A DOG last won the day on February 12 2019
A DOG had the most liked content!
Local Area
Outside NZ
A DOG's Achievements
Member (2/5)
116
Got the new suspension in over the weekend. Out with the Old The rear was easy enough. Compressing the front strut. I decided to just cut one coil out and I'm glad i did. It lowered it about an inch and still rides really well. The shorter and stiffer Camaro rear shock helped compensate for the cut coil. I used just replacement front strut cartridges. The tie road was beyond gone. Just had rust for lubricant. New control arm going on It lowered the back 1.5 inches and the front about an inch. With how bad all the suspension was the starlet now rides a thousand times better. Before the steering was numb and you couldn't feel the road at all, now it is much more direct. Before when you would go over a bump the suspension would shimmy left and right and it felt like riding on marsh mellows. I feel much more confident and safer now.
Last Snow sliding session before spring hits.
Hey Thanks!! Come spring time I will get the Celica wheels are polished up and shiny again. Awaiting my Milwaukee power tool kit to put in the new suspension.
After many years of working on my vehicles in the street or in gravel I finally got a shop. Some friends and I went in on it together. Lots of space to work with. Here is the little Starlet awaiting the new suspension bits.
That's good to know. I do want an lsd eventually. But finding one I the USA is nearly impossible. If I do get one I will let you know. The rear bumper all though being an eye sore will have to stay for a while. It is a nice resting spot for my bum when at the car meets. All though a nice similar style rally bar would be fitting.
Oh what i would do for a 4KE race cam. To hear this little motor lump would be dreamy. I am truly jealous
I am very happy with finally having a front end back on the Starlet. It looks a lot more like a rally car now. And it is road legal so i can drive it around town. Now that the front end is all together and it has a little sound from the muffler, It is time to get this soggy old suspension taken care of. Parts pile going on next: Replacement Front Control Arms Tie Rod Ends Front Sway Bar Bushings Rubber Strut Tower Tops Replacement Strut Inserts Camaro Rear Shocks Cut the coils a bit and see how she rides. I would love to do all AE86 suspension but I want to see what is possible with the stock suspension. I'm just replacing all the bushings that I can and putting slightly shorter shocks in it. Cut one coil out and see how it rides. It won't be perfect, but it will be far better than what it is now.
- 11 replies
The bumper is all done and turned out fantastic!! Also slapped on this muffler I had sitting around Video of making the bumper, welding the diff and a little exhaust rumble for you!!
Found a great deal on some fenders from Malaysia. Just had to go with it and hope they showed up unharmed to the USA. Threw on the fenders with some ebay fender mirrors. Then painted the headlight surrounds and grill so they match. installed the new front end with some Ebay LED lights. The ebay LED are so darn bright and a million times better than those old H4 lights. SHOP TIME!! After sliding the car around on some snow I realized I need the rear end locked up. It was too hard to predict when the rear end would break loose with the open diff. So I took the little starlet to my friends shop to weld up the rear diff. Locking up the tiny little diff. Now having a custom front bash bar made. Gotta be legal and have a front bumper.
Took the Starlet to my Mechanics shop for the rear brakes and spark plugs. As you can see below the rear brakes were caked with nasty old fluid from leaky cylinders.
So i took the starlet for a spin in the rain. I mounted the 155-80-13 tires on the back and pumped them up to 35psi. Then found a big parking lot and had some fun.
I had seen online that the old Celica/Supra wheels fit perfectly. So after some searching around MT i had a set of them. Man do they look good I may have a problem with rare and cool old school parts. I was digging through local craigslist and found this really cool old 5 star wheels. After getting them home i had to test fit them with the 175/70/15 tires Going to need some flares for sure. Lower the car about 2-3in, add some flares and these would be perfect. I couldn't help myself. I had to stack some drinks.
Now that the 4KE is running time to start making it better. First thing to go was the Air Conditioning. Because we all know its not a race car unless it has AC removed. hahaha. By the way this whole AC package is for sale if anyone wants it. Going to the gas station for the first time to fill it up with fresh gas. all 10 gallons of it. HAhaha First car wash in over ten years
So the Starlet had sat for just over ten years not moving at all. I turned the motor over to make sure it wasn't seized up. It moved so were good to go! The reason it sat for so long was the water pump had froze up. So first thing to replace was the water pump Old Teq vs New pump Next was going through the entire fuel system. It was badly clogged from ten years of sitting. i had to drop the fuel tank and clean the out and return lines. Then got a new fuel pump which wasnt big enough and had to go for a bigger one. I also slapped in a new fuel filter. Next were the injectors which were pretty much falling apart as i took them off the fuel line. After getting the fuel system all redone the car still wouldn't fire up. So i started looking at the other wires and found a couple things. One of the plug wires had a nice chunk taken out of it from a mouse. I'm sure that tasted really good. Then i found the O2 sensor was just barley hanging on. After replacing those things i found the dizzy cap had mold growing inside of it. So got me a new distributor cap from Thailand. The car still wouldn't start up. So last thing to check was the timing. And of course the timing chain tensioner was gone. So replaced that and she finally runs!!!!! Parts list so far Fuel pump redone twice Water pump Injectors Fuel filter Cleaned clogged fuel tank O2 sensor Spark plugs & wires Distributor cap Timing chain tensioner Battery All new fluids Front brake pads
- 11 replies
- 15
