Posts posted by solidstripe
Swage lines! That sounds so much better than "logs" hahaha...
Where about's did you work Chris? It was a bit of a mish trying to find cladding or even a wreck to take some off so ended up just making it ourselves. Measured once but it didn't feel right and realized I had to offset the measurements a bit to allow for the shrinkage from folding. Thankfully came out pretty good for a first try.
All sorts of toys! Hopefully by the time it's done it will have space to fit at least 3 - 4 motorbikes, or a kei car (anything up to 3m long or so depending on the bumper set up) and/or a dingy and still sleep our family of 4 and be self-contained. AND still work as a functioning office too! Bring on the working holidays... haha
- 6
If anyone else needs this type of cladding, back fold about 10 degrees for the "log" type joints and then fold 90 degree for the angled body lines. They should be kind of curled up on themselves, but then once laid flat and rivited on, the "logs" will buldge out giving that typical caravan cladding look. Also, don't go bigger than 1mm in thickness with the ali as it gets hard to bend, is more expensive and unnecessary. The stuff that's on there is probably around 0.5mm? You can see the new stuff as it's shiny in the photo below. Seal the joints with MS marine sealant (not the black stuff as it gets everywhere!!).
Oh, and hammer the ends of the angled body lines down once in place so its all flush and matches what's there.
Don't know if peeps are into caravans on here? Anyone else got any threads? I've seen motorhomes.
Anyway, got this sweet '80 Roma caravan that is a bit different. The story goes that it was owned by an old engineer that wanted to get his Ford Model A (or T) to Ford meets, but it wasn't exactly easy to drive it to each meet, so he cut the back off his caravan, strengthened the chassis and turned it into a O/S toy hauler. He had a single fold up bed and a little kitchen up front and modified the back to use as a ramp/deck and could drive his car in, cart it around, then when he got there, drive it out and fold his bed down to stay. Primo! However, it was pretty beat up and in need of some love when we got it:
Shot guys, thanks for the info.
Appreciate the vote of confidence on the "affordable" rubber, good to hear first hand opinion.
And cheers for the vote for lacing up the front hub to the back rim. That pic is pretty much what I'm after! I'm guessing since I'm dropping so much diameter size, I can afford to go with the higher aspect ratio/profile? (i.e. 90 instead of 80) Found this guy online based in Auckland http://wheelandspoke.co.nz/services.html
Not sure of the rear wheel width, I see I wrote it down as 17 x 215 but that can't be right. (Have left the bike up at bro-in-laws for the day, so can't double check). Could it be 17 x 2.15? I have read some people saying its a toss up between running either a 4.60 or a 5.10 for the rear tire width. Presume it's safe/possible for me to go a size up to 5.10 on the rear, because as I mentioned, there's a fair bit of space and I can't see a moderate increase causing any issues of it rubbing on anything. Is that a normal thing to do with bike tires?
Hi y'all, I need some help as I'm such a wheel noob!
I have a KLR250 with thick knobblies on it that are needing to be replaced. They are on the stock wheels.
Since I use it for commuting mainly and they are sliding out on the road, I am wanting to put some Shinko E705's on it:
The bike currently has a 4.50 - 17 120/90 knobbly on the back with a 17x215 rim, and, a 3.00 - 21 knobbly on the front. I want to go motard style on the front with a wider wheel. There is 120mm space between the shocks.
My questions are:
1) What's the most affordable way to widen the front wheel and have a smaller diameter (17 or 18")? (Buy an aftermarket wheel? Buy a second hand set of wheels and swap the rear rim and spokes over to the front hub? Would that fit?)
2) How wide a tyre can I fit on the stock rear rim? There is a fair bit of space on the swing arm and the chain isn't an issue. I presume you can only put a slightly wider tyre on the stock rim?
Appreciate any help by those more knowledgeable than I.
Pics/vid's of CB/XR plz
Sold - Going to a good new home in Hawkes Bay at the end of the month.
Oh wow!! Long time no see! Man it's good to see it again!
How's it running? Did the guy I sold it too fulfill his dreams of RB26-ing it?
Also, does anyone have a front sprocket cover for an XR200? As you can see, mines MIA somewhere. If so HMU for $$
On 10/10/2017 at 20:53, MopedNZ said:
TAURANGA?
TAURANGA??
TAURANGA???
Well, I live here. Are you local? I pine over bikes and there aren’t many around here that do. Keen to pine over yours sometime.
This is great news.
Hey bro, yeah local as. I'm sure we will run into to each other sometime as I use it all the time. If you see me round just toot like crazy so I know its you haha
1 hour ago, SOHC said:
That looks cool, I like the wood gran. I would be the one you got the motor off
Oh choice, thanks man - it's still going hard! Just got some new clutch plates for it cause the clutch is on the way out, but other than that, just gave it a paint and stuck it in. Only had to do the intake pipe and that was it And the rest of the XR200 went to a good home too with some local guy wanting to retro upgrade his suspension (as I hear the '89 was better than the '90+ or something?)
On another note, I redid the rear number plate holder which now doubles as the rear guard out of 3mm aly flat bar - way more sturdy. Also fitted two new little LED rego plate lamps top and bottom (cause of the curve of the plate it needs two haha) and pillion pegs for the WoF. I tried to argue that it never had rego plate lamps, but if that's all it needs I don't mind. Also redone the muffler bracket so it's a lot more sturdy now and hopefully takes the pivot stress off the head
Next up: going to have a crack at making a bit of a tracker-type tail thing for it so I can relocate the tail light as it keeps rubbing on the rear tire and I don't know how much more they can both take haha....
On 10/6/2017 at 07:44, Kimjon said:
Great result in all regards! Well done.
Cheer ears!
Back guard needed to go, and got annoyed at the prospect of having to make a plate holder and another smaller rear guard so came up with this idea. Hopefully it's WoFable?
Also was going to go full LED with the lights but thought I'd keep the stock brake and indi's as they have grown on me. Hard mounted the indicators to the frame and relocated the taillight to the seat.
Solidstripe's O/S Toy Hauler
in Other Projects
Cheers ears!
While the old boy had done a great job of the rear end conversion, this junction detail here had me concerned about moisture ingress. It has an "internal gutter" for want of a better word underneath but I wanted that to be the last line of defence, not the first:
