sr2
Everything posted by sr2
  1. One of Rigamortice’s dirty little secrets was a set of these little shockers hidden behind the front wheels! I found a pair of proper hub-centric spacers on Trademe for a very reasonable price. I then upgraded to some ARP studs at a very unreasonable price. (Talk about charging like a friggin wounded bull!). All torqued up with a snug fit on the hub and wheel. Finally got the front ride height and wheel track just where I want it. Decided the rear needed a tweak, so I backed off the rear U bolts…. …and figured out how much I could safely lower the rear. I ended up using solid bar for the spacers I’m expecting the rear springs to settle with a little use….. Have to say I’m finally happy with the old girls stance.
  2. A while back I spent quite some time making a sleeve to tidy up the gap between the steering column and the steering wheel. Problem was the top bearing just had too much play in it for my liking. When I pulled out the bearing I found it was a piece of pressed sheet metal rubbish that was close to impossible to replace. The solution was a trip to the local bearing supplier and the massive investment of $13.50 (and to think the “ever lovely Mrs. sr2” accuses me of being cheap!). I bought a large piece of mild steel round and chucked it in the Emco. I bored it for a firm fit to the OD of the new bearing. I flipped it over and cut it to size in the bandsaw… I then line bored it to fit the steering Column tube. That’s an end I cut off from an old column; you can see how light the original bearing was. I double checked everything still fitted…… …… and then turned down a piece of scrap water pipe to act as a cover between the bearing and the steering wheel. I then turned it down to the same OD……. …. Took the cover off and turned a taper at the other end…… All set to assemble……. (The tube on the left is just for setting it up). Checked it with the Triumph steering assembly…. …….some plug welding…… A bit of paint………… And I’m back to where I started, (story of my life!) but with no play in the steering wheel. The only thing I don’t like is the cheap, shiny, aftermarket “hotrod” indicator switch. To its credit it works well but looks very out of place - far too new and shiny for Rigamortice’s discerning taste. I’ll keep looking for something old and quirky to replace it with. Any suggestions gratefully accepted… https://oldschool.co.nz/index.php?/topic/49843-sr2%E2%80%99s-1947-vauxhall-%E2%80%9Crigamortice%E2%80%9D-discussion-thread/
  3. With space in the nose cone so tight the only way to wire the headlights and fan was to take the front off for the umpteenth bloody time….grrr….! So much easier to wire on the bench. Found some heavy connectors to make disassembly easier in the future. Love using the old school fabric wrap. I’d bought a big box of connectors off Banggood for a price that was too good to be true…….. … so I wired up the headlights. I refitted the front………. I installed the gorgeous over-priced P700 headlights…. ……..and started blowing fuses whenever I powered them up! After an evening of uttering nasty horrible words and throwing thinly veiled insults at Rigamortice re the marital status of her parents at her time of inception, while going round and round in circles with a variety of test lights, test probes and multi meters - I discovered the f****** “too good to be true” Bangood connectors were………. You guessed it ‘too good to be F****** true’! After a quick trip to Jaycar the following day, I paid through the nose for the right connectors…and we now have head lights. And as an added bonus they even worked in the dark! So I stuck the bonnet on and discovered it didn’t fit…. I loosened it off and started pulling things into line before re-tightening. Finally, it all fits, (sort of).
  4. …………Yes I know I’ve been a slack prick, re: this thread. With final arrival of summer the good ship Aquaholic insisted that I take her and some of my disreputable mates out fishing… (What could possibly go wrong?). It was a hot day, we got thirsty, we drank heavily and we “got fush”…….(as you do). A few days later my brother turned up at the Viaduct in this bloody monstrosity, and the good ship Aquaholic (and a certain part of my anatomy) felt very, very, …. small…….(Sibling rivalry can get complicated!). ….so we headed north. The view from the bridge was cool…… Accommodation wasn’t too shabby…. …. And the lounge was bigger than the one at home… Thankfully there was a bar on board for self medication! Back home I was stricken with a bout of the much feared “home handyman-itis” and I accidentally started rebuilding the front of the house… (Note the cunning accumulation of Brownie points with the “ever lovely Mrs. sr2”). After the above brief hiatus I’m finally back to Rigamortice’s wiring. I’m trying to document as much as I can because my memory is like a sieve. I managed to source some cool old fashioned bullet connectors…. I’m almost finished under the dashboard, getting sick of working upside down. The dip switch still works so I hit it with some contact cleaner and we’ll see how it lasts. I’m running relays on the lights so it won’t be carrying the amps that it used to. I’m using my 70 year old meter just because I can. The horns are all wired up but they sound like two strangled cats, I’ll have to do some research on how to tune them. Circuit breaker in place instead of a fusible link. Mounted the battery earth cut out through the fire wall Repurposed an old offset ring spanner for a battery clamp. Managed to get some life out of the interior light with a new bulb and fresh wiring. Cleaned a ton of crud of the diffuser…. And it works.
