Posts posted by AE25
fixed!
apparently can't change a private event to public. lesson learnt.
Yeap. it works well there. Just awaiting confirmation. I'm too busy with life things to organise more.. but maybe an autumn meet if peeps are keen for it.
Heads up. The usual late notice but, this is happening
More details in thread once confirmed.
https://www.facebook.com/events/215537258907263/Date: Sunday 22nd January 2017. 11am - 2pm. (starts thinning out by 1pm usually)
Where: University Ave, Massey Uni Campus, Auckland. lower tier carpark outside 'the ferguson' bar.Cruise meetup points at the usual places Greenlate McD's and Westgate outside ASB 10.15am, depart 10.30ish. Someone in attendance gather those there and make call to depart.
For previous meet galleries and FB posts..
www.jap-olds.nz- 3
great stuff. maraetai beach packs out on a sunny day tho aye.
yup. typically last minute organisation
When: Sunday 22nd Jan 2017
Where.. TBA
ke10 and early ke2 with leaf front spring i believe had a 3 bolt steering knuckle. would be same ball joint as a KP. dont have vented disk tho.
EDit: and they look totally different with ball joint sitting outside of the 3 bolts. So its not corolla knuckles.
1g-eu manual says:
Use API grade SC, SD, SE, SF or better and recommended viscosity oil.
Gives a chart for recommended viscosity vs atmospheric temperture.
mega frozen balls to 10'C use 5W-30. but dont.
-22'C up to 30'C you could use 10-30W.
10W-40, 10W-50 starts at -22'C ish up above 38'C
15W-40, 20W-40, 20W-50 starts at -12'C ish up above 38'C. seems 15W-40 is about the sweet spot for NZ temps.
oil pressure (warm)
at idle speed .. more than 0.3kg/cm2 4.3psi 29kPa
at 3000rpm ... 2.5 - 5.0 kg/cm2 36 - 71psi 245 - 490kPa
says when bleeding lifters, dont pull them apart.
gives leak down test specs.. 20kg takes 2 -7 seconds/1mm after the first 2mm.
I wouldn't say it a big difference in power. less weight in the ae82 so be faster than your ae101. 20v needs the revs to make power. be curious to race a std fxgt! I would've gone blacktop if i had a choice but picked up a complete ae101 for dirt cheap and had the setup sitting there waiting for a chassis.
Its a relatively simple conversion except for wiring which not everyone's cuppa tea.
flat spot... maybe check tps position, map sensor and fpr hoses have no splits, put some injector cleaner in the tank. um, check water temp (green) sensor is plugged in nicely.
admit to having soft spot for ae82's. learnt to drive in dads old fxgt. not much original in the one i have now. 20v ST, using ae92 superlows from memory in a mix/mash ae92/101 brakes n suspensions. rear upper spring cap needs ae92 version to fit coz different diameter.
plenty 82 nutters on ae82.net
yeh nz new didn't have the oxy sensor.
see if you can track down the toyota yellow book for ae82 and the 1983 4age blue manual. heaps of info in them. should be able to download too.
naw, got the hots for david eh!
yeah defo do an autumn meet Ed. It usually has to conflict with another event that time of year tho.
also been suggested to do a premeet and cruise to caffeine n classics. kinda makes sense since they've taken every 4th sunday off the available dates. might have to start a pole on it
wow what a day. prob the biggest turnout we've ever had.
cheers all that went!pro as pics tim chur.
lots of pics up on the FB page too
https://www.facebook.com/events/175110509512814/- 1
even as the OP, i cant edit the original post/title. One for the mods?
merida are good bang for buck eh, especially the XT editions. Didn't like the rear suspension on older models tho (2014).
Massey Uni Albany confirmed. lower tier carpark outside The Ferguson bar (gymnasium building). left at the uni round about and first left into parking area.
Cruise:
If people want to cruise together to the event. The usual spots to meet are 10.15am at Greenlane Mc'D's carpark or westgate shopping center outside the ASB. leaving 10.30am which is dictated on the day by the people in attendance. (Gather yourselves together and make the call).
Cheers
just awaiting confirmation of massey uni parking.
facebook event page added
https://www.facebook.com/events/175110509512814/share share share!
yeh 29ers just roll over everything better aye. my mate on the 29 SJ pulls away if we are rolling side by side down a hill
(without any pumping etc). great for trail rides.29er stumpy won trail bike of year last year me thinks so lots would've been sold just from online reviews. but so many good trail/AM/enduro bikes available these days, we're spoilt for choice if got that much money to burn.
bought my nephew a byk e350 (16" good qual bike) for his bday. he was more excited about a book on minecraft kids these days
yeah good time to buy reverbs at mo! (importing new from UK that is). nz$328-376 delivered from chainreaction http://www.chainreactioncycles.com/nz/en/rockshox-reverb-seatpost/rp-prod84856 or nz$360 delivered from http://www.wiggle.co.nz/rockshox-reverb-remote-dropper-seat-post/
make sure take free shipping option to keep it under $400 otherwise may get pinged by customs for duty.
I'm finding wiggle is usually the best priced online store for parts.
reviews are often saying the fox 36 or BOS deville are better forks for 'enduro' but if price, weight, user friendlyness and servicing are priorities then Pike all the way.
im converting my hardtail to 1x10 from X9 26-39 11-32. Ordered raceface narrow wide direct mount sram 30t from CR and sram 11-36 cassette from wiggle. (I prob should have ordered the aftermarket 11-42 cassette but oh well). Then i'll be swapping all the components over to a NOS Stork Adrenalin carbon 100 travel full suss frame and prob later build the hardtail as a single speed.
Also ordered two maxle skewers after losing the pike maxle and XTR trail clipless pedals which are cheaper online than local priced XT trail, lol.
MTB not cheap when you're constantly upgrading
im a shorty so 29ers feel like riding on cart wheels. A mate rides a 2015 stumpy carbon 29er expert and it's a great do-everything bike, but i prefer the maneoverability of smaller wheels. demo'd an enduro 650b and loved it. demo'd a reign 1 and was great fun but bit too low/slack and downhill/race specific.
nah there's a huge difference in suspension feel in modern forks just by adjusting air pressures, setting sag, adding/removing tokens and tweaking compression/rebound settings. not all forks are created equal so need to tweak em to suit. Compared to the old Recon on my hardtail that only has rebound and a lockout, the new pike can be tweaked in so many ways.
kewl, like a stumpy with 130 travel and steeper head tube. looks like ideal geometry for most of auckland trails. im now on a capra for the steep/rough stuff.
Queenstown sounds awesome! bucket listed
440 are running shuttles on wednesday arvo's.
save the date..
Sunday 17th Jan 2016 (usual same weekend as Kumeu hotrod show)
Place.. TBA (but probably massy uni Auckland again).
I'll post up more details as they happen.
previous meets deets here...
click me- 2
after a couple rides out at maraetai i've now joined up pcbc (have to be member for forestry access). Some sweet trails been made out there. pretty steep terrain using fireroad climbs to get to the downhill trails so legs get a hell workout. But so many bermy jumpy techy flowy trails. and there's shuttle evenings for people that help with their maintenance/building bees. Another mtb mecca being built for auckland woot!
looks like i be at 440 tmrw arfternoon if anyone wants to join in. pm for number. no reception at the park tho. look for the only guy with a hardtail lol.
10th New Year Nostalgic Jap & Oldschool Meet 2017
in Upper North Island Region
1 week to go
