efp0wa
Everything posted by efp0wa
  1. Not that it is, but if so? This engine (4g63 sohc carb) isn't running overly smooth; seems like it is misfiring (as though it has a lumpy cam), takes about 4 minutes before I can let the throttle go so it can idle by itself and then when it does it's at about 1100rpm and jumps around a wee bit. It's a bitch to start too, as discussed it has no choke but it shouldnt be this bad. Has good compression compression. I'm wary of the dizzy and coil, I may change the dizzy back to the previous one and see how it goes then.
  2. Well driven a tota of 1km around the yard and is driveable. Idle is bit of a joke. Don't know what is wrong, carb tuning is all out of whack. Spent 30mins getting it as good I could. But have to sit with foot on gas for a couple of mins when cold to prevent stalling.
  3. The carb must have been blocked and the spark was too weak therefore I changed to the other dizzy and coil. Smoked like a train for about 10 minutes but it cleared up.
  4. It's alive!!!! Apart from a leaking O-ring on the heater tube from the waterpump which ill rangi silicone up; ALL GOOD!!!!
  5. I've got it on 1-3-4-2. Thought that was right? I'm more so suspecting that dizzy isn't at correct position since I put the replcaement one in. Battery is on charge again at work anyway, will take it back to workshop this arvo and give her a shot.
  6. ALRIGHT. Gotten a bit further! Put carb back on inlet with all hoses required etc. Also changed to a different distributor & coil. Went to fire her up and BANG. Like a shotgun was so loud I almost shat myself as I wasn't expecting it!! Obviously all that unburnt fuel/engine start sitting in the manifold finally ignitied. Turned her over a bit more but was popping away like the ignition timing was wrong. Pulled dizzy out and turned it to next setting, but that wasn't right (wanted to start but seemed like it was firing at the wrong time). So going to try the other 2. Can't find my timing light which is a bitch! Anyway jsut went a got some woodys and now I'll try again Wish me luck.
  7. Just blew out the carb with air. Going to go bolt her back up. At first I thought the dizzy may be 180 out so I tired it the other way. But it was all good to begin with. Need this thing to start...feeling fucking stupid.
  8. Ok guys, Tried the engine start spray, still no good. So I removed the carb to give it a clean up. There IS fuel sitting in the inlet manifold under where the carb mounts onto the manifold; seems its not getting drawn into the motor... Now...Is it possible I could have the cam timing out by like 180degree? Or something along those lines. All the markings lined up when the cam belt was installed. I'm feeling stumped
  9. I may as well pull the carb off and give it bit of a clean i suppose. Yeh the autochoke was disabled as it was coozed and wouldnt work.
  10. 4g63 sohc. carb that is generally on the 2 litre models
  11. SO where do I start?
  12. Went to start engine...had to fuck around with getting spark again (like i've had dramas with in the past). It won't fucking start!!! Carby is getting fuel. But once I remove a couple of spark plugs they are dry. Like there is no fuel getting into the engine itself...FML. I thought maybe dizzy way 180 out so I turned it around. Still not go. Not that that would matter seeing as I'm getting spark. I'm feeling pretty bummed. Why would fuel not be getting to the motor...? PLEASEESE help
  13. Ok then... Went to start engine...had to fuck around with getting spark again (like i've had dramas with in the past). It won't fucking start!!! Carby is getting fuel. But once I remove a couple of spark plugs they are dry. Like there is no fuel getting into the engine itself...FML. I thought maybe dizzy way 180 out so I turned it around. Still not go. Not that that would matter seeing as I'm getting spark. I'm feeling pretty bummed. Why would fuel not be getting to the motor...? *stuck* As for pics...Imagine a stock l300 with tints and a bed. I will post pics anyway though.
  14. Sweet as Fuel. My bad. Pre 85 old school??
  15. Have a funny feeling this hose snapped during disassembly. Do 1 and 2 go together?
  16. Does anyone have this? Or can they draw one for me? I labelled most of the hoses before I removed them, but there is one that has got me stuck...
