Posts posted by HUNTD
Wonder how this one is going to be killed off and what color the next one will be.
im hoping for pink
that would be so aws
its possible (just not for sales assistant
). even non ex mechanics. you just gota get up the ranks a bit.
what i done when i changed my open diff to my trd one on my chaser was this
pulled the bearings off using a modded gear puller ( had to due to were the bearings sat )
when i pulled the shims out i made sure they went back in on the correct side
changed centers over ( easy also used new crown wheel bolts ex toyota )
when it came to re-assembly of everything i sat the diff in the craddle, making sure it was meshhing correctly, placed the shims/washers in on there correct side's.
torqued the bolts up on the caps
then got engineers blue and chucked it on three of the crown wheel teeth
rotated the crown wheel in till the ink came back around and used that to check for meshing probs
as the crownn wheel turns and meshs with the pinon it whips the ink off on the surfaces that touch each other and you can tell weather or not you have good teeth contact
most bearings now days you can get about 100k kms out of ( un opened of coarse ), but if i were you man i would change them, regardless if there notchy or not, just for peace of mind
tell me what the bearing numbers are and i can get them at cost + 10%
ring around a few storage places get a price and send him a bill for cost of storing his car
for however long,
if bill isn't paid he must surrender the car back to you etc like panelbeaters do when the bill ain't paid,
and then once hes surrendered that report your plates and tags stolen get new ones and profit or just report the plate number to the cops and tell them whats happened
mean idea
Note ....... I said ......."skimming the head for more compression".
There's nothing wrong with skimming a head to make it flat.
To make any extra compression that's worthwhile, say bringing it up from maybe 8.5 to 9, or 9 to 9.5 involves taking a LOT off the head.
Personally I've had 80 thou taken off iron heads and had ongoing problems which took me a while to figure out.
Why suggest it then... why give advise that you know is going to fail and cause problems? What the hell does your speel have to do with "is it worth putting twin webbers on a hillman hunter?"
and forced
were talking about hilman hunter 1725 engines that have been around for many years there cast, alley wasnt even a thought on these engines hillman imps yes hunters no
Sorry love he is correct. Either cast iron or aluminium head. If hes got the iron head its probably worth getting the carbs just for the manifold. they seem pretty uncommon.
And skimming is worthwhile if using the aluminium head because they are so prone to heat/warpage.
franklin cams have a good cam regrind available, cant remember specs of top of my head. kelford didnt really have an idea of what to do with hunter cam last time i contacted them
You should do your exhaust first tho. makes heap of difference
Is your iron head or steel????
Don't you mean........ Is your head cast iron or aluminium?
You are correct
LOL
mobil dont make those filters
champion labs do and there re branded as mobil so to say mobil makes them is a crock of shit, it will even say that on the box
FLAWLES wrote
what do you do fred? i am very interested to know?, and im asking with out being checky, as you seam to have an answer for most things
plse answer as i to am keen to know
i have a 1725 and gb
and i just relised that im using donnas sign in
jarred
most gen filters are either fram and or donaldson
most filter suppliers or gen filters do offer a garrentee on there filters.
for instance if something goes wrong with a filter i sell for any tractor or machinery i have to go get a inderpented oil test to prove that i was the filter that failed or if it was something internal, more often than none its the oil that pple use and not the filter
theres nothing wrong with fram
flat battery....
no wof...
awesome.
sweet fuck all, just wanted to inspire myself to do something.
got new block after finding original one was fuxed.
Wheel nuts to suit your spare!!
lol awesome
waterpump is cheap at repco too. cant remember excatly how much but a lot less than that!
haha yes, every old man used to stop and talk to me. and then be actually suprised when i knew stuff about it, fully just expecting me to be like uhhh im a girl.
Yea it sucks with how narrow it is in the rear aye. You pretty much gotta roll the guards a little bit.
yours does have an alternator and not a generator?
D.i.y. Heaps easier than doing a modern car cos the glass is flat. only tricky bit is the lil triangle corner windows but they arent half as hard as doing a rear window in a modern car.
faster than the primera running on 2 cylinders in reverse with the handbrake on maybe...
http://www.trademe.co.nz/Browse/Listing ... =175181071 1725=better than a 94 primera
Traffic light law query
in General Car Chat
maybe you should be thankful that you got let off so many other things and take it. they are going to say if you were travelling within the speed limit you should have been able to stop.
