Posts posted by Ke36
nah not talking about the centre bolting to the car i mean bolting the centre to the 4wd outer?
not 6 stud to 4 stud etc, but as in the 30 + or so bolts
most 4wd rims seem to have heaps of bolts holding the centre to the outer but my jap rims have farless than that
are u matching the bolt pattern of the outers to the centres you have zeb or is there a way you can put any centres in there?
i.e weld the outers up and redrill the bolt pattern?
so whats the deal with this?
go some centres that i wouldnt mind swapping into some wider outers ive got my eye on
do you have to fine something with the same bolt pattern for the centre or whats the go?
yea what he said and....
driveshafts depends on what replica rx3 crossmember you use some mount them slightly further back so need a little shortening and also require some massaging of the firewall for the clutch fork/slave rod
if u get the proper xmember then everything fits perfect driveshaft etc and gearstick lines up in the factory hole
use 323 gearbox crossmember with a flat plate as an adaptor to bolt to the s1 gearbox just needs 4 holes in it
s1 rx7 extractors can fit but require a bit of heating and tapping to clear the steering box
rx3/rx7 radiators fit pretty easily,rx7 ones end up having the oil cooler pretty low if you want to mount it under there in the factory location tho,(can al,ways tuck it up behind the grill) theres some cheap alloy rx3 ones i trademe i think which fit better
wiring is pieice of piss for anyone who knows what there doing (not me hahah) think ya only need to change bout 3 or 4 wires
there the same chassis as a rx3 from strut towers forward
wellside rules my face
haha yea the yanks seem to love them, and always seem to back it up with evidence of the toyota 3t engines
to save starting a new thread, what sort of options are there in a 185/xx/15? looking at getting some for some 7s
+1 for new front looking awes
pretty sure hes just using a l200 gearbox zac
ok so wanting to get some steels for my mitsi to get it rolling and maybe widen later for drag rims
closest i can find in a 15 is 66.1 to my 67.1
die grinder? any other less dodge options?
Fitter turner / anyone with a lathe big enough to hold the rim will just machine some out.
yea thats the obvious way, but elite told me not possible( however at the time the steel i had was a much smaller centre bore so there would have been no ring left, not keen on the roughly $50 a wheel it would cost tho
yea cheap sigma steels is the go if i can find some cheap enough, as it doesnt really give me the option of using them for drag rims later
yea 14s min due to brakes but i really need to go bigger
ground clearance and minimum room upfront plus the new stretching rules etc mean anything small is going to look tryhard
im thinking maybe something like this hahah
with the coilovers and getting camber plates hoping maybe squeeze a 7.5 up front but my 7s were pretty flush
sweet guys
yea im figuring i was lucky and the engine stalled before the cam gear broke off
ill let ya no if i find anything else when i check
ok so im slowly getting back into this
have picked up an new shell and starting to switch some stuff in and the old one is probly the size of a box of beers now
im after some help on colour and wheel choice
im swaying towards red or white at the moment, more so red, just the brightest flatest one
was going to paint my old wheels white but they seem rather bent, so may not be economical to use them so after other ideas, bearing in mind anything wider than a 7 isnt going to fit under the front really
im open to any ideas
o and if anyone is after ex parts ask, mainly suspension and interior
ok cheers ill check that too
is it possible even if things look ok there still stuffed?
ok so wen my car went upside down it snapped the cam gear off so i was worried about the valves getting all bent outta shape, its a 4g63t so is an interferance motor
have taken the head off and there appears to be no visible witness marks on either the valves or the pistons
have also rotated the cams over checking each cylinder individually by shining a torch down the ports and there is no light "leakage" from any of the valves
is it safe to say i got really lucky and no valves got damaged?
or do i need to get more indepth testing done?
aaahhhhh, so , it's quieter with less plates, as long as you have the END PLATE on there.
that's the bit I was struggling with. i was like, how can it be quiet with nothing on there. but I didn't factor in the end plate.
yea always have to have the end plate
the end of them is flared so more plates spaces the rear plate (as opposed to the discs) further back allow effectively making the end opening to be larger as well as allowing gas to escaped between the plates , the less plates you have in there the closer down the end plate is and thus the narrower the exit of the exhuast is
further more, why does it have to be a toyota diff? what's wrong with an L200 LSD diff? they're plenty strong too. The ramps in Hilux LSDs are useless anyway, most of them one wheel spin at times
i thought all 6 stud diffs were a prick to use?
thats why you use 5 stud axels from the hiluxs cos otherwise the centre bore is massive, and to turn it down so any sort of wheel fits on you end up with nothing
giz us ur guard mirrors
more plates = mroe backpressure = quieter.
nope, its the other way round
quietest with no plates
and i believe they are illegal now aswell
jap theme wud be nice but definately no on the mk1s
wud end up looking like shallow dish smoothies = an alternative to mods
my comment was to sort this issue
Im going to have to look at the brakes as they still feel faded after 24hrs of not being driven -
flush the brake fluid, its probly boiled and is toast, should sort the brakes
2 peice rims swapping centre into 4wd rims
in Tech Talk
nah was looking at swapping some un welded two pieces into another set of two pieces
