ProZac
Posts posted by ProZac
  1. For the throttlebodies I'd strip them completely last part. The media will get everywhere. It's worth it though. Get all the steel bits zinc plated and gold chromated, they'll look better than brand new :-). Hit me up on the ol faebos and we'll sort it :-).
  2. If you're keen on pulling the carbs to bits, we can sort you out with using the wet blaster (vapor blaster) at uni. It cleans up aluminium casting like nothing else I've ever used. Simply amazing.
    internal coating stuff sounds like complete waffle.
  3. Can you put up some pics?
    I don't think any of the later intercooled Starion front compressor covers had the TD marking embossed into them, they usually had a spot on the casting where it was supposed to be, but usually not stamped, so they just read '05-12'. They were TD turbos though. If yours had TD embossed into it, its probably not a stock starion compressor cover.
    060 refers to the exhaust housing size, it has a 6cm^2 passage measured radially at some specific angle. It's mitsies way of indicating what garret calls the A/R ratio. 060 is the smallest, there are also 070 and 080. 070 Seems to be the sweet spot for a modified SOHC 4g63.
    Yes, you can machine out a 12a compressor cover for a 14b wheel, not sure about all the way out to a 16G, but it'd be worth a shot.
    Years ago I had all the compressor maps for this stuff, did the calcs and came to the conclusion that for a worked SOHC 4g63 an EVOIII big 16G was where you wanted to be, should be smack bang in the meat of its efficiency range at around 1 bar of boost. I bought a stock evoIII turbo, rebuilt it with a mitsy rebuild kit, and bought kinugawa housings for it, 070 exhaust and a big front cover. The front cover is machined for the EVOIII big 16G wheel, but is the same casting they also machine out for 20G and 25G wheels, so looks externally much bigger. Gotta have the aesthetics, yeah? ;-).
    Early non-intercooled stuff is the TC range, hopefully that'd not what you have, not a lot can be done with them.
  4. If they have more than one 3.909:1 8" CW&P setup, let me know, keen for my Starion GSR-V clone project.
    Nah, I dont reckon the 7 bolt (RVR) motors are as bad as they make out, not if you keep it maintained and aren't asking huge power from an internally standard motor. They do make the install easier having the timing gear on the front of the engine.
  5. Cool truck! love the wheels :-).
    Only the later Starion stuff (5 stud) with the bigger 8" CW will fit, the earlier 4 stud stuff (more common in NZ) is the smaller 7.25" CW.
    Finding 3.9 gears for the 8" stuff is a might tricky. Early L200 sport models had them. I put 3.5's (from a widebody starion out of the states) and a 2nd gen LSD head in mine though as I wanted better highway cruising. The 3.9's that were in mine were pretty worn out and noisy. With the smaller tyres on it putting the taller diff in it has corrected the speedo which is excellent :-).
  6. Haven't had huge motivation level behind working on this the last month, so not a lot of progress really. Work is pretty hectic atm with the whole COVID-19 thing... I suspect I'll either get absolutely zero time to work on it in the next month, or the Uni will close down and I might have more time that I know what to do with...
    Anyway, I drive this thing with headphones in most of the time, listening to audiobooks. This means I don't hear all the sounds it makes. My headphones were flat the other day, and I drove home without them... Really really odd noise was coming from the gearbox area, related to vehicle speed. Didn't take a lot of sleuthing to find the problem:
    This was completely dry just a couple of months ago when I put the new diff in, so it's let go in a pretty decent way. Managed to get a replacement seal and the use of a hoist as I don't like rolling around on the ground if I can avoid it. About a 15 min job to swap it out, took longer to refill the gearbox than swap the seal. Seems fine now, no weird noise and no leaking... I sort of suspect the output shaft support bush might be flogged out, but this gearbox will be replaced once the new engine goes in anyway, so as long as it holds oil I'll be happy.
    Silly regular maintenance instead of mods. Lame. Front left wheel bearing felt a tiny bit loose too, so gave that a nip up, and tightened the hand-brake cable too. Once I fix the exhaust leak at the manifold - exhaust point it would probably actually pass a warrant!
    • Like 6
  7. I've got a box from a 2.6 2nd gen L200, so wideblock and cable, should bolt to everything / existing mounts and be the right length. I've got a spare Starion box too, so might look at swapping the gearsets if the Starion boxes have longer legs, no idea if they're even any different.
  8. The loving projects is mutual mate :-). The black stuff was ABS, Imagin brand. Prusa i3 MK3s, generic ABS temp settings, no tweaking. It warps a bunch on larger prints though, as not a heated build chamber. Mostly I print PLA on it though, and get awesome results also. RS Components branded stuff, just for prototyping :-).
  9. 18 hours ago, bigfoot said:
    Can I please order one of all the cool shit you have made for this motor for mine?
    Hah, lets wait and see if any of it works first... ;-). I'll make two of a few things though, as I'll be doing another SOHC motor in the next couple of years for my Starion.
  10. 18 hours ago, NickJ said:
    3mm? are you building a tractor?
    But no, very good, sheetmetal is a thorn but oh so satisfying when it works out.
    Yeah, I got some CAD-eye on that one... But the coils are pretty heavy, and I have one bend that is greater that 90deg, dont want it to fatigue and break in the near future...
