Hi R3spct
What ECU model from Haltech are you using? I have used E11 and now I am using the elite 2500. Prior to this I used Kalmaker with GM ECM as used in VN Holden.
I am not using the internal Map. I have connected by MAP box to an analog input. No trouble codes. This is why I built the MAP box so I can get good vacuum signals.
I would agree the support is not as good as it was. I recall calling haltech Australia from the side of the road when running the E11 many years ago. However my most recent ticket remains unanswered. It may be since Haltech was acquired by Race Winning Brands inc the support enthusiasm has diminished and the forum has disappeared.
kpr said
In most cases with Itb's, just throw away your map sensor and tune in tps vs rpm.
I disagree with this, I am running 45 TWM (Borla 2900 series) and I have a good steady with dynamic range MAP signal this provides the other axis for the BASE table.