  5. Could be a good winter project, any idea on what resistance the windings should be? I've been thinking of buying some flashing LED's for them https://classiccarparts.co.nz/classic-car-led-12v-self-flashing-36mm-semaphore-trafficator-amber-led-slimline-256-12v36flash
  6. Time to take on a job I’ve been dreading somewhat; repairing the damage to Rigamortice’s port side B pillar that was the result of the body falling off my homemade body rotisserie. I used a profile gauge on the good side…….. Converted it to CAD……. Swapped sides…….. …. And it was easy to see how out of shape things were…. After a lot of measuring I cut a section out of the replacement B pillar…. And did the same on the car. I went back to using an old school hacksaw - far more accurate than an angle grinder for me. It popped out with a bit of a bang, obviously under some tension. Started tacking the repair piece in… Checking it with the CAD template…. Still just little tacks, a bit messy but I’m cognisant of avoiding putting too much heat in and distorting things. A quick test fit of the doors and it looks OK. Cut out some 16 gauge zintex strips… Marked out and drilled for plug welds.. Put the reinforcing strips inside the pillar and started welding……. A quick test fit of the doors and nothing has moved….(phew!). A few coats of sandable primer… The obligatory insipid green… Doors finally back on and everything fits.
  7. Now for the fun part, I’ve been looking forward to this…….. I’ve been collecting old (and mostly broken) Lucas Trafficators for a few years now. I gave them all a quick test, the results weren’t promising. I cannibalised a number to get enough parts to build a working pair. Started rewiring and assembling the good bits, learning as I go. Have to say they were a lot fiddlier than I first thought. I just love diving into this old shit; it feels like you’re bridging the knowledge gap - if we guys don’t keep it alive who the hell will? It was also very thirsty work! After more failures than I’ll admit to I eventually ended up being a self-appointed Trafficator expert and more importantly - I ended up with a working pair. So much fun to play with………yes it’s a blokes thing. I left one set up on the home made test bench for a few days in the ‘universally esteemed & revered sr2 man-cave’ for visitors to play with…..and to think the “ever lovely” Mrs sr2 had the audacity to describe Rigamortice, me and my mates as being shallow? https://www.youtube.com/watch?v=xQ67aWH4v4U Fitted up and wired up - if that’s not old school I don’t know what is!
  8. After countless, sleepless nights of painstakingly thorough soul searching and self-analysis, (fuelled by the considerable imbibement of 101 Wild Turkey) I came to the conclusion that for Rigamortice and myself to have any chance of surviving typical Auckland traffic we would need indicators! In 1947 indicators were yet to be invented and trafficators were considered to be state of the art high-tech. Maybe the side lights on the front guards could be converted to indicators with an orange lens or bulb…….? This became my fiendishly cunning justification for Rigamortice and me spending far too much money on a beautiful pair of P700 replica headlamps that had the parking lights built in. I struggled to get anything that resembled either light or life out of the existing sidelights. Same old problems as with the tail light, corroded terminals, dodgy insulation, and almost impossible to strip down while keeping it intact. Yes; sadly 70 years ago when they were new they were junk - Lucas, “the prince of darkness” strikes again! So I found these bulb holders on line…… …and fitted them with orange bulbs. Old vs new….. Luckily the original lenses gave it that elderly, faded, glow! I had a spare pair to use in the rear. I attacked an old Whitworth offset ring spanner with an angle grinder….. …welded the bits onto the bumper irons….. ….. with some fabric wrapped wiring they look the part - and they work!
  9. Working my way through the electrics….. This is all that was left of the original tail light, (i.e. the bloody thing fell off!). I started stripping down the tail light I’d got from the Vauxhall Car Club. Paint stripper, rust kill and paint……… I replaced the clear number plate lens with plastic cut from a welding helmet lens cover. The bulb holders were badly corroded and shorting out. I made the call to upgrade it and made one of these out of a piece of scrap alloy. It fits a modern bulb holder……… And just fits inside the housing. The number plate was a little bashed and battered so I reinforced it a bit. Still looking suitably bashed & battered but it all works!
