JasonK
Posts posted by JasonK
Got it all driving again last weekend and cruised around a bit, was definitely the metering rods stuck down in the carb, also chucked a new set of leads on and seemed to be running real well.
finally remembered to take some pics of the whole car:
However I noticed a bit of an intermittent noise kinda like a bolt rattling in a tin can, so checked everything was tight etc but it sounded like it was coming from the gear box so I was thinking cracked flex plate, so pulled the gearbox out tonight and found this:
pro parts have one listed on trade me so I'll go in and get it tomorrow, Hopefully that"ll be the last of the issues before wagnats!
na pulled it out and still did the same without one
Took it out for a cruise, was going mint (had cut the cat converter out that afternoon) and was noticing a power increase, then went to come home and 80kph was as much as I could get out of it and didnt have the power to make it up the hill, but would rev up resonably well under no load, ended up walking up the hill and getting lee to pick me up. Have cleaned out the carb and I think the metering rods may have been stuck down but havent driven it yet so not sure thats fixed it
Shit good work. must be a week for broken down wagons haha
Finished off the bags a few weeks ago, was a bit slack taking pictures but heres what I did take
Front shocks relocated:
Tank and compressor mounted:
Shit yeah was sweet seeing side by side top fuelers, I heard the marsh guys saying that on the run that they red lighted on, their data said they ran a 4.9 so they're getting dam close
I'll take some pics next time i'm under there. Havent done the shocks as yet but will mount them to the side of the bottom arm and make a bracket tto go on the chassis and pick up the top bolt. will be part of this weekends mission
its not quite as low as I was hoping but where it is now it'll meet the scrub line rule
so after spending way too long trying to find drop spindles for this I decided to bag it, so right after hawkes boes I put it in the shed and pulled the springs out
then made up all the brackets to bolt the bags in with. Front:
and rear:
So now they're all in and plumbed up, pretty much just got to finish wiring the valves up, mount the compressor (a york air con pump), mount the gauges and some tidying up and it'll be time to think about getting a cert.
- 18
I've heard of the insurance companies just writing recovered stolen cars off for that reason so will be interesting to see what happens here
So this is all sorted for a vin now, hopefully get it in this week, also spent the day flatting and buffing it, then put on a couple of coats of wax, came up pretty good.
Also while we were in the states last month we picked up a set of braided leads for it, looks a lot nicer than the in your face red ones.
Shit yeah, awesome race was a bit weird watching on tv and not being there though
There's not really any need to put it on a fancy chassis machine, we only have an old machine at work and measure almost everything with just a tape measure or a manual tram bar.
Kk's method is probably the easiest, just take diagonals of everything you can and if they comes up within 2mm then everything should be fine.
I wouldn't worry about not having the engine etc in, in fact its probably easier to measure everything with it out.
What makes you think you something is out of square? Bad fitting panels etc?
I'm a panel beater and do windscreen rust repairs pretty regularly and have never heard of anyone using a disclaimer. As Sorensin said, do a good job and you won't need one
Shit thats crazy , I paid $100 for my resonably tidy 2 door wagon a few years ago with a blown gearbox. if it wasn't such a good daily driver it'd be worth selling if they're going for 3 grand
Double sided tape , whaaaaattt.
on a urethaned in screen you do use foam tape around the frit band (the black primer stuff around the edge) to stop the glass pushing all of the urethane out and sitting hard on the frame, i think that's more what rustisize was meaning
I'm quite keen to do it myself even though it would be a whole bunch easier to send it away, just yeah wasn't too sure if that one was going to be all good as i can't seem to find a way of ID-ing it online, also wasn't sure what mods you have to do, if any.
It doesn't seem to have the steel cover on my one. Do you reckon it'd be worth just giving it a clean and jamming it on? or is there something that needs to be done to it?
Ah, the trusty old holden column manuals.
I had a smellmont, and the 1-2 shift was poos. You had to shift up out of 1, before going away and up to 2. Otherwise it jammed like a cunt.
Be sure to take lots of pics of the body once you start delving into the bodywork.
haha i think this is a universal thing on Q's, I could shift mine pretty quickly without jamming it but ever time it went for a wof the guy would always stuff it up and be stuck in first right round the block
Will be crossing a couple of things off my list in august, Going to the states for Bonneville Speed week and hopefully catching a top fuel meeting as well as as much other stuff we can fit in
So Bought this about a month ago, the guy selling it said it was running but had no drive. So got it home chucked a new filter in the gear box and filled it with oil and now it drives. Rego's on hold, have just gotta do a little bit of rust work and get an idler arm for it and then will go for a wof, then of course slam. hopefully all in time for nats.
It's reasonably tidy and the only thing i've noticed that's missing is the bottom part of the dicky seat. might respray it at some stage but for now just keen to roll it as is
Discuss: //oldschool.co.nz/index.php?/topic/36715-jasonks-dead-sled/
hahaha that thing needs a shit tonne of work before it even gets close to going anywhere
YOU WHAT!?
What are you bringing to Nationals?
fingers crossed the beast parked next to it in the picture
JasonK's 79 Chev Caprice Hearse
in Projects and Build Ups
Have changed the flex plate for a brand new one, everythings bolted up tight but still makes the same noise! anyone got any idea's? must be time for a beer
