jack the frount up so both wheels are off the ground
get under the middle of the ute and you will see a threaded bolt with 2nuts on it, undo the first nut and take it off then wind the second one down till u get the desired height . measure how far you go down from the tip of the bolt to the first nut then repeat process for the other side to the same length. make sure you put the lock nuts back on .
