Posts posted by Ke36
i put that redline mt90 oil in my sr20 g/box hoping it would help, but it didn't change a thing, but the box was probally too worn already, good way to waste $120
yea i tired it in my l200 gearbox hoping it would help my shifting but no luck, i think its more to help shock loading etc and breakages rather than wear/worn parts
i used por15 on my diff housing and my control arms
scoured the fuck out of both and it worked well on my arms but it has chipped off in a few places on the diff like people have said it does
sandblasting should be sweet for it to key into, best ur guna get id say
steps showing how to fit trd lsd to hliux diff plz
just say no
om's look good
id be checking the legality of that copper pipe tho, i thought it was a no go
im a big fan of original colour lenses
but if you cant get mint lenses in orig then new clears will look better than cloudy old original ones
also that pic looks as though its been grey scaled except for the fogs and lenses maybe?
i believe it does or can be fitted with a few mods such as slotting holes
head over to austarion.com and have a look round there, heaps of info
if find that bubble arched escorts need to be two toned/striped etc to appeal to me in even the slightest (exception to thaT RULE IS THE [iMBOSS] ONE FROM OZ
would Redline be the choice over Penrite competition diff oil then?
I guess I'll hunt for a christchurch distributor for redline and ask them
BNT stock it
but as for them knowing much
yea u shud be able to rotate the core keeping both housings in the same position just may have to mess around with locators
Ok, cheers man, what will happen if its not?
The thing im confused about is if it was rotated 90 degrees to be the same as on a standard RB it would not be coming right out of the bottom of the core either.
Will take pic in a sec to show you what i mean
usually ends up will a build up of oil in the core which in turn bypasses the real oil seal resulting in smokey joe out the exhaust
really want the drain coming right out of the bottom of the core
r100 steelies are 14"
most of the aussie guys use van rims i think or "chasers" which i think came on saabs and are actually 4x109 or something
have a search on ausrotor theres a few topics about it
both 15s
Where the rod steps down after the spline and you need to weld to add material is the same as Hilux axles I think. Is this how they also shorten Hilux axles properly?
Gaz
hilux axles you usually need to get ones far longer than what you need so you can respline them from the larger diameter part
or otherwise you just trim the ends of the spline (still uses original spline)
l200 yoke on a custom driveshaft
all good mate glad its sorted
Its mechanical, the electric switch and circuit is fine, but when it is scewed in to the box and reverse is engaged it doesnt touch the switch, and it is the correct one.
wierd.
you have a mitsi box correct?
check when you take the reverse sender out of the box that there is a small ballbearing in there
its what contacts
they drop out easy as if sumone has taken the switch out at some stage
Whats the deal with running 4 point harnesses for the street? is it legit as long as you have the correct mounting points etc?
I've heard you can get away with them in your car as long as you still keep the factory belt, and use that for road use.
Don't quote me on that though
that sounds like a load of shit. that making the car less safe which just about immediatly means fail . ill check tomorrow in our book .
not sure bout here but think thats the deal in oz
to do with getting out of car quickly etc if fire or in water
sender needs to match gauge so yes needs to be autogauge
I have bellhousing to fit s5 rx7 gearbox to motor. (mitsi box shitty at high rpm shifts)
yea iv found they suck balls too, gbox swap is next on my list aswell
weird my box has been mint so far, probably just jinxed it !
i havent had any issues with mine as far as breaking goes but the two iv had have made me think i was driving a bus
i didnt go but found this footage of the vaughan advanti evo on another site
is the gebbies pass run he won by 4 sec apparently
yea kpr beat ,me too it i reckon the current wheels look hawt
just needs the guard to rim gap sorted
bumpstrips rule, never get rid of them
Macabre's VR4 Lancelot EX
in Project Discussion
wat turbo u guna strap on the side of the new stroker?
