Posts posted by MaxPower
Hi can I change the 14” rims to 16” rims Without any worries on a 95 Toyota dyna? It’s got a hubo and cof etc. only gets 90kmph before the engine noise gets to me. Cheers and sorry for new car question.
Just now, RUNAMUCK said:
Can do if need be had a good time that year
Going to be leaving this one standard for anyone concerned. It’s to good condition to butcher cheers.
On 30/05/2020 at 16:08, bigfoot said:
I have a low km auto box if you want one
Pm’d
Has a tranny leak, left axle seal leak, some small areas of rust but nothing major so I would say yes it’s in good condition, put a fridge magnet all over it. Has had power steering fitted, the old lady has owned it since 500km and it’s now 105km the interior is mint as. She’s off to buy a mobility scooter now haha
- 15
brought it for $3250. shame its a auto but money left for modgies, who's got a manual centre console for sale?
Won’t be selling it or buying it to make money I just like buying shitty old mitsis
- 8
Just now, ajg193 said:
How much would you sell it for if you got it off him for 4k?
$500?
Cheers guys, it’s just a person who has taken it to a dealership to get it valued not a dealership selling it, have quite a few old Mitsubishi’s in the shed so have a bit of an idea of where to look etc. hope the guy isn’t too stubborn on trying to fetch top $. It isn’t exactly a desirable vehicle
hi guys i left a note on a old ladys windscreen a couple of years ago and her friend gave me a call today asking me if i would like to buy it this weekend, he said a stealership valued it at $4500-$6500.
its travelled 105,000km. I think I would pay up to $4000 if its factory as wof reg.
gone are the days of buying these for a few hundred for a minter and paining it matt black.
what do you think? cheers
- 5
26 minutes ago, Nominal said:
Any thoughts on Plasma Cutters?
This is on sale for $600 right now
https://www.thetoolshed.co.nz/product/3139-toolshed-plasma-cutter-40-amp
i just brought that same one haven't used it yet but it looks like junk straight out of the box, may return it for the boc one for similar price, the hand piece on the tool shed one looks really chinise and the consumables look rubbish. but the tool shed one does come with a 3? year warranty
1 hour ago, rusty360 said:How did this end up? How deep? Water flow etc?
ended up getting 45,000L roughly a day out of it, haven't got it tested yet but haven't got sick or the shits. the water goes through a decent filter setup down to 1 micron, put a 750w sump pump with float switch down the well to pump to a 35,000L storage tank. so happy been able to sleep better not having to worry about running out of water, kinda wished i had documented it better as more people could build these as its not difficult. if i build a pool i will probably dig it by hand too.
4 hours ago, Thphantum said:
How much?
$1500. or some roofing materials..
29 minutes ago, Boatie said:
Crikey...i have just found online an old advert I put in beaded wheels around 28 years ago
its for sale if interested. have found another vintage vehicle I would rather play around with, have original tags and plates for it, doors need re-wooding, has no motor and box. cheers for looking
found out why my 13bt diesel was cutting out when hitting boost above 15psi, was a little electric valve leaking that sits down by the starter motor, it controls a flap in the intake so that it was cutting airflow off to the engine completely when on song, took me ages to figure out and goes good now. the other issue I'm having is winding the fuel screw in doesn't seem to make any difference? it can be wound right in but doesn't seem to make a difference.
19 hours ago, rusty360 said:What's the water quality like at 6.5m? Are you still digging in clay?
was dirt, pumice, sand , clay, then sand when i hit the water now I'm into pumice\sand where the water is, have dug 500mm today and the flow rate is 20L a minute its been running for about an hr now and is starting to run clear. Will get the water tested but happy just to have water for the animals, garden, spa pool and possibly the toilets if i can be arsed.
spade with the handle cut off, then into a ss bucket hauled up on a rope and pulley. same way to get out just pull myself up on the rope
Are ya still digging in the hole? That must be tricky what's the diameter of the hole. Great work thou!
still digging, 1050 od , 900 id hole thanks
the later vans 88+ had no full chassis but the front end still unbolts if you get what i mean, if your only after the front end\crossmember
1 hour ago, HighLUX said:Thats some sweet primitive engineers Max but 2 questions, how you know where the water table is and how you gunna sort out water ingress once you hit the water table and still have 3 meters to dig?
i divined for the water, used a post hole borer with 1.5m homemade extensions till i hit the water, i will put a submersible sump pump with float switch on it when i hit the water, i will stop digging at about 4m then lower the concrete rings down and keep digging and stacking the rings, if the pump won't keep up then I'm deep enough. the rings will stop the hole collapsing and the rings have been cured for more than two months. thats the plan anyway
the spindles are different on the early stuff compared to the later ones, not much different but different, the vans have a full removable front suspension unit which is probably why they were popular, if using ute spindles on a van front end the brakes end up at the front of the wheel not the rear. rock auto has lots of parts under dodge d50. my advice would be to stay away front the early 80's front ends (small brakes)
cool yes for cert, no to dodgy welding, never looked to see if the other arms would fit just guessed they would be different, thanks for your guys advice.
Jesse's punishing auto shitbox
in Other Projects
i brought one of these off here, its currently getting paddock bashed due to rust and fucked shocks, but its manual so if it ever blows up theres some cheap parts for yours, panels are\were pretty good.
