Hi all,
I have a 1980 ke30 corolla, it is running a bit rich a d I had suspicions about that choke not been adjusted correctly, after taking the air filter off I found it is a twin barrel carb but only the right hand barrel seems to serve any function, the left hand barrel has two butterflies neither are connected and I can't seem to see where to pull or pull to open the second lower butterfly. The upper butterfly has a lever that has no spring tension and seems to remain shut all the time,
I blocked the right barrel while it was at idle and opened the upper butterfly and it idled as normal I closed the upper butterfly and it died, can someone explain if this is normal or what is needed to connect the left barrel.
Sorry for the mash of writing I'm on a cellphone, I also can't seem to be able to upload any images? Cheers
