Posts posted by doullama
VN spec 3.8, very reliable and adequate power. Intrigued by single-unit diff/shaft/box!
and ended up swapping for a chebby turck, in pretty good nick, RHD and 94k miles. Is 350/th700r4, was LPG at some stage so has been converted to carby. Certainly gets up and marches, sounds the tits too. Also has canopy for camping missions. Will never be mentioned again as not really OS (89) Great leyland support vehicle
- 6
you've come a long way baby, not really happy with my paint-job, bit orange-peely but oh well, better than it was. Reassembly almost complete, just need to install stereo, get rid of fake whitewall things and get a better drivers seatbelt, hunt down front bumper rubber thing + carpet the rear. Put styley brown doorcards on which suit well, along with new weatherstripping. Even has a functioning rear hatch handle, and vastly better rear bumpers. Swapped to a smaller oil filter to eliminate start-up rattle. Really needs its o.g suspension put back in, not a fan of having to crawl over obstacles + I assume the swaybar was removed due to incompatibility with lowness, have a 1 ton one to put on, gotta have that RTS after all. Don't intend to keep this van long, just sick of its bs haha
- 9
I dig the floor extension, do these have the cavity under the floor where rear seats would go to hide stuff in etc?
Cheers, it’s a metallic that goes coppery in the light. If I could only apply it in a fashion that doesn’t appear to be sneezed on then it should look quite good. Always been a fan of brown as an automotive colour haha
Much welding & filling has taken place, and the whole shebang has been given a coat of oil paint + penetrol, left to cure & then given an inaugural coat of urethane in a stylin’ brown, my ancient + cheap gun seems to want to spray orange-peely unless there’s only 50ml of paint in the cup? Rather than get a new gun I think i’ll Roll 50ml at a time haha, after another day of wet sanding of course. Swaps for nice champagne AU, serious
- 27
When my wife wrote off her pristine, low km 05' corolla, I promptly got her a much less pristine, high mileage nissan march. If she stacks that she gets a marina with a missing plug lead, and a higher life insurance premium
- 9
This thing is awesome! How does penetrol handle sun? I always mix it in with oil paint/slosh it around inside panels etc but haven't left it outside on its own
Should put out more KW than factory with the electronic ignition
I'm certainly hoping the end is in sight! very much looking forward to getting the rust work out of the way so i can get back to regular bodging, sheds too full of flammable junk to weld in there and its cold outside! Sure thing, i'll be the sucker lying in the driveway haha distractions most welcome
Have finished making some patches & started welding in the front of hz's lh inner sill tonight, luckily most of the inner is salvageable excepting the very front and a couple of feet of the rear! bit where sill joins firewall was toast but complex, just cleaned it up & gave it a mig-wire rebuild. There is meant to be some sort of support under the a-pillar, it was rusted beyond recognition so may just use some handy bent c-channel I have lying around, couldn't find a relevant patch-panel excuse generic bird-splatter
- 5
Oh hurro original sill, suspect the other side is an oversill also - however will refrain from confirming suspicions.. The RH rear quarter is an over-quarter too. Seriously is it that hard to run a grinder along to cut out the bulk of the rust before slapping a panel over? Even thats rough but this is next level, oversill held in by about 20 poor tacks + bog to taste.. got it started with grinder +nail-puller then just tore it off by hand! Have both inner/outer repro sills, Outer sill will be a pretty easy replace once I cut out the front quarter panel (still waiting on arrival ex aus) Inner sill looks a right bastard, (complete replacement reqd, big suprise) so much spot-welds under low car.. may even just cut it off at spotweld flange, clean it up and spotweld the replacement inner onto that, then cover the mess in por (just got some, never tried it before but not much to lose -soo much surface rust/pitting to cover. Whatever I do cant possibly be worse than what is there I figure. Be "interesting" to see what A-pillar base is like under guard. Have grabbed a bunch of random scrap steel & an old ute tray headboard which will come in handy for replacing the rotten arch support. Still blown away by 70's australian rust-susceptability tbh!
Whipped the LH door off holden to address some rust in bottom of A-pillar, + its poked (so is RH) so not putting that one back on, while I was there thought i'd do some investigative grinding, someone has kindly smashed in the front quarter? with a hammer to "line up" -read leave room for 1" of bog between it and the poorly folded, and now rusted out replacement outer sill. rearmost 8" of inner sill is also shagged. Luckily patch-panels are available for all this, chinese mig's gonna get a hammering! Also found why water was leaking into A-pillar, nowhere near the appropriate amount of sealant around windscreen, so I guess that comes out too.. Swaps for Austin/morris, no rileyz
I have an ancient atlas 215x CB with receiver and would love to grab an aerial and see if it works, any recommendations for new players?
i'll just send em to a spring shop, from what I hear its not overly expensive
Max 80s grossness is my precise aim, was just trawling for pics of such haha. Cheers Clint, will look into sending springs away. I'll pull the blocks out 1st, mayy even be ok standard. Max height is just my spontaneous reaction after fixing ground-impact damage haha
10 minutes ago, cletus said:
you would need a cert for lift shackles.
how much do you want to raise it?
As much as I can get away with couple of inches above standard would be nice. At the moment (lowered) It barely clears my driveway, and hz's are apparently prone to cracking in the control arms when fitted with lowering springs and standard shocks..
I'd just cut the spring-seat off and weld it on underneath (if its legal), failing that, are lift-shackles wof-able?
I'm looking at de-lowering the hz van this week, I'd quite like to raise the rear a little above factory height. Can I simply reverse the existing lowering block assembly to use them as lift-blocks and get a wof? Had a bit of a look in the virm but couldn't find much about lifting. Chur
Recommendations - someone to do a conversion in Auckland area
in General Car Chat
I would expect to budget at least 10k tbh
