plasticdash
Posts posted by plasticdash
go to this link
http://www.uniden.com.au/NEW_ZEALAND/cs ... anuals.asp
then scroll to the bottom. and click on the vs1600xr pdf.
Nice score. mate had one few years ago with a 4k conversion of all things. he got it in a swap for a rusty jag with a poke 305 chev half in it.
Mate had the same problem as you. tried everything, brand new master, bias valve and vacuum, blew out lines, bled many times using foot and also vacuum bleeder. turned out that one of the brake pistons was sticking. wouldnt move when bleeding, but would when under pressure. caused similar issue to what you have.
also take out your bleed nipples and make sure the holes in them are not clogged (ive had this one myself)
Was it doing a similar think prior to re-kit ?
Twin charging - (supercharger and turbo) pros and cons ?
in Tech Talk
I am wondering if driveability gains from twincharging are worthwhile . ie a 2L motor that will pull strong until 7500-8000 rpm whilst at the same time eliminating lag around the 2-4k rpm mark - ie something that is more linear in power delivery.
The most efficient way i have seen is using something like a toyota SC14 supercharger until around 4-5k rpm (then clutched off) and "larger sized" turbo only from there on.
I have seen a couple of ways for plumbing.
I believe the way below loses efficency by having supercharger after intercooler (less heat loss, as air is heated by compression from supercharger)
This way is better i believe -
Plumbing looks rather simple to do too. obviously have to run a bypass valve to open up air (from filter) into turbo when supercharger is shut off.
