Posts posted by Jeffs_Emporium
This is the current state of the exterior. I need to track down a front windscreen and fit the rear one. Also needing the blue cressida/Chaser bonnet badge if anyone has something and would like to find late model bumpers
There's some fettling to do on the front lights to get them to sit properly and track down the proper Chaser corner lights.
- 8
Having a look at the rear end when test fitting some wheels yesterday.
Being a nz model it has the solid rear end 7.1" E series diff. I've broken a few of these behind a pre vvti 2jzge so will likely upgrade to F series maybe even G series
There's a set of ae86 xyz rear coilovers which look to have a 10.5kg spring which seems way too stiff. It's also sitting on those bump stops currently so they will need to be deleted
Last on the list (that im aware of) was this water leak coming from the back of head.
Most 1gge owners have issues with gasket sealing here so this was infuriating to see the gasket was in perfect condition and I was unable to remove it in one peice to transfer to the spare outlet.
I made up a paper gasket for the spare and it's held up so far so fingers crossed.
- 6
Another crucial part of the build was sourced a few weeks ago
Some new or very close to fender mirrors in 037 colour. They came in toyota door mirror box's amd with a stick on chrome blank for the holes in guards so I assume we're removed upon purchasing the car in the midst of them changing to door mirror models
Got the message from Aidan at Pine engineering that the wheels for this have been completed
14x8/9 A type focus spoke.
The general idea for this car for those who remember is a bit of a tribute to the old gx61 two tone drift car I had
Keep it 'Simple' with a fully stripped out car, 2jzge, 14s and as close to the ground as possible with no LVVTA restrictions.
Green lane speed shop made up a cold start injector fuel line that replaced the janky barb fittings and crusty 30 something year old hose the supercharger kit came with.
I also added the correct size fitting to fuel pump inlet so the tank hose could slip on further than 5mm.
Replaced diff bush while I was groveling on the ground and lifted rear back up to get camber back in spec.
Now I can check the water in 3 easy steps instead of 20 minutes each way.
I still can not get the heater to blow hot no matter what I do, the tap doesn't feel seized and I've tried bleeding air with a bucket sized funnel sealed on filler neck and the heater hoses at back of engine feel very hot.
- 8
21 hours ago, Mr.Mk1 said:
While I feel for you handing over cash and getting excited about finally having that garnish, fuck that gave me a LOL.
I feel ya. I definitely lold at the quality.
This thing has always had a bit of a water leak most likely from the shit junction on top hose where there are 4 joints in 200mm (engine-filler cap-radiator) all on a bit of an angle and just average. Took it in to my radiator guy and he said to make a cardboard model of how I would like a filler neck added to passenger side
The existing setup meant I had to remove drivers seat and 10 or so bolts for the engine cover. Moving it to passenger side means 3 buckles and I can check/fill water. Tempted to move dipstick over there also....
Dropped it off this afternoon with my cut up glad wrap roll. Hopefully back up and running for the weekend
14x9 14x10
in General Car Chat
185/60/14 on 14x10
