Posts posted by two_days_late
Looks great man, looked at buying it myself How bad is the rust? The guy selling it seemed very sketchy about it.
Couple of examples of whats currently on there. Nothing overly amazing but a couple of them are probably good buying at their prices.
http://www.trademe.co.nz/Browse/Listing.aspx?id=512673672
http://www.trademe.co.nz/Browse/Listing.aspx?id=513311443
http://www.trademe.co.nz/Browse/Listing.aspx?id=510308236
I'd sell it off. You can get really decent daily for $2000.
Check out my tool for finding cheap cars on TradeMe if you like. It's just an extension for Chrome, see awesome bargains on there all the time.
https://docs.google.com/open?id=0B9cqPaEVi9ArZU5idllrcUNmdE0
Cheers
Matt
Hey mate, what did you end up doing for these? I'm also looking at a set of Coilovers and these ones on TradeMe seem like an easy option. Interested to hear if you found something cheaper.
Cheers,
Matt
http://www.trademe.co.nz/Browse/Listing ... =509016147
This would have been good... already had the tunnel etc modified.
I would have spent well over that on my motor I'm building up, you can see a lot of whats been done in my old build thread here:
//oldschool.co.nz/phpbb/viewtopic.php?t=10637
With more updates to follow in new one here:
//oldschool.co.nz/phpbb/viewtopic.php?t=29206
On my cam spec sheet it says this:
- Do not allow engine to run under 2000rpm for the first hour.
- When heavy valve springs are fitted we recommend installing soft springs for the break in period.
- DO NOT IDLE. Slow Idle speeds or continued starter cranking will result in sever Lobe and Follower wear.
Also not looking forward to running in my engine
Thanks mate
Yea its worth trying to figure out, just waiting for mine to show up now.
I'd like to dyno it yea. Will be interesting to see what kinda power it actually does put out compared with the claims you hear about with similar mods. I'll happy if its over 130hp but as long as it goes along nicely then that's the main thing.
I have a single piece driveshaft to suit a 4 speed if you need one mate.
So finally progress is happening again!
Went back up to Gisborne for the rally last weekend and picked my car up from Dannevirke on the way back through.
The panel work is largely finished now, the whole thing has been undersealed as well, including inside the boot. There is a little bit of tidying up to do so I'll get some more underseal and do that when I get around to it. I also haven't done any of the black trim (mirrors/handles/bumpers/window trim) or the rubbers yet. Will do a full rubber kit and black paint at the same time, but for now the focus is getting it moving under its own power.
First step was to order some new bits and get some bits machined, so I have ordered:
- 2x Reconditioned DCOE Webers with linkages and filters, plus an electric fuel pump all jetted and choked etc for my engine from Weber Specialists in Auckland.
- Ashely Extractors from Palmside as it was going to cost me over $200 to get the cobys coated and then they would still just be cobys.
- Honda pre-engaged starter motor with adapter plate for the Sierra box from Palmside.
- 2x Kelpro urethane engine mounts.
- Dropped the gearbox at Cemeck Engineering in Petone to get shortened so I can keep my shifter hole.
- Also dropped the flywheel at Cemeck to get some grooves cut in the teeth to suit the new starter motor.
While I'm waiting for all these bits I've been getting the motor in a position where its ready to drop in the car. I've pulled the cross-member out and plan on bolting the engine and gearbox all together on the floor/trolley and the just lifting up the car and dropping it down on top of it. This means I am far less likely to scratch up my new paint dropping in an engine, and I can muck around with the new starter/clutch/engine backplate on the garage floor where I can see and get to everything easily.
Also needed to modify the engine mount brackets to suit the new style mounts. This involved cutting off the bonded rubber from the mounts (an old one on the left), then drilling a hole in the bracket followed by a spot of paint. Just like new.
Decided it was also a good time to fit the new front pulley kit... and neither of the pulleys fitted.... They were both really close though so just filed back the water pump a tad and now it is snug on there. For the crank pulley I got out the Dremel with a sanding bit and then a polishing bit until I could get it on the crank. Also fitting perfectly now.
