droop. So doesnt have much travel
All the parts laid out, just used shortened starion strut tubes, celica gt4 KYB inserts which bolt into standard lancer top hats, and Jamex 63mm id coilover springs rated at 7kg. Looking at adapting adjustable tophats soon though
And then through word of mouth in dunedin i came across another lancer, so added it to my collection. Its a 1980 and got airconditioning? Is this possible?
do you have any spare ex lancer springs to fit a 1600?
no sorry, i only had 1200 lancers
Hey, do you guys think this is sitting right? Too low for certification? cheers
Been on holiday from polytech so done heaps with the front end. Since im putting in the starion struts i had to lower the front about 80mm. If i left the standard shocks in i would have had 40mmish of travel in the shock....not a good thing. So took this idea.
I just cut off the lower spring hat and ground it back. Then cut and shortened the starion struts 57mm for the KYB celica inserts.
Tacked the struts back together to make sure that i had them right before fully welding tem and put them back in the car.
Sits like this
Getting some sleeves machined to slide over the strut tube to weld spring seats on.
yea the mounts on the wagon diff are quite differant to the EX. Ill take a pic tomorow and post it up. Im tossing up myself whether or not it is worth making a sigma diff fit or just save up for a hilux one.
Home from polytec for the holidays so thought id put the lowering springs in the back, i reckon its at a pretty good hieght, not "sacked" or "dumped" on the ground. But it is definately alot lower than it was, will go lower if there a couple of people in the back.
As you can see the front is pretty high, would make some suv's look low.
Im thinking that i will make coilover out of the front starion struts using shorter shockies and civic lowering springs or similar.
The engine is also in with the gearbox which is hitting the rear of the tunnel. I would really prefer not to cut this so if anyone has a l200 shifter extension plate etc give me a yell, cheers
yea ive got it all done.
i used a starion crossmember(pretty sure sigma the same).
the staion lower control arms
starion knuckles, cant use lancer ones as they are 2 bolt and starion are 3bolt
starion struts
Lancer main drag link and right/left steering arms
and a sigma idler arm
and it all works sweet
today was particulary good work. got everything i wanted out of the sigma and started working on getting my lancer to sit on the ground by fixing all the little things, like the steering.
After i put the starion crossmember and lower control arms into the little lancer the steering arms would catch on the back of the crossmember. I couldn't fix this problem no matter what steering arms i used, so in the end i gave up and it sat the while i started sanding etc. I made a thread on what i could do to fix in and came up that i needed a 1600 crossmember (hardish to find by itself).
Today however i got the idler arm off the sigma, bolted that up, and IT WORKED!!! i now have steering in the lancer .
So to clear up on how to put starion struts into a 1200 Mitsi lancer.
Use.
1.Starion or Sigma Crossmember. They are the same
2.Starion Lower Control Arms and knuckles. 2 bolt as lancer are 3 bolt
3.Starion struts with lancer top hats. These bolt straight on and up into your lancer
4.Lancer main drag link and right/left steering arms
5.Sigma idler arm!!!!
Note. This is how i done it, so it should work on 1200 lancers, i dont know about the other ones. I have only bolted it up aswell and it worked, i haven't got it certified, so dont come after me if it doesnt pass. I hav'nt cut or welded anything it is all bolt on.
Hope this helps people out, cause it was frustrating the hell out of me!!
After a few months of searching a hanging out for a bargain a sigma wagon came up for tender.
Which means i got one of these
As im up in dunedin polytec for most of the time i got stuck into it as soon as i got home.
Being a wagon means that it has a 10bolt diff hiding under there waiting for my lancer
Also came on cheviot oldschool mags haha
its moving only quite nicely now, hopefully il have the sigma stripped out tomorow and have the engine sitting in the lancer before the end of the weekend
haha yea the other one was molested abit, although this one has been hit hard by the rust bug.
im trying to keep it sort of classic orientated with carbs etc, there deffinately wont be 17" chromies on this lancer
these turned up in the mail at work the other dar, cheers to Southernchick
i also changed my mind on the turbo 4g63 sohc. Cant be bothered mucking round with turbos and wireing. would rather put the effort into something else, like these onto a n/a 4g63
also made one of these
Southerner Ex lancer
in Project Discussion
yea i shortened the strut itself and used the inserts. I presuming if all the welds are done nice and neat then it should pass cert, and therefore wofs
