Posts posted by Jeffs_Emporium
15 hours ago, HighLUX said:
Pining for vids of doorts. G52 and tiny wheels is going to make it hit it the limiter in 1st reeeealll fast
I do have a bit of a selection of diff ratios available with the 3.9 that's fitted and 4.1 from the ym30 and the original 4.6
Have been working on refinishing the beetle earlier centre caps. They originally have a chrome finish but since they are 40 odd years old the set of 5 were all in various states. I hit them with vht wrinkle black and sanded off the faces of the logo. They look good from far.
I did try spraying some silver on some cardboard and pressing them down kind of like a stamp but it made a mess. Lucky there are 5...
- 6
I managed to get a good price on a piece that I've wanted for a while.
HKS IPM (Injector pluse monitor) has and adjustable alarm you can set to a specific Injector duty %
In short - flashing lights and buzzing sounds. Perfect interior accessory.
I'm thinking this will replace either the additional Injector Controller or Boost controller in the glovebox panel. I'm needing to remake the panel as there are a few things I want to change
- 5
Hopefully OK to share in here/it's pretty relevant
Recently I purchased an HKS turbo kit listed for kp61 starlet for my small online based parts business.
It utilizes the original carb in a direct blow through setup.
Seriously considered going back to 5k to use it in the van but luckily someone purchased it before too much thought.
Happy to say it will be staying in nz and they have decided to let me restore it for them also.
Jordan at Autoparts Vapour Blast has done a great job vapour blasting the flaking wrinkle coat off so I can re-apply for the new owner
- 22
Used these wiring diagrams I found online for fuel pump control with carters oil pressure safety switch and for the thermoswitched fan with a manual override.
Have also put a manual override allocation on the fuel pump incase there are any issues. Used a couple of powertech 30A pre-made relay circuits with switches and swapped pins around to suit my needs
On 06/01/2022 at 22:52, GARDRB said:
Have you sorted your radiator filler yet? https://www.aliexpress.com/item/32853053737.html?spm=a2g0o.productlist.0.0.3cd95632UCYCL6&algo_pvid=19c20a98-9f25-4799-a51d-726758680599&algo_exp_id=19c20a98-9f25-4799-a51d-726758680599-6&pdp_ext_f={"sku_id"%3A"65349876555"}&pdp_pi=-1%3B22.18%3B-1%3B-1%40salePrice%3BNZD%3Bsearch-mainSearch
I have sourced one from China a while back that is indeed that one
Had a bit of a yarn to them about my radiator situation while I was there.
This is the current setup which has the bottom outlet on the incorrect side for the 4ag. They claim the increase from 1500cc to 1600cc would put this radiator out of use anyhow. I'm looking for a cost effective solution that will fit in the same space, use the factory mounting points and as a bonus have electric fan with shroud attached.
Width to outside of tanks is 625mm and height 370mm 32mm inlet and outlet sizes
Have been making good progress on the wiring. I feel like each time I do it I learn from my mistakes and take a bit more care and make it look more factory
Just collected the re-cored heater core from Auckland radiators after spending about twice as much as I wanted but it was one of those not keen to take the dash out again moments
Hoping to receive $430 worth of warm toes in winter.
A few hours rigging up some wiring this afternoon and I was able to get it fired up.
Hyperpak was a breeze to wire up and just jigged up something temp for fuel pump.
Hoping to spend the next couple days finalizing the wiring with the proper relays with an electric fan provision also.
- 25
Have been a bit slack on working on this but have word the tailgate is almost done.
As much of the bottom straightened as possible and then some filler to sort the rest.
Purchased an old fiberglass fixed back to run in this as a bit of a tester to see how bad the shipping prices from Japan are for them.
Who is Alex? I'm not sure but I have a vague memory of flicking through catalogue pages and seeing the name so went for a sift this afternoon.
Listed in 1989 CARBOY sports tuning guide from Japan is the 'Mr Alex' fixed seat for ¥28000
Also found my old Bride reclineable which I didn't think was an original upholstery at the time
- 19
On a lighter note, the second tomcat has arrived and is booked in for surgery
latest one was originally red (they only came in red or gold)
I plan to have it painted in red and the other left in gold to see what suits the car best and paint one colour when I locate another pair some time.
Sizing wize 10J A type is on the cards but there is a small voice reminding me I have shorter axles and should find another subframe to shift arm mounts inwards.
Sheepers latest Ms75
in Project Discussion
Probably not high compression either
https://page.auctions.yahoo.co.jp/jp/auction/g1022274535
