Posts posted by Jeffs_Emporium
Pretty upsetting to find in my driveway this afternoon.
Must have happened last night as it was normal when i used it yesterday
Bloody lucky they didn't get in as I had more stuff than usual in there. Given me a bit of a wakeup call to keep shit hidden ( I'm usually a lot more careful)
I'm guessing something spooked them as there was about 15k worth of building equipment sitting there.
They didn't even damage the lock enough for it not to work
Tools have been put away like they should have and looks like the van is narrow enough to tuck inside the gates with some creativity.
- 30
Have been burning around in this a bit recently, fixing small issues as they come up.
The Carter fuel pump has a knurled fitting that the leads slip onto. These keep jumping off resulting in pulling to side of the road and lying down and reaching up under to put back on. Probably need a better solution before I get snagged on motorway. I can't seem to get the heater to blow hot, think there might be air trapped in it. Need a tall ass funnel to be higher than the top of the core to bleed it.
Orderd a 21/5 speedometer driven gear to replace the 19/5 just waiting on that to arrive to hopefully get me in the ballpark.
- 22
With the rear panel being modified to take late model mark II tail lights I doubt the matching garnish that houses number plate and number plate lights would fit so I'm going to take the opportunity to attempt something similar to this
Inspired by Instagram user alkku_
Mine will be a bit harder due to inner inward edges on x6 tail lights having a beveled edge not 90° with the top bottom. Hoping to use two spare lights and slice them in the middle and get the bevel right on outer then glue them up
- 6
Couple of photos from the Trademe listing.
1981 Toyota Cressida RX60
It's had a full panel and paint with all the door jambs and everything done as well as underside.
JZX81 steering rack mounts and engine mount towers have been grafted onto GX60 engine crossmember and 81 rack fitted.
S13 front coilovers, hubs and castor rods have been fitted up front, I'm just having some brackets made up to locate castor rods onto factory cressida body mounts
Ae86 coilovers have been fitted to the rear with the E series solid rear still there.
It's had a late model chaser sedan front installed and late model mark II tail lights have been grafted on.
There's a 2JZGE VVTI with the gte covers fitted, W55 and a flywheel has been located to manual convert the motor.
- 23
Not likely to be a problem for you but when slotting motor into my van I ran into sump clearance issues with the ground when dropping motor to clear the seat due to running 13" wheel with a 175/60 up front.
New muffler and rest of the exhaust in 2.25" and driveshaft hoop fitted
Idle problem was seat pushing front carb down and creating vacuum leak at the soft gasket. I have used a big hammer to fix that.
Things I need to still address:
Speedo out by 10% so need to see if I can get a cog with extra teeth for the speedo drive or increase rear tyre size by 10% (5% to get within the threshold)
See if I can get a legal sized tyre for the brx rear wheels (13x7j) that fits in guards and doesn't further mess with speedo.
Pcv from cam cover to a non vented catch can returning to fittings pressed into all 4 trumpets with a gauze filter on face of trumpets like so
There's a bit of renewed enthusiasm from hooning around in it, it goes pretty good even with 3.9 diff and 165/80/13. From memory ae86 diff ratio is a 4.3
Don't forget to calibrate your speedo, bash your guards and change your bumpstops to suit
Tune went alright. Definitely blew the budget.
And the muffler...about 200 meters down the road from webers specs into my 30km journey on the motorway back across the Harbour Bridge.
It definitely has a decent pull to it but is horrible to drive due to the engine touching the seat, the obvious noise and the poorly set up linkage.
It also isn't idling by itself after that backfire, the idle is so low that the oil pressure safety switch kicks fuelpump on and off. Hopefully it's just a small adjustment needed.
I've got about 4 weeks to sort driveshaft hoop, legal size tyre for the rear wheels that corrects speedo, big hammer the seat cover, new muffler and definitely hone the suspension.
There's a definite temptation to track down the rest of the floor shift shit tbh.
- 17
I had this thing running and warmed up until thermostat opened and tried my best to bleed air out of the system. Carbs definitely need tuning so it's booked in to get taken to weber specs to sort it out. They advised against running the engine at all until they've rejetted carbs.
I've also booked in for driveshaft hoop to be made the following week and a certification check for early may.
Hoping it all pans out
Enjoy this photo from facebook i found a while back on the NZ car relates scenes 1950s-1980s page
- 15
5 hours ago, Bling said:
Not sure what is considered central, but could get in touch with https://strangeworkshop.co.nz/
Have tried contacting them numerous times over numerous years so preferably someone else
Seeking reccomends for a central Auckland workshop to carry out driveshaft hoops on both of my vehicles. Hoping for a drive in/ drive out solution.
A fella from the nz Datsun parts Facebook page was kind enough to post some b310 engine mounts up which have worked perfectly.
They are bout 12mm thicker with an offset pin.
All of this time under there ive noticed the gearbox rear seal needs replacing.
I'd drained the Gearbox oil incase I needed to remove driveshaft when doing that release bearing so its no bother to swap a new seal in while I'm here.
Those mounts have given me a good amount of lift on the box, pretty chuffed.
I'm awaiting a bung for the sq engineering rear water outlet since I'm not running ecu or cold start sensors. That rear seal and an inline fuel filter.
Radiator is mounted for good, fan clears engine by 5mm.
Nearly ready to fill with water and bring up to temp and watch all the leaks =/
- 18
Searched the kelpro catalogue and these bottom two nissan ones look pretty good.
Except the dimensions shown vs the written measurement seems to have been mixed up. One looks like it's from b110 engine mount. A quick check shows a12 is 97kg and g52 is 35kg so they should be up to the task?
Rock auto has a pair $35 delivered but they won't arrive until April 4th so if anyone reading has a used pair kicking around to confirm that would be handy then I can order new also.
Purchased a new release bearing and installed yesterday. Pretty easy job with space for a ratchet behind all the bellhousing bolts. Having a look at my Gearbox rubber mounts they really need replacement.
They are the items highlighted green which are no longer available new (genuine).
Might use this opportunity to use something taller to lift Gearbox, there's about 20-30mm clearance above it currently. This would also help with the driveshaft angle since the diff is a good 4" closer to the body than stock. I'm guessing going to a taller rubber I'll have to weld and re-drill new holes, maybe even put a plate on crossmember so I can get the pin on the mounts in the sweet spot.
- 5
6 hours ago, Sungai Sungai said:
those camber plates are gorgeous, where do i cop some!? also this is one of the sickest car in the country man a thousand kudos to you
https://www.izanami-wheel.com/en/product/pillowballuppermount/
So after setting the gear lever to specific heights it seems I have all the gears but in the wrong orientation. Reverse is where second should be (closest to steering wheel) and first being closest to dash board. Also having some Clutch problems. When I push the pedal in it loads up the engine? Trying to think what could be up with that
Nissan March (micra) K11 appreciation thread
in General Car Chat
Althought its a bit earlier, i have this brochure coming in that may appeal to some of you sickos.
