mk2panelvan
New Members-
Local Area
Hawkes Bay
mk2panelvan's Achievements
Member (2/5)
15
Cheers @tortron! Sanding primer/bog/top coat - any brand suggestions?
Hey all, I decided I wanted to repaint my mk2 escort panelvan a few years ago. So I stripped it back to bare metal, bought an air compressor and sprayed it with etch primer from Supercheap Auto. Most of it is etch primered now, and I have put a few layers of primer on one side, that I also got from Supercheap Auto. There is now surface rust on most of the vehicle, so I'm going to have to strip it back again - which I think is good as someone told me that I should never use paint from Supercheap/Repco and to buy some two-part epoxy primer and use that in place of the etch primer. After that to bog any holes, and then put a couple of coats of primer, then the final coat (which I would prefer a professional to do). My questions are: 1. What is the best/quickest way to get the rusted primer layers off? (I used a sanding wheel on a grinder the first time round as there were many layers of old paint). 2. Can anyone recommend a brand of two-part epoxy to use? And bog? I'm based in Napier, Hawke's Bay. 3. If all else fails, does anyone know of someone who specialises in this kind of thing in Hawke's Bay? I contacted a local company who were going to quote to get the job done but they never showed up. Any help would be much appreciated - I'm very keen to get my panelvan on the road again!! Thank you
She's alive!! Got her started up on the weekend. Cheers for all the advice!!! Legends thank you!
- 53 replies
Sweet will give that a go. Thanks @kyteler for taking the time to explain!!
Sweet, will give this a go - can you explain how to do this in more detail though please? Do you still put the battery back in and turn the ignition key from the drivers seat?
Update - the engine is turning over using the crankshaft bolt. I've been putting 50mls of ATF/Acetone mix in about once/twice a week for the last few weeks. When I turn it over it still feels pretty tight, although there is a less tighter spot every now and then. How do I know if it is going to loosen up more? Or should I just go ahead and change the oil/filter now and try start her now?
Can move the engine now using the crankshaft bolt, but its still mostly pretty tight - should I keep putting AFT/Acetone down there until it frees up more? I used to be able to move it round just using the fan.
Cool, will do, thank you!
Ok - thanks heaps for that. Do you know what kind of oil I should buy? What is the difference between Manual Transmission Oil and Auto Transmission fluid - can I use either? And do you know how much to put down each hole? I've sprayed a bit of CRC down there for the moment...
Its a 1981 Mk2 Ford Escort Panelvan. But I got the engine swapped from the original 1300 to a 1600 sport.
Got the spark plugs out. How much of the acetone/ATF mix do I put down each hole? I'm going to change the oil after doing that, then use breaker bar on crank. Is the crank down the right hand side by the wheel?
Yep oil level has gone up. Spark plugs are on pretty tight, haven't managed to get them off yet, been spraying crc around them. Any tips to get these off? Also can't rotate the fan at all.
Its been sitting about 6 years, but I regularly started it to stop it from seizing. Haven't started it in the last year though, got slack! It's been sitting in the garage all of that time though.
Choice, thank you. Will let you know how I go
Will try that ajg193 - thank you! Is WD40 OK?
