go hydrolic if you can
all i did was get out the hole saw and make a hole in the firewall where i could see the brake pedal, bolted a VL master cyl in the hole.....then cross drilled the brake pedal and made up a push rod.
it was one of the easiest mods on the entire car. Just watch the ratio of pivot to rod and pivot to pedal, mine comes up very short! there is only 1.5 inches of pedal travel, but i wont lower the pivot point on the pedal for more travel as i quite like it
space wise it is right up close to the brake booster on the mk1 capri, maybe 2 inches to its left is all youll need and sits quite low too
cheers
cue
