Posts posted by Giant
should have expected that
spam for everything diesel related
4 hours ago, Mof said:
Wow really
I get around 500deg just cruising at 110km
The highest I've seen is 750deg
Do not want cracked head.
I have been considering fmic
1kz run hot as hell stock try stay under 700c post turbo manifold temps will be up round 850c to 900c
Time to mass produce them. I have 4 part started ones
Could do the math and work it out
Someone will rock up with a 90's honda cbr250rr and pull 20k rpm
Why did you decide top mount over front mount
How much have you spent getting the barn/house to where it is so far?
Looking sweet
I can't see pick either. I guessing it's a twin charge setup.
The 6bd1t swap has been done before. A guy down south done most of them
So if been a bit slack lately new job moving house and what not so the 60 has just been used as a daily with not much else.
I have decided where this is going.
Swap the 2h anchor out for a 6BD1T(pretty much a Cummins 6bt) intercool and up boost and fuel. Goal is 180whp.160hp flywheel is stock
Re gear the diffs to suit 35s and lock the rear(auto locker) Currently on 32s.
Ute chop is a maybe.
Current state https://imgur.com/a/yxopx
If you go 1kz try find a 1kz-t they are out there.
Imo if your going to the effort of engine swaps I'd put in a td42t. They take a real hiding and no head cracking like a kz
Older trucks putting in some work
On 13/08/2017 at 07:45, GuyWithAviators said:
This one listed yesterday on TM has them though: https://www.trademe.co.nz/1392949145
6.5k is a mean deal on that.
On 12/08/2017 at 14:48, Shakotom said:
Convert to spring over and gain all of the heights
That would be so unstable. Mines rolls like a ship in a storm with only 2 inch of lifts. 6-8 would be nasty.
As for rust check the between the seats and doors there is s spot that traps water. Have to lift the carpet.
Also forgot to post this.
New radiator https://imgur.com/gallery/OTI2H
Rebuliding the front brake calipers
Went pretty smooth
Brake rebuild https://imgur.com/gallery/ehXHx
Still hunting doors
Today's progress.
Went father into the hub. Swivel seals,bearings and bronze bushes are getting replaced slowly ready for a diff lock.
Only have to open it once this way.
Don't have a lot of picks was covered in shit all day
More hub stuff https://imgur.com/gallery/oIdK9
diesel spam
in Tech Talk
has anyone here run water meth in a diesel?
