Posts posted by Trigger
Hey man,
measured up my Sigma and Ex rear coils
sent you a PM,
see if it helps?
Hey man,
Kool ride you've got in the build there!
I've got and 1200 Ex too, and hope to be putting a sigma motor, front end etc in soon,
Was hoping to put a sigma front sway bar in my mates 1600 Ex (hes NOT using the sigma x-member either) but you reckon it wont bolt up? Cant see what difference the x-member will make? (Cheers for the heads up tho) I'll have to sus it out...
Wanta change my dash cluster over to a 1600 one too,
Good luck with the rest of the build, bet ya hanging out to take it for a skid!
I got my shocks done at Stocks in Auckland,
got different inserts fitted and lowered springs,
and they mod. the front shock housings to have more travel
bit of mucking around, but you could try them?
True, where did you find GSR font shocks?
I'm using the sigma front x-member and lower arms + starion ball joint knukles and shocks,
if I cant find any GSR shocks, I'll have to stick with THAT setup and hope for the best?
Cars you own: Sigma, Ex, Lancer (Evo2), galant
Mods to them (can be brief or detailed): Evo (LOTS of mods) good take off and 1/4miles! just starting on the EX...
Links to pics: viewtopic.php?f=17&t=13789
How you found out about oldschool: talking the talk
Anything else you want to add: MR4G63 SYSTEM OF A DOWN!
I'm at the same stage with my EX (1200) just got some starion front struts and brakes
using sigma lower arms (same as the starion) just waiting on the starion ball joint knukles (x2 bolt)
gona swap the top hats over, then work out what spring/shock combo to go with?
Hope it DOESNT have postive camber?
rear springs wont seat properly
in Tech Talk
Hey man,
glad you got some springs sussed
4inches / 100mm is pretty low
think if you use a spring shorter than about 300mm
it wont be captive and you'll need shorter shocks
LOTS of info on here about brands and part numbers etc
Trigger
