Posts posted by - i5oogt -
I decided to have a go at repairing it as I pranged my daily mk5
got this off purple~esky on here as a crash damaged car, I couldnt decide if it was going to get dismantled or fixed.
front end pulled apart to inspect damage
interior needing some re-assembly
trying on a replacement bonnet to check fitment
damage to the old bonnet
also have the 14" ROH mags i had on it if you are interested looked really good with these lowered. I didnt get any pics unfortunately
sorry only have twin carbs/manifold, a set of front legs with compressed springs left for a hunter. everything else went with the car when i sold it last month
What's the departure time/day for the ferry back?
Picton › Wellington - Thu 05 May 2011 - Depart 1.10pm - Arrive 4.20pm - On board Kaitaki - Final Check In 12.10pm
Wellington › Picton - Mon 09 May 2011 - Depart 8.25am - Arrive 11.35am - On board Kaitaki - Final Check In 7.25am
I have got a backup car sorted if anyone breaks theirs / decides we need to travel in 80s ford luxury for nats ...
standard tplink routers are around $45-$50 trade price
wheel centre and nut caps are in the post
":td1rcanr]dont forget the"Meat is Murder" sticker for max lolz
any luck with those centre caps carl? get wheels back tomoro
oh yeah im really useless and havent sent them yet will try and get them off to you tomorrow. sorry mate
this is going to be a sweet weekend
yeah a meet sounds good.
sweet will post them this weekend
got those caps for you, I will send them in the next couple of days. did you want a set of the plastic wheel nut caps too?
for the 2L? i have a spare driveshaft end you can have if you want it
got any details on that piston kit? I cant seem to find them on ebay
yep, im super keen for this. if no one wants to take cars accross the water due to costs we can fly up
then either catch a ride with one of the welly gc's or rent a car?
I will take some pics in the next couple of days to show what I removed
removed EGR Crap and cut some plates to cover the holes up. everything appears to be working as it should now. and it is noticeably quicker too
so Isuzu = clocked (well until the next thing goes wrong)
thanks for your help guys
I threw a brand new turbo on it 6-8 months ago and cleaned all the lines etc out then at the same time i put the 4jb2t oil return line from the rocker cover back down into the sump to clear any excess oil build up in the head.
I will put a boost gauge in and see if the turbo is doing anything. has near new glow plugs and injectors. It is still running the EGT crap I haven't removed it yet. I was thinking that something associated with it might be causing the problem as the fire was on that side of the engine. all the vacuum hoses are looking tired and a little cracked etc so it will be a good opportunity to get rid of it.
I will try that tomorrow after work and report back
cheers
Karl
hey guys
I have a 1990 Isuzu Bighorn with the 4jb1t 2.8 turbo diesel motor.
It had an issue last week where the starter motor solenoid jammed on basically cooking the starter motor and the wiring associated with it (caught fire) i have replaced the wiring and the starter motor.
It now runs and goes well when cold. however when it gets to operating temperature it looses most of its power. you cant hear the turbo spinning up and it throws alot of black smoke out of the exhaust.
im thinking it has cooked a sensor somewhere causing the wastegate to stay open? anyone have any ideas?
cheers
Karl
I have a 1990 Isuzu Bighorn Irmscher S LWB. 2.8 Turbo Diesel Manual.
looked around for ages to find one that wasnt rooted.
ended up putting a new turbo on it when i got it. It has 31's. had to get some of those rubber guard extensions for it as they run a 205/70/16 factory
This is my List of Cars Owned.... Cortina Overload? The ones in bold I still own
1986 Holden Barina
1987 Holden Barina
1993 Mazda 323
1989 BMW 320i
1986 Mitsubishi Mirage
1992 Mazda Familia
1988 Toyota Corona
1993 Ford Laser
1988 Mazda Capella
1986 BMW 318i
1989 Ford Laser
1991 Toyota Corolla
1996 Toyota Camry
1998 Toyota Camry
1990 Isuzu Bighorn
1994 Isuzu Bighorn
1996 Mitshubishi RVR
1970 Holden Kingswood
1977 Chrysler Hunter
1967 Hillman Hunter
1974 Hillman Hunter
1979 Chrysler Hunter
1969 Cortina Deluxe
1969 Cortina Super
1968 Cortina Deluxe
1967 Cortina GT
1967 Cortina GT
1970 Cortina Super
1970 Cortina Super
1969 Cortina Deluxe
1970 Cortina Deluxe
1970 Cortina Deluxe
1970 Cortina GTE
1970 Cortina GT Wagon
1969 Cortina Deluxe
1969 Cortina Super
1968 Cortina Super
1968 Cortina Super
1967 Cortina Super Automatic
1969 Cortina Super
1969 Cortina Super Automatic
1970 Cortina Super Automatic
1967 Cortina Wagon
1971 Cortina GXL
1977 Cortina GL
1977 Cortina GL
1964 Cortina Super
1983 Cortina L Auto
1981 Cortina Ghia
1983 Cortina L Manual
1982 Cortina Sport
1982 Cortina Sport
1982 Cortina Wagon
1982 Cortina Wagon
1980 Cortina Wagon
1980 Cortina Ghia
1980 Cortina GL
1982 Cortina Wagon
1983 Cortina Wagon
1984 MK3 Escort XR3
1969 Cortina Super
[ i5oogt ]'s MK5 Cortina Ghia
in Other Projects
After pulling the front out I had a dig through my parts stash and found a gold bonnet. although it is the wrong gold it does the job
also fitted grill, headlight, bumper from my parts stash. bumper is slightly bent up on the drivers side but that can be fixed later
next came to replace/fix all the broken odds and ends
replace bonnet release cable, strip fusebox and clean corrosion to get the horn and headlights working again, strip dash and get the illumination working,
replace heater core and dash control cables. flush cooling system and refill with antifreeze. change oil and filter
re assemle interior
and install some cheap sounds
ramflow for the dirty old pinto - everyones favourite engine
Got a wof - went straight through
paint some rustkill on the nasty repair until i can be bothered filling and smoothing
the only thing left to do is change the rims for something more oldschool
