johntezza
New Members
    Outside NZ
johntezza's Achievements
Newbie
Newbie (1/5)
0
  1. Correct kyteler I'm Irish. Was put onto this product by a Facebook group called 1uzfe swap parts UK. My main issue with this set up is I have been told it takes the hardship out of wiring and comes with a more then adequate base map while getting rid of the security feature. This all sounds to good to be true and so simple. Wouldn't everyone use it then???? Want to cover all bases before parting with my money. Its roughly 350 English pounds which is about 500 euro.
  2. Hey everyone. Just wondering who has used Spitronics set up for doing a swap with a 1uzfe vvti engine into a is200. Can get ecu, looms, coil driver ( not sure what this is) this is sequential so have 2x4 way coil drivers. As well as this I would also get a idle controller and crank trigger wheel. Then all I need to get is some relays and go from their. He has informed me this gets me around the security issue with this engine and is fairly straightforward. Is this right or not that simple. I have the manual for wiring off this site so have an idea what is needed. Any info would be great before I pull out the LS engine and hand over a few €€€. Also any extras or things I should look into while I'm getting this.
