I guess it's time I actually posted something on this thread.
Yep, I am Gavin of Bateman Racecars.
So on pricing, the cost of raw materials went up significantly (20%) at the end of 2010, so prices have gone up a bit. The difference in cost mentioned by twosmoke is probably because he asked for pricing on 17's as these are more expensive to make than 13" thru 16" diameters owing to the yeild from a piece of material. ie: less parts per sheet = more $ per unit. (We only do 13"-17" diameters)
I'll check it out & see if I am allowed to post a full list of pricing on here.
Cutting off welded on outer shells & bolting on new ones is not a problem so long as there are enough bolts to safely hold it all together afterwards. Otherwise the application of some more holes is aways a good solution rather than welding. The bolts used on different brands of wheels vary in size. Old BBS racing wheels (eg Formula Atlantic) were 6mm, the BBS as shown at the start of the thread are 7mm (really odd so don't lose any) and some are 8mm. Generally you find that the bigger the wheel diameter the bigger the bolt diameter or the greater the number of bolts.
When sealing the wheels, we always also run a bead of sealant around the joins after it is all bolted up and tool it off to ensure there aren't any air bubbles in the seal. Just putting sealant between the parts does not guarantee a seal. Generally also put sealant around both sides of the bolt holes as I have seen some wheels leak around the bolts.
I've been thinking about making complete copies of SSR Longchamps. What sort of interest would there be in these?
Otherwise you can have a look at the start of my new website at 41degreewheels.com. and feel free to email pictures of cars that we have had a hand in making parts for that can be included in the gallery! gavin.bateman@clear.net.nz ph 027 2468948
Have fun