  17. I've owned this L300 for about 2 years now. During that time i've gone through 2 headgaskets on the old motor. Not too sure what the cause of the overheating was, but I'm suspecting it was the radiator. Needs a good back flush. Being fed up with repairing that motor I purchased a 4G63 out of a L200 from Chch; was told it was in running order, after driving all the way down to Christchurch to pick up the motor it appeared to be a crock of shit. The motor was missing the balance shaft belts, the water pump had snapped fan studs and there was no cam tensioner. Anyway after driving from Nelson to Chch I was not going to leave without the motor, so I offered the seller half the price he originally sold it to me for on Trademe and I drove back with a Peice of shit 4G63 for $55. The motor sat around in the yard here at work for half a year and then I finally got to work and started working on it. I purchased a engine stand and crane from Ripco for $399 during their fathers day special, was too cheap not to. After stripping down the engine I checked all the bearings with plastigauge, they were all within spec so I chucked them back in. Also checked a few other things like crank end float while I was at it. I put the block in the Turbowash at work while it was stripped down and it looked spanking new after the clean. I had to grab quite a few parts (tensioners, oil pickup and things like that) from the 4G63 that used to be in the L300 as I didn't like the looks of bits from the L200 engine. I installed the oil pickup, used the sump from the L300 engine as the L200 one varied in shape a wee bit. Installed the tensioners. Had the head from the L200 engine crack tested and checked for straightness and it was mint. Didn't do anything else to it but now I wish i had changed the valve stem seals. Fitted the head to the block and continued. Reused the water pump from the L300 engine as it was only about 2000km old and looked to be in great condition. Used the pulleys from the L300 engine seeing as the L200 didn't have powersteering. Turned out the L200 4G63 didn't have a required spacer on the crank pulley that is required for the powersteering; didn't find this out until I went to fit the powersteering pump and the pulleys were on the piss with belt allignement, anyway got that sorted and Got the belts all installed (balance shaft, cambelt, powersteer and alternator belts). Everything was all installed on the engine apart from the manifolds, I chose to leave these off as I could see it being a hassle with lowering the engine in and getting it mounted up. But I did decide to install the gearbox while the engine was out, as It appeared to be a bitch to get the gbox on while the motor was in the car. Used the flywheel, clutch and pressure plate from the L300 engine as it was in a lot better condition. I cleaned up the flywheel with emry paper and blasted it with brakecleen (also used this on the clutch). The clutch was in such good condition that the springs still had the blue paint on them. I made a clutch allinging tool as I didn't want to fork out for one at the time as funds were tight. The tool worked great. So had the clutch and gearbox installed in no time. Then it was time for the installation, had to stuff around a bit with chains on the crane to get it short enough to clear the roof of the van, sussed it out eventually. Removed passenger door, wheel and seat and got the bitch it. Was bloody awkward as the weight of the gearbox unbalanced things a fair bit. Had to remove the top mount from the gearbox to get clearance with the firewall and put a trolley jack under the gearbox to lift it up from the ground. Once she was in I had a cunt of a time alligning the engine mounts, but once again managed to get it sussed. So tightened up mounts accordingly, reinstalled driveshaft and fit gearbox mount back to box. Plumbed up the power steering lines and plugged in all wires that I could at the time. Refitted exhaust manifold. Things are looking pretty good. I've compiled a list of things remaining which can be viewed below. I hope to get all these things completed after work tonight!! And with fingers cross she will run. 1. Put battery on charge. [charging now] 2. Flush radiator [complete] 3. Bolt exhaust manifold to down pipe flange. [complete] 4. Tighten Driveshaft to Diff bolts. [complete] 5. Find suitable nut for bolt to mount starter motor & mount/wire up. [complete] 6. Secure shifter cable bracket. [complete] 7. Secure clutch cable bracket. [complete] 8. Tighten gearbox upper mount. [complete] 9. Repair reverse sensor switch. 10. Repair earth cable on top of gearbox. 11. Fit thermostat with gasket to inlet manifold [complete] 12. Fit inlet manifold with new gasket. [complete] 13. Fit all vacuum, fuel and coolant hoses to their appropriate locations. [complete] 14. Fit distributor. [complete] 15. Fit coil & ballast. [complete] 16. Wire up distributor, coil and ballast appropriately. [complete] 17. Fit new spark plugs. [complete] 18. Connect distributor cap and HT leads to spark plugs in appropriate order. [complete] 19. Fit oil filter. [complete] 20. Ensure sump drain bung is tightened. [complete] 21. Pour in new engine oil. [complete] 22. Pour in new gearbox oil. [complete] 23. Top up power steering. [complete] 24. Fit radiator & hoses as well as fan shroud. [complete] 25. Pour in coolant. [complete] 26. Fit air cleaner assembly. [complete] 27. Ensure all hoses clamps are secured [complete] 28. Fit charged battery [complete] 29. RUN ENGINE! [complete] 30. Check for leaks etc. [complete, leaking mildly from metal water to heater hose] 31. If all ok, which it will be. Bolt seats back in. Clear path behind and remove vehicle from container. [complete, apart from drivers seat]
  18. I have a spare L200 gearbox, flywheel and rather worn out clutch if you need them.
  19. Well its off. Just about smashed my skull in when it fell Mission is going well. 1 more week (if that) and I'll be cruising again! :-D
  20. I thought I had screwed up somethign else somehow as the bolts wouldnt budge; suppose my weak arms wernt convincing enough
  21. Got 3 more. Miss van for summer camping missions
  22. Ok, crc marine applied. Will reattempt with your guys tips after work.
  23. Handbrake is removed. Shaft isnt spinning anyhow, the bolts just seem seized
  24. I've been trying to get those 4 bolts undone, they are insanely tight. Might go spray some CRC on at lunch time and let it soak.
  25. Hi, Need to get driveshaft removed from my van. Gearbox is still mounted, but engine is out. How do I get the driveshaft off? Thanks
