MKD
Posts posted by MKD
Decided its time to sell this..sob.
1974 FR50, classic rego, just got it in the mail..40 bucks or so per year.
Will come with 3 months new rego
Located in hastings
Pics to follow tomorrow.
$750
Few bits and stuff with it, ie,
- All original parts that came off it
- haynes shop manual
- spare 6v coil and points
- spare carb jets, plenty to upjet with
Chur
Posting in for sale too.
brown delta cruisers? then you wont have to get new rims haha.
how about a bar end lever?
tidy speedo mount too
the 20-30mm roundslide mikunis are cheap too, a few on TM. the ones that usually come on pit bike engines - most have a filter and manifold with them
The carb on these are intended for fixed rpm I found. Didn't react well to quick throttle changes.
Flatslide!! theyre cheap as chips on aliexpress..20USD etc for a 30mm keihin copy (OSO, PWK etc)
ariel gearbox?? no idea if its a 350
http://www.trademe.co.nz/motors/motorbikes/parts-for-sale/clutch-gearboxes/auction-1098095148.htm
drivetrain-wise, would there be enough room to do something like this?? separate pitbike gearbox running off belt drive to the flywheel/pulley...
http://www.pipeburn.com/home/2013/01/13/brenton-newtons-honda-ct110-bobber.html
fair amount of engineering/winging it to get a good fit, but the separate gearbox could be cool.
otherwise you can get new variators/torque converters on TM - like the TAV2 ones or golf cart ones.
youtubed that engine lol sounds awesome
theres a couple of XL / XR honda engines on TM
otherwise http://stormparts.co.nz/index.php?main_page=product_info&cPath=30_302&products_id=30255 ??
at least that drawing shows the mount locations - measure up your one to match??
Edit - or for a couple hundy more http://www.trademe.co.nz/Browse/Listing.aspx?id=1091468404
if you bought a crate chinese motor could you just make up a blank plate to cover the starter motor opening?
cg125 manual here http://www.carlsalter.com/download.asp?p=1161
try an AG100 tank, i reckon theyre pretty mint
bigger carb time?
i think they can fit up to 3.0x17 - depends on the front guard and suspension height
Pretty pricey but they sound and look so good
apparently is the 6n4-2a-5?? google will tell you. Bout $17
http://www.motozone.co.nz/products/hard-parts/electrical/batterys/aero-batterys/batteries.aspx
itll run without one though probably
Yeah man, if the bore looks good you can get new rings etc for fuck all $$ to freshen it up
http://s.aliexpress.com/UfAnaAvI
There's 60cc kits around for these too.
beat me to it haha
Have I got the right idea about the compression? Just whip the head off and see whats going on?
yeah probably means worn loose-ish rings? hopefully its not all slappy but a rebore is pretty cheap. you can get top end big bore kits for them pretty easy too.
clean the carb first - dunno if theyre points or CDI but check points if it has them. Carb + points will be most of your starting issues sorted
turbo-wise small ones of like a charade / kei car suzuki etc or even a low pressure one off a golf maybe? could try source an actual bike one but theyd be moonbeams
Superchargers could be a cheaper option than messing with EFI etc, lots of cool small aisin ones on TM for 300ish. make the flywheel into a pulley etc?
Old mate at elsberg-tuning.dk does them on honda 50 engines etc
Aliexpress has carbs cheap as chips. chinese dellortos or mikunis etc etc whatever sizer you want. surely chinese carbs cant be tooo bad, theyre simple enough to start with.
You could try 1977 mopeds or treatland etc but shipping sucks arse from US
any updates on this or any of the others? keen. chur
Old'n'Rustys C90 Hog, Side Tracked Project
in Two Wheels
Found you a better engine... In keeping with your theme bikes too. Should fit sweet
http://www.trademe.co.nz/motors/motorbikes/parts-for-sale/complete-engines/auction-1140089998.htm
