Hi guys,
My question is, how do i know the correct cam tdc of 4g63 sohc carb engine? I saw the timing marks on the crank shaft pulley but for the camshaft iam having a hard time looking where would i line up the mark of the camgear. My main problem is I cannot lower down the ignition timing, it is set at 30 deg btdc, i cannot anymore rotate the distributor clockwise since it is the max settin, when i turn it on the opposite side the timing adds up so i know i have a problem with the cam timing.
Your reply would be highly appreciated. Thank you guys.
