Posts posted by 4AG_Addict
I can't see your pics but a guy on ORE has a rolled Navara that he is looking for a good (double cab iirc) shell... might work out for you if you wanna flick the Nav Cab?
Edit: here's his fred: http://www.offroadexpress.co.nz/Forums/ ... 18&t=21378
That's my workmates Navara, he just got another cab for it last week.
He had looked at swapping terrano body onto Nav chassis in the past, remember him saying it wasn't a major, but by no means a straight swap over.
Jealous, always wanted a Mk V.
Went straight to Trademe after looking at your thread, better get off the computer before I do something silly.
What about adding rear camber adjustment? There are kits available for the MA61 celica that you should be able to adapt
Count me in for one Richy
But mainly what I'm after is to identify the boss kit I have that is attached to the steering wheel I got.
Providing a picture of the rear side of it would be a start & also information about any markings or numbers on it, and the size & number of splines.
I've got a Kenwood single CD one you're welcome too, it's from a Jap Import, so uses a band expander, but that's attached to it
Would need a little more info about the vehicle to confirm 100%, (Took a guess at 2001ish Estima) but believe part number should be 42603‑28330
Description is given as 'ORNAMENT SUB-ASSY, WHEEL HUB'
Even the laziest Toyota parts person should be able to do something with that info
Andy the TRD Race springs are not really designed for road use, and will require shorter shocks front & rear to remain captive & also shorter bumpstops.
You used to be able to buy TRD Street springs, they were the right length for standard shocks, and lowered the car about 30mm all around. Also spring rates more suitable for everyday driving. However they now only sell the front springs, the rears are discontinued.
Just cut it down. Or go to Toyota, they're about $3.50 each & should be available overnight from TNZ, lengths are different left & right one is 16mm & other is 18mm, no idea why.
You mean the bolt on the bottom? Any fasteners supply shop should carry them, like EDL or Blacks fasteners. It's a M10, with a fine thread pitch (1.25). Can't remember the exact length, i want to say 20mm, but just match up the one you have.
Edit.
You'll probably find anything local will have a 17mm head instead of the 14mm head on the original bolt.
Not an OS contact, but Bellamy & East on Falsgrave St are normally the best place to head for these in CHCH
No shit, so mine must have been ordered with the two tone blue? Always thought it was weird the first owner of mine lived in Hams but the car came from Timaru.
Mr Ling, what are your plans for your 86's? Are you going to sell one or keep both? (too lazy to read thread)
^ The rules may not apply to the NZ cars? my uncles NZ new one is blue alsoYeah should have said that Silver car/Blue interior is a JDM thing, NZ New cars were all over the place, even seen one with Brown & Tan but in full GT Apex trim, not the brown/red that is most common.
Yeah Andy, just the 2 different grades of Hatch available. You're right about the boot light, it's another good indicator of trim level.
haha, great, How do You know it's a gtv?
Saw the photos on Trademe, has the GTV interior in it, and unlikely the interior has been changed as the 2-Tone blue is rare & usually only came on Silver cars unless especially ordered.
Check your build plate if you want to know for sure, Model code will be AE86-FCMQF. The 'Q' tells you that it is a GTV.
GT Apex ends in FCMVF
Early GTV came with the unpainted bumpers, which were a dark grey colour. Flat Black is close enough & looks really good, also easy to touch up if needed.
Yep, that's right bit too loud for daily, don't know how much they worth tho?
Usually expect to pay around $200 for second hand Japanese brand name extractors.
Please paint/install black bumpers on the Silver Hatch, then fit your Black Volk mesh wheels & lowering springs. Will be awesome.
Yeah better to be safe if you're not confident. How come you're replacing Exhaust Manifold anyways? I thought it had a nice set of Cusco Powerball headers on it? Mitch got them off Reo at Tama if I remember right (only know that because I wanted them & he outbid me)
Andy I know you are a member on AEU86.org so head over there & download the 4AGE 16V manual they have available in PDF. This will detail everything better than I can explain it. You will also need to bridge the diagnostics plug before you reset the base timing.
Maybe it's just your photos, but the wear pattern on the teeth of your crownwheel does not look ideal, a lot of wear on the front edge of the teeth. I would suggest taking your complete diff head to a local diff specialist to be set up correctly, this process will involve removing the pinion, so probably a good opportunity to renew pinion bearings & seal if required. They will also be able to tell you what configuration your diff is set up in (1.5 or 2 way) If I had to guess I would say it is probably the TRD 2-Way, that is the most common setup (The 1.5 way model was discontinued 5 or 6 years back, the 2 Way was available up until 2010)
As for your starting problem, yes you have stuffed the timing. There is a procedure for removing & reinstalling the Dizzy. You need to ensure you have the timing mark on your crank pulley at 0 degress, then remove oil cap on Left cam cover & look for the indent in the camshaft, if you do not see a mark on the camshaft then you need to do another full revoluton on the crank. Then there are two marks on the dizzy itself that you need to line up straight. It can be a bit tricky. It is a lot easier to see everythingif you remove the Exhaust side Cam cover. You will need a timing light to correctly set timing afterwards, that is what the adjustment of the dizzy does, fine tunes the timing.
I go between CHCH & Oamaru quite often, so could pick it up on the way past next time i head down, probably 2 weeks time
fuck man that sucks, was that the only thing they took?
Yeah they were only after the bike. Lucky in some ways, could have been a lot worse.
165R14 tyre options
in General Car Chat
Looks like GT Radial have a non commercial option, called a Champiro T
