mikuni
Posts posted by mikuni
I'm the exact opposite Heath. That sump guard has confirmed I'm not going to do any road racing.
Yet, when I pulled in after my second run at Hampton Downs racing actual cars I literally had a grin from ear to ear. It's definitely the best track time I've had yet. The extra challenge of trying to get by someone adds so much to the excitement levels. I don't care if the times are down a little from being held up, once you get past them you can chuck a blinder in there to keep them behind!
As per the other thread, I'm using a Shorai bike battery in my race car.
They are expensive, mine was around the $250 mark and it is a little undersized for a normal car, but bear in mind it is a race car. I'm removing all of the electrics except for the windscreen wiper motor and I've removed a blade to reduce friction. Headlight bulbs have been replaced with LED bulbs and I might take them out altogether. For a road car with electrics you would need a much larger battery, but most older cars should be fine with a small one.
This is my battery
should be ok with a little motor like yours but i doubt it will turn over my high comp falcon 6,lol
I've seen a video of one starting a massive high comp V8. It was a couple of sizes up than my battery, but like you say, small motor, small battery.
Lead–acid batteries, invented in 1859 - is it possible that battery technology has moved on in 154 years? I think a lot of people just decide something can't work because they can't comprehend it.
I kind of just like new technology and new ways of doing things, and this was a really easy way of saving 13kg.
Looks like it needs heaps more holes once you cage it.
Definitely! I'm pretty much going to just tidy it up in it's current form and try and get it to a few events at the moment though. Before I lose the plot and chop it into a million pieces like the last one.
Decided to grab a picture of my battery - I agree, it is very hard to comprehend after a lifetime of lead acid batteries, but it's working!
Give you an idea of the size - that's the battery in the distance on the firewall
No Michael, that is unacceptable. It is NOT OK. Go to the back of the room.
Cool car bro. Glad you got it in the end. Wait, that doesn't sound right.
Also, I swooned at the Laguna.
Not sure about Li Ion charging, but Li Fe can be charged perfectly safely from a normal battery charger as long as it has a automatic cutoff once the battery is full. Charging from a normal vehicle alternator circuit will be fine for the most part, but you'd want to be careful with earlier vehicles or dodgy alternators. All that will occur is a damaged battery though, no explosion like may occur with Li Ion or Li Po.
Shorai FAQ
210cca amps is really light,so id only used to post fire up
It's measured in a different way to lead acid batteries. Do some reading on Li-Fe, they are pretty good. I would wager they'd last longer than one of those SLA batteries and are 1/4 the weight. Plus there is no acid in them, so they're safe to install in the car where as SLA technically are not.
Have a read up about them, they are pretty good. http://www.shorai.co.nz/ Mine was about $250 or so, but you can get larger and more expensive ones than that.
My old battery was around 14kg and this battery is 762g. I have just bolted it to the firewall rather than relocating it further back as it is so light. To preserve it I'm using a jumper pack also, but this probably isn't required. A couple of race car builders said it's good to only use the battery in the car for running it rather than it getting hit hard by the engine start and having to be charged for the first couple of laps.
Don't laugh, but I'm using one of these Shorai bike batteries
Oh that's disappointing!
That settles it then - no moving parts in sumps if it can be avoided.
Yeah I knew the pedal box was going to be average, so it's not too bad. It was about half the cost of even mid range with everything included and I just can't justify pouring money into those areas. I just wanted the cheapest way to lose the brake booster, ABS etc. I think it was about $700 landed included bias adjust, reservoirs, masters etc
Steering is fine kk, don't stress. I've pedalled it around Hampton Downs for 10 laps and the small amount of play in the steering was the least of my worries.
OH YEAH THE BATTERY! I forgot to mention that, I'll try and get some photo's of it up. I started it for most of the day on the jumper to project the battery, but when loading it on the trailer and into the garage I did a couple of starts off the battery and it started well. I think it's ok, but for absolute peace of mind it would be good to go up to the next size. I'm happy with it.
Pedal box was super shit Markku. The brake pedal bent a little bit (side to side, from heal toe) so I have to reinforce it a bit. I shouldn't have skimped on the lower end, should have gone mid-way but I still think OBP has the potential to be ok. I'd just weld a rod or something on the pedal to fix that. Also balance thing needs to be sorted out as that wasn't twisting very freely.
Steering is sweet, that shaft will never bend it's like 25mm solid steel, even in a vice you'd not get any bend hanging off it. But the steering column is adjustable, so there is some movement in there. When I do a cage I will reinforce it a bit to reduce play, but the adjustability is good for getting out of the car because the steering wheel is in the way of the door a little bit.
No idea on power to weight VG. Factory power is 150bhp at the flywheel, so hopefully a little bit more than that and probably somewhere around 1000kg without driver at the moment. I've only done 2 plastic windows so far and the sunroof is still in, so once I finish that side of things and take a bit more weight out I'll chuck it on a set of scales and see what it weighs.
Oh a update! looks good man, must have been good to get it out on the track.
