ryanfels
Posts posted by ryanfels
  1. @ryanfels, Ok so can you implement using the s13 coilovers with height adjustable bottoms such as TEIN or BC and fit them onto the ke70 stub axel?
    Last time i looked, i dont think TEIN had height ajustable bottoms? Maybe other models TEINS do though.
    BCs work, especially the Red series as they have a 51mm ID on the threaded tube bit so they slide over the ke70 struts perfectly. The gold series S13 stuff went up to 55mm or something so a small sleeve is required
  2. Ive only heard bad things about the s13 gear, I know Brendon Dunker has pulled quite a few out and swapped back in the ae86/ke70 stuff. maybe try ask him personally about it
    You can weld most s13 coilovers onto the existing ke70 struts in the front and the back is just a matter of removing the springs from the shocks and changing the bottom bush
  3. Just curuios, i have a brand new mazda boundy LSD diff. Its a 4.1 ratio. What sort of revs would my car being doing at 100kmh in top gear assuming the engine was spinning at the same speed as the driveshaft ?
    G52 right? in 5th, they are almost the same as a w58. A 4.1 would be ok but a 3.9 will put you at about 3500rpm in 5th at 100kmh (thats what my grande did and it had 205/50/15s)
