4AG_Addict
Posts posted by 4AG_Addict
  1. in need of a quick answer...
    i dont have much time at the moment to read all this...
    ive been offered a sweet little project but its deregd..
    its a 72 datto..
    what do i need to do to get it on the rd and what will it cost?
    oh and do you get a cert before or after?
    cheers
    Take it through for the Re-Vin process first, they will assign your vehicle with a Vin number, Pass or Fail.
    They will then proceed to fail your car on needing Modifications Certified.
    Then you can take the car for a cert. Your cert plate needs to have a Vin number aligned with it, not neccessarily a Rego number.
    Once you have the cert plate you can finish the Re-Vin Inspection process & apply for registration.
  2. AE85 or AE70 is A series K50, all the internals are interchangable with K series K50. When i destroyed 2nd in one of my AE85s, i scored a freebie K40 from KP60 & swapped the damaged bits over
    So did this transform your K50 into a 4 speed or were you able to retain 5th? I've heard elsewhere you could rebuild A-series K40/50's with parts from K-series ones, it's nice to have this confirmed :)
    No K50 was still a K50, I just removed the damaged 2nd gear off the mainshaft the K50 & replaced with the gear from the K40. Was pretty simple really
  3. AE85 or AE70 is A series K50, all the internals are interchangable with K series K50. When i destroyed 2nd in one of my AE85s, i scored a freebie K40 from KP60 & swapped the damaged bits over
  4. There was a wrecker down Oamaru, Autoland Dismantlers, they had a couple of RT84's. Could be worth a look for parts, altough it was a couple of years ago that I was last there.
    Seems like the 6R is one of the harder to find motors around, I didn't have much luck when i was looking for a spare, turned up plenty of 12R bits
  5. KE70 Wagon Shocks for the rear, in the front you can use 4WD Carib front inserts (can't think of chassis right now), same body size, but 30mm shorter stroke. Or if you want to put a spacer in shock tube, then ST185 GT4 Inserts or AE92 Levin are much shorter.
    Photo below is all captive with 3 or 3&1/2 coils removed all round, ke70 rear shock, carib front
  6. It will be Toughened glass then, which yeah you can't drill it will just explode if you try.
    Is the window flat? if so just draw round it onto a bit of cardboard and mark where you want the holes (you will need to be pretty dead on) and take it to pretty much any glass place and they can send that cardboard pattern off to get toughened so you'll end up with a nice new window with the holes you want and it will have required safety stamps on it for the wof man
    Its legal for us to cut holes in vans and put windows in so i don't see why you can do the reverse of that
  7. Nah it sounds like the shocks are at the maximum extension and are preloading the springs making the ride very hard. When the car hits every bump the shocks max out steel on steel causing the harsh bang.
    Yep you're right on the money there, i put the shocks in it, they're DX wagon shocks & are about 100mm shorter than what standard starlet shocks are. Was real mint when i had it on cutties, but i believe it now has standard springs back in it, & because thy're too long for the shocks they're basically holding them at full extension constantly
    Put it back on cutties, they were all captive with those shocks, looked way better too