  10. As I mentioned previously I’d bought a set of modern gauges but didn’t want them in full view. I cut out a piece of zintex that would fit in the port side glove box and drilled some holes in it. Did a dummy fit with the gauges, an override switch and LED for the cooling fan and a high/low switch for the wipers. Welded some mounting tabs on and applied some paint. Fitted the hardware……. And wired it all up. Did a little more wiring in the Port glovebox……….. Glovebox closed……. Glovebox open………
  11. Woops! Just did a quick double check on Google - it's actually a front wiper motor.
  12. Please correct me if I'm wrong but I thought you used voltage drop across a shunt resistor to calculate the amps? (i.e. I'd need to use a volt meter).
  13. Hi mate, the wiper motor was off a Nissan Tilda C11 (2004 to 2011 I think?).
  14. Time to have a go at the dash cluster. I’ve got a spare one and with some luck should be able to make a good one out of the pair. The speedo came apart easily All I did was to carefully clean the mechanism and add some light oil…. Assembled it all carefully…… …. tested it with a drill….. and the bloody thing worked! I knew there was still life in the fuel gauge so I just stripped, cleaned and reassembled. I’m not sure what you do with a 20 amp meter when you’re running a 60 amp alternator…….I’m open to suggestions? Amazingly the clock works; problem is its positive earth. So I made the call that for the time being I’m happy with it being accurate only twice a day and just gave it a good clean. I managed to source the right bulbs for the backlighting but the sockets needed rewiring. Managed to de-solder the tiny contact washers….. Soldered them on to some new wire and assembled them with the old springs underneath. Wired it all up for plug ‘n play. Finally back in the dash, looking good above the ignition/light switch.
  15. I was bench testing Rigamortice’s flash new wiring loom while admiring the cool ignition/headlight switch….. ….everything was looking good when the entire switch assembly blew into pieces in front of me. The locking tabs on the Bakelite body had disintegrated allowing the spring to do one very quick disassembly job! I had a big hunt through my spares and found I had another one. The front was a mess but the main body looked in much better shape. (Sometimes you get lucky). I had to sacrifice an old screwdriver to make an assembly tool. Everything cleaned up well….. And I managed to fit the original ignition barrel. The assembly procedure obviously required six hands …….when I got it wrong the spring blew pieces all over the esteemed sr2 man-cave! Three attempts later I finally managed the job with only two hands, gaff tape, copious shots of Wild Turkey, some nasty horrible expletives, and old-school perseverance. And it even tested OK
  16. I’m at the stage where I need to make a call on the windscreen wiper setup as there is limited room under the dash and the wiring loom needs to clear the moving parts.. The original pre-war system was driven by a Bowden cable that believe it or not was in turn driven from the camshaft. If you think the old vacuum wipers were crazy, matching engine rpm to wiper speed added a whole new dimension to driving in the rain! It had a cool little AC Delco gearbox with a clutch. I toyed briefly with the idea of powering up the Bowden cable with a small electric motor but due to the overall condition of the system I made the call to start from scratch. I’d done an electric conversion in the early 80’s but it was pretty rough (to say the least) and the “Lucas prince of darkness” wiper motor was locked up solid. I found a Nissan rear window wiper motor that was small and compact……. Old vs new……. I modified the output arm to take an 8mm rose joint. \ And once again fired up the CAD… Some bending and welding….. ….and it tucks under the dash well out of the way of the instrument cluster. The alloy wiper pivots were badly corroded……. So I made up some new ones Some more “insipid green” paint………. A bit of mucking around to get the ratio’s right……… One last assembly on the bench……. And it all tucks away, out of sight behind the dash. Not only does it work it even has two speeds! (I’ll just have to hide the switch somewhere).
  17. I managed to source some old style fabric tape and began wrapping the loom. The main earth supply will be bolted to the earth strap bolt as it protrudes through the fire wall under the dash. (I’m running separate earths to the big current draining components. One more testing session and it’s all ready to fit to the car…. Looks messy at this stage…… ….but it fits where it’s intended. Hard to get a good photo of it sitting on the firewall on the passengers side. (I’ve got covers for the main components).
