4agze KE70
New Members
Everything posted by 4agze KE70
  1. Ok so if i go w5* gearbox i can get one with 4age bellhousing from reardrive what fabrication will need to be done to ke70 sedan to fit? Any tunnel bashing, are they cable or hydrualic clutch? Will the gear shifter sit further back? Also what tail shaft would i use i would have to get one made to suit correct?
  2. Sweet so i can go ahead with getting T50 and support brackets but one more question before i do theres another t50 for sale but it has the clutch slave cylinder on the exhaust side. Does this mean that its not an orginal 4age t50 what complactions does this create.
  3. Gidday everyone I have just started to build a ke70 sedan with map 4agze. Just a couple of questions before i go rushing into things im going to use a t50 gearbox i have sourced a 22 spline with a 4age bellhousing will that fit to the 4agze or do the have there own bellhousing? If they do the gear box support brackets will be different also won't they? Also for the gearbox cross member what do i use? Im guessing an ae70 cross member and mounts will need to be sourced? If you have any links or photos that might help me on my way that would be great. Thanks Shaun