That's all for now... hopefully some new bits show up in the next week or so.
Been chatting to the guy at Weber specs in Auckland and its gonna be cheaper for me to get a reconditioned set of DCOE 40's all kitted right for my engine and sell the ones I have, rather than paying to get these ones setup properly. So still side draft Webers
Ah sweet good to know. I've already got my box/clutch/flywheel and am planning on doing this mod to it:
Will post pics and info if it works. Cheers
EDIT: This mod is worth looking at if you want to change shifter position as well.
http://www.lotuselan.net/forums/download/file.php?id=19578&sid=fc76060225b9ce90d980e9d8e883952b
Cheers mate. I get the car back next weekend from my mate who's been doing all the panel work. So next step is dropping in the motor, then getting all the drive train sorted. Don't want to move my shifter back with the 5 speed so next tricky part will be the 5 speed gearbox mod.
Hey mate, they're 15x8's front and rear
Cheers
Looking good bro. I got my stripe kit from the TradeMe guy and it looks great. I'll PM you his email addy
It's a sport bro. Also take a look at your VIN plate, if the engine says L3 then it's the top spec'd engine from factory. Got some info on this site here:
http://www.rsownersclub.co.uk/rsocbb/showthread.php?p=2168145
And to quote:
For example, a 1600 sport (x-flow engine) has L3 as it's engine code L being 1600 and 3 meaning a GT version.
Here's the entire Escort Mk2 engine code breakdown :
G = 1100
J = 1300
L =1600
N = 2000
T = 950 (unusual continental poverty spec Escorts were sold as 950's )
Kent engine :
1 = Low compression
2 = High compression
3 = increased performance (GT version)
Pinto : E
Used to own this bad boy
http://www.burtonpower.com/powergrip-pulley-drive-kit-water-pump-alternator-pinto-ft1054k-17.html
Only 156 pounds if you ship internationally. buy buy buy
Doesn't have a cambelt But yea its a different style drive kit for the front belt (Crankshaft, Alternator, Waterpump), looks similar to gilmers and should make it look a lot nicer. Have also got an electric fan that will be tucked up under the radiator shroud so you won't really see it but means I can ditch the old viscous fan.
http://www.burtonpower.com/water-pump-alternator-drive-kit-15mm-alt-shaft-x-flow-fp225dk.html
They do a kit for the pinto as well.
Parts finally showed up from Burton, they'd basically forgotten the order it seemed. I called after hearing nothing for another 2 weeks and then it was sent the next day, anyway its all here now so stoked.
Parts from Burton
So after well over a month of waiting for my order its finally here. You guys were right, they are really slack at following through but after a few phone calls and emails it finally got shipped off. Was held up mucking around with customs etc for about a week in NZ but that's another story.
Few good bits in here, mainly the Alloy radiator, new single piece drive-shaft for the Sierra box, silicone hose kit, and front drive kit. Plus a bunch of gaskets, side entry dizzy cap, new performance leads, bolts and studs, thermostat, fuel pump blanking plate, engine back-plate, oil cap, electric radiator fan, and a new alternator (from TradeMe) that I can swap my polished housing into.
Good times!
Induction
Two brand new Weber DCOM's (Apparently the replacement for the DCOE) popped up on TradeMe with a manifold for a sweet price so I snapped them up. Already had a manifold that's been matched to the head porting so I now have 2xDHLA Dellorto's and a manifold for sale if anyone's interested.
they make the arse sit quite high off the ground...
Yea back wheels are just sitting there. Will be slightly further under the guard and lower. Front is getting close though.
Mine had these 16's on it when i first got it and they look silly
I now have these 15's and its taken a lot of work to get them looking good, and i'm still not quite there yet
The 16s are for sale though if you are that way inclined
Want Photochops of your car?
in General Car Chat
Any of you PhotoShop ninjas keen to do a shop on this kart to make it all black but with with company's logo on it (inverted so the text is white).
Cheers!