  18. One thing I learnt about wiring years ago is that it always takes a lot longer than you’d think and most importantly liquid self-medication ensures a steady hand on the soldering iron. Started working my way through the circuit diagram making sure I was using the correct length and gauge wire while labelling everything. Making great use of my $15 EBay wire holder when soldering, it’s rubbish quality but works surprisingly well. I’m not a fan of crimping so everything is soldered and covered with glue lined heat shrink. Next step was to power it all up and test with my trusty old Universal Avometer Model 7 Mk2 multi-meter……. Crazy as it sounds the Avometer still works as well as the day it was made (it’s even older than me!) but to be honest my go to tool for car electronics has to be my new Multi-Function Auto Tester, they do everything including powering relays - I can’t recommend them highly enough. Removed a mess of wires, fuses & relays from the wooden jig……… …and mounted it on the freshly painted fuse/relay chassis.
  19. I decided to mount the fuse/relay boxes inside the car against the firewall on the passenger’s side. Made up the usual CAD template…… ….and cut out a piece of zintex. I drew up a schematic diagram, (I’m trying to document everything before the “al-simon’s disease” kicks in). Bent up and tacked on some brackets to mount the hardware…. ….love those riv-nuts. Cut the middle out……. …….and checked everything for fit. Primer applied and hung out to dry. Next step was to make a plywood jig to hold everything and give me access to pre-wire. Plan is to make up the loom and most importantly test all wiring and switch gear before fitting to the car. Time to fire up the soldering iron…
  20. My thought process was to have the light light up only when the fan was actually powered up, .i.e I'd be covered in the event of a relay, fuse or switching failure.
  21. Yes I love the horns, genuine Lucas ("Prince of Darkness") Windtones - they appeal to my passion for totally impractical solutions to problems that never really existed in the first place! Only issue is they currently sound like a pair of cats being slowly strangled, I'll have to do some research on how to set up their contact points and then tune them.
  22. Snap! I've just had an auto-sparky mate point out the same re the fan acting as a generator, shame I didn't have the room to mount it as a puller. I might do a suck it and see on this one, if it is an issue I'll put a big diode on the fan supply after the feed to the light.
  23. You're on to it mate. The fan light is supposed to be on when the fan is running. I should have it connected to pin 30 on the relay, (I've been going bat shit crazy staring at it all for the last few weeks!). Revised version below, the bulb will be a LED so there should be no earth issue.
  24. LOL, gin always makes me highly intelligent, nearly as much as 101 Wild Turkey. You're right there's something funny with the fan on light/override switch setup.
  25. Rigamortice and I are recovering in isolation after a recent bout of retail therapy. Decided the ‘world famous’ sr2 man-cave sound system needed a retro upgrade. Found a cool old 12 channel desk. And a vintage NZ made Jensen 300T power amp. We ditched the Wharfdale PA cabs in favor of column speakers but kept the powered sub.... Bought a set of gauges on line, I’ll just have to find a place to keep them hidden from view but still be available when I need them. Found some cool new old stock push/pull switches…… …and another pair with a big “F” on them…..(don’t tempt me!). This should do for a horn button…. Rather than running a fuseable link on the main power supply I settled on a big, grunty marine circuit breaker. I found a 12 circuit ‘hotrod wiring kit’ for a too good to be true price on line, (yes I bloody know…..). Have to say I was a little disappointed when I discovered that it was wired incorrectly and the instructions were written in a form of “Engrish” that neither Rigamortice nor I could comprehend! The wire and hardware will be handy however. I’m a little wary of running modern amperage through 70 year old switches so I found a box full of relays and fuses that should make things a little safer. Best score of all was this collection of leftovers from a big wiring job. More than enough to wire the old girl up. Time to make a start on the wiring, I don’t think the original diagram will be much help but it sure is cool. I’ve been working on drawing up a circuit diagram (pronounced ‘circulating diaphragm’ after a few Wild Turkeys) for a while. Plan is to have a box of relays to minimise the current through the 70 year old switches while having both control and supply circuits individually fused, possibly a bit overkill but as I always say “it’s always harder to put the smoke back into the wires”! After a number of late nights and a considerable over consumption of Wild Turkey this is hopefully the final version. If anyone from the Oldschool Brains Trust can spot any mistakes or suggest any improvements please let me know. https://oldschool.co.nz/index.php?/topic/49843-sr2%E2%80%99s-1947-vauxhall-%E2%80%9Crigamortice%E2%80%9D-discussion-thread/
