Toddy415
Posts posted by Toddy415
  1. I used one on my Gemini. The kit was from super cheap in imvercargal. It had a suction cup and syringe that you used to pull vacuum on the crack to suck resin into it.
    It got the crack/chip to 95%.. It was still visible. There wasn't enough vacuum to pull the resin properly in..and not enough resin to start again.
    I'd go to the professionals. If you have insurance usually there is a glass cover.
    And its probably cheap for a professional repair.
    Although DIY was fun
    i done the same on old car when i was really tight got the kit from supercheap (was from invers as well lol) i had the same results it wasnt perfect but did fill most of it. Again if you can afford it or have insurance get a pro but if on a budget them kits do sèem to work.
  2. I might have a longer one in the shed i can find it and measure it for you if you want
    EDIT: I had a look but i think i put long one in my car cause the one i found is 40mm long so is probably the same as what you have.
    EDIT 2: lll go measure up the other fitting size as well.
  3. could be worse....... living in Timaru and owning house and 6 acres in the Catlins taht i can't spend enough time at, as there is fuck all work down there to pay bills.regarding your issue, i would ring Carter Strang (strang auto), in wallacetown. he's built plenty of them for race/rally use and should able to point you in the right direction.
    cheers man yea someone whos built a few would be pretty onto it might have to track him down
  4. Hey guys is there anyone in southland that knows how to set up 4age nicely and would wanna give me a hand over the christmas break some time.
    I need help setting up tps maybe trouble shoot a few other things to. I have tried a few times to set it up as per 4age manual and by what i have found on the net but can never get it very good.
    cars a ae82 fxgt
    sick of fiddling with it trying to get it nice any help would be appreciated will sort you out for it.
