Everything posted by rotormotor
Rotormotors' 1990 FC Rx7 Brapta$tical coupe
rotormotor replied to rotormotor's topic in Projects and Build Ups
Thanks for the member who linked me Carclips in Dunners btw. Most helpful. Reason for 4 new housings in pic previously was I bought FC because cheaper, FD are a far better chroming finish and no dumb inlet manifold coolant ports to blank off with 20c pieces..so I bit the bullet and got FD ones, i'm sure hoarded NOS vapour blasted housing in the original boxes be worth lots in a decade or 2 -
Whilst waiting for builder to start the keg build, I been buying a looot of parts. He started the rotors last week (all new side seals need clearancing x12) then he onto stacking. Bought the 'infini' momo centre cap so many years ago..got the wheel to suit now, Infini was the top spec JDM version of the FC but also badged to the BF mazdas of the day? Mazda OEM, Franklin, Aeroflow,Link,Pac,..try my best to use only kiwi sourced stuff, but the US & AU has supplied a few trinkets that only they do...example is 3D printed gauge holder ontop of the gauges, deletes the ashtray flap which has never been used.. Currently in contact with Vinny fab in chch for some bespoke items further on the build. Anyways, pics of stuff from the bin.. -
Pretty hefty exhaust leak that, my leak was just the gasket after the downpipe. If you after any emission stuff or airpump let me know
Oh, and redid the mounting arm on alternator, that rough cast dags really irked me..great restraint not go further, looks uniform legit unlike my pic. -
Also replaced the EGR emmision plate for the more shaped green bros one...Irked me way too much. Top half of manifold ( 'dynamic chamber' and factory throttle body/greddy intake tube etc) are now surplus to requirements moving on for reasons I will divulge another time..all that frikkn hard work vapour and reassemble/mod throttle body wasted Also a change of direction, twice the fun perhaps? -
Fiiinally builder is free to build my sammie, dropping off irons & housings tomorrow...YUSS Have been furiously scoping out the future parts/bolt ons needed & buying bits n pieces last few weeks and tinkering on modifying bits for the factory items I'm actually keeping and the delooming process for engine bay repaint I'm sure when I get my keg back in one piece I be all focused and pepped up.. Projectlife? -
You onto it fabbing the missing bits. Be mighty fun when sorted and road legals.
Ordering OEM mazda bits today asked if headlight motors still available. Showing obsolete.
SUGGESTIONS/RECOMMENDATIONS FOR VIVA CONVERSION
rotormotor replied to La Viva 71's topic in Project Discussion
Mayyyyte..I have the perfect engine option, fit in there no problems.... -
HumberSS's Datsun 240c coupe of irrationality yarns
rotormotor replied to HumberSS's topic in Project Discussion
Yeah, it so cool what you have got. Look forward to the project. -
Pretty pleased with my hoard of photos on dismantle and lining up plugs with the associated deleted emission crapola, I have removed half of the wiring in the looms leaving the necessaries to remain. Pic of my usage from purchase around 2007 to where it ceases being a daily driver -
FuCkt nats?
Roterek/Omar might have some headlight motors. Prob need the arm, balljoint pivots too? Hopefully the motor plug is still there as it used to run thru the rubber curtained hole with headlight & in my case fog lights plug. Also need the stopper with rubber knob on the back wall. Funnily I just cleared that area out yesterday so have clear pics
Deep Google found it. Fuel pump relay resistor. "It is there to save wear on your fuel pump under cruising/light throttle conditions. Essentially it cuts down the voltage your fuel pump sees when there's not as much demand on it, the theory being that this will help prolong the life of your pump, and may also help with gas mileage. On the S4 TII cars it's located on the passenger side under where the stock airbox resides, just behind the headlight" US obviously. Edit: gas gone, he was surprised how much gas was in there. Cant have had any leaks then cos the belt was removed about 10yrs ago when fit gilmers. -
Just gotta make sure 3x heater hose aftermarket from states ok being LHD..looks so from pics. Also find out if this can be deleted. Relay and resistor behind headlight in engine bay -
Rethinking a few things. Turned down FD housings over FC due to cost. Been playing on my mind a bit cos inside chroming better finish hence longitivity. Lucky my FC ones not notch yet for bridgeport but oniy vapour blasted. So will bag up and put in their boxes for the day that NLA and worth heaps. Also rethink throttle body. SCR has a much better AM flowing product which bolts onto the lower FC intake. So all the bother vapour, modding throttle and expansion pipe for nout now hahaha. Its only money, todays effort pulling out plugs/loom and other deleted AC, emmision and factory turbo bits..happy cos only have coolant lines for engine block and heater core moving on..much nicer, cleaner and no risk of leaks. Boring pics.. old post engine pulled and current look. -
Does it have a manual steering rack or remote electric powersteering pump somewhere? Fantastic choice on the OEM headlamp setup btw.
Nice FC, My teins were a used set from TM HR or something for a grand or something yonks ago. Had to rebuilt a front but I'm looking to replace for BC golds. Got the correct rear lights, are you going to fit the original headlights back on it?
Back in one piece using heatgun to heat the rear casting bearing carrier because bearing was pushed in...heat and rubber mallet done. Allen key to hold in the brushes. Sunlight distorts colour to blue as seen...its actually teal. EDIT: closeup photo seeing the Raggety cast mold dags on the mounting arm is irking me. This bit is pretty much right on top of me motor and visable so I may just dismantle/file/wetsand it smoother and re vapour when i do Diff to settle my OCD.