It was real cool. Need to soften the front suspension a tiny bit and get a bit more travel because it lifts the inside wheel easily. Opening up the exhaust will free up a bit more power too. I think it will actually be quite quick after that, as it feels really well planted on the track and seems to be a good balance of turn in with lack of understeer and a tendency to oversteer a little bit mid corner which is fun.
ky pretty much as spence said, but mainly the cool points. It's fun to pretend I'm driving a proper touring car by sitting real low and as far back as possible. I think it makes a difference though, because the car feels good on the track. Engine out the front is around 150kg and I'm around 180kg (despite what Sheepers may say, the fat cunt), so the further I move my weight back, the more it offsets the heavy motor hanging out the front.
Next stage is now complete, which consists of the following:
- Power steering deletion (done the right way by removing the valve in the rack along with all of the PS gear)
- ABS deletion
- Floor mounted pedal box installation
- Re-run brake lines and 't' them as required
- Fit new seat about 300mm back from original
- Fit steering extension so I can reach steering wheel
- Extend gearshifter so I can reach it
- Replace CV joint
- Replace radiator
- Fit plastic windows
- Cut the shit out of shit
- Drill some holes
- Fit bonnet pins and remove crappy cable
- Remove heaps of loom and other important bits
- Fit tiny battery
- Run new battery cables, kill switch etc
Probably some more stuff, but the photos will remind me.
Playing with things
Steering wheel has some adjustment (see above and below) and is also removable
UJ would be proud
- 8
Cool, 1:27.11 I'm happy for that for a first outing.
Heath where did you get the time for me from? I still haven't seen any results (or times)
I just watched the video of me putting it in 1st gear instead of 3rd (twice). It's a bit painful, and I'm lucky I didn't blow my engine too.
I've done that before at Meremere (but it was 4th at full revs into 3rd rather than 5th). I'm glad you didn't blow your motor, it seemed like quite a carnage filled day out as it was.
Brad - how was the first time in the Opel?
Real good overall. After watching some of those videos (of other cars) I'm surprised at how well planted my car is. I'm going a bit slower, but turn in and grip is really great, I just need to get used to the car and soften the front suspension a little bit to get a bit more mid-corner traction.
What happened to your engine?
7 weeks is a pretty optimistic time frame for a conversion, especially if you don't have everything set to go already.
So keen to see this thing get a decent repower. I do actually have a motor sitting in the garage that is not being used, and people often put them into Escorts in the UK.
Have paid, and booked trailer. Only a couple of things left to do on the car then I can try start it, so looking good at this stage
- 5
Speights is probably better for yarns than BF
editfuckyyoutopofthepage
If my car ever runs again 105, I'll hit you up and we'll go and do a trackday of some sorts. In the weekend was a driver training day, and from what I could see, for only $230 you got a day on the track with some schooling on how to no be a n00b (race driver training), along with a track outing with Paul Radisich sitting beside you - it may have cost more to get the man himself in the car, not certain on that. Pretty good bang for buck though, compared to a standard trackday.
I've been working hard on my car and the list only has about 10 items left on it now. I think it's doable, so going to bust my a*** to get to Hampton. If nothing else pops up I should be there. So excited about getting back out on Hampton Downs!
Done
New seat bolted in. Harnesses relocated. Steering wheel extension and column in. P/S removed, steering rack modified and back in. ABS removed. 2 of 4 new brake lines run. Plates made for new pedal box. Pedal box in. Brake fluid reservoirs mounted. Bonnet pins mounted and cable removed. Windscreen wiper motor relocated and modified to single action. Brake bias adjuster mounted. 2/4 doors cut out and plastic windows added. Fireproof kit and new helmet purchased.To do
Run remaining brake lines. Plumb, flush and bleed brakes. Replace CV joint. Replace radiator. Extend wiring/make spacers to relocate switches. Have custom clutch cable made. Retune/adjust base map to fix fueling issue. If I get time fix some issues like lack of brakes and replace an engine mount or 2. -
As I said, not a full noise video, but still cool to see and hear the car out on track.
You might as well chuck them up Richie, otherwise I will be forced to inflict my iPhone 3 photography on the world.
I have a real shit video that I have been struggling with all night to try get tidied up and onto the interweb. Will see how it is tomorrow and chuck it up. The car was having issues and only managed a couple of slow laps, so no full noise clips unfortunately.
That was the whole point - I for some reason thought the 350Z had a rear transaxle, which is why I suggested it.The sweet, sweet rear transaxle should have been the biggest part to notice.
Anyway, it wouldn't work so I retract my suggestion.
Innovate LC-1 wideband sensor clearance sale
in General Car Chat
Sweet! Cheers for the link, I think I'll grab one tonight.
I'd also like to know what advantages the LC-2 has over the 1, but at the end of the day I'm a cheap arse and I've never heard a bad thing about the LC-1, so I'm sure it would be more than enough for me.
Then I'll just need to hire a YOWZER!!! or similar and pay him BEER!!! in return for tuning while I drive.
