Posts posted by _Matt
Made some brackets to mount the valves. For some reason the holes ended up too far out so had to slot them a little.
They're held in with countersunk screws so it's all still flush underneath (not that anyone will be able to see underneath anyway haha).Played around a bit with the location for a while and decided this was the best. Wasn't really enough room for the compressor to fit in between. Will mount a compressor on each side of the bed, just above the exhaust area.
Back to fitting and fixing the rust in the dash now.
Cut out the good/un-butchered section of the dash that some idiot tried fitting a commodore cluster in.
Glad to finally throw this shit out!
Pic for motivation
- 52
+1 on the ecu. Mine did similar so pulled apart the ecu and couldn't see any problems, but decided to try another ecu in it anyway and that fixed it. I think mine would drive alright without the vvt solenoid plugged in, but as soon as it was plugged in again it just wouldn't drive right.
Finished another patch of rust. Hate trying to do them when you can't get in behind with a dolly, makes it difficult.
Made up some strap sort of things to mount the fuel tank.
Spent a lot of time trying to figure out how to mount it and decided that adding another bar between the chassis rails was the best.
The straps pull the tank up against the top brackets, should hopefully hold it in place well enough.Made up a aluminium tray to mount the air tank and compressor in. Being able to draw stuff up in cad, program it, laser cut and use a CNC press-brake is pretty great!
It's pretty tight but fits. Will swap the tank to the back as the tank will look better being visible through those holes than the compressor.
I'm sure I'll paint it black so it's a bit more subtle.
Got the rest of the exhaust tacked together as well. Not sure if I'll change where it exits, because at the moment it sort of comes out between the tailgate and bumper or just leave it as is. I think the whole exhaust has 10-12 u-bends in it now haha.
- 38
6 hours ago, nzed said:
I use one of these and they're amazing. The bigger view is great, especially if you're trying to weld stuff while looking straight down or over the top of something
23 hours ago, KustomKreeps said:
That a Merc in the background?
dude wheres the build thread for that!
Yeah it's one of the Mercs my parents own. Currently just have the two but have also owned another couple over the recent years. That one was imported from America with the roof chopped off and Junior's in Wellington finished it off. Hasn't had much done to it since, Dad wants to start on the Model A Tudor before that one.
Nearly done the transmission tunnel.
This piece of the firewall has always annoyed me by how it isn't symmetrical, so cut it out and fixed that.
Just need to do something with the little hole on either side where the tunnel, floor and firewall meet.
Also built the fuel tank. Drew it up in Solidworks and then lasercut it.
Added a couple of baffles that located and slotted into the top.
Here it's fully welded, will give it a polish or something one day.
The big flange is for the pump, the smaller one is for a sender unit and the small holes are for the return line and breather. I think it's just under 60 litres.
Now to figure out how to mount it.- 40
Done the floor patch, just need to do the bit up the side and then there's a few little patches of rust, where the top of the guards bolt to the cab on both sides and a pin hole in the rear cab corner. That'll hopefully be all the rust in the cab done, then I can start on the transmission tunnel.
- 30
Got the tray and cab back on. Plenty of room for the exhaust to go out between the chassis rails and guards.
The cab was sitting slightly on the driveshaft hoop, so cut a hole and made a patch.
Then cut a big hole in the floor!
- 35
More like "Palmy Yearly meet" hahaha
Longest exhaust build ever! What a stupid idea it was to design it like this haha.
So far has 5 pairs of flanges on each side if you include the ones at the end of the headers. Will have another pair after the diff as well.Got some flexi's and welded them in, as well as the rest of it. Need to put the tray back on now and see where the rest of the exhaust can run out the back.
Made some mounts, after making them incorrectly to start with. Had the rubber hanging under tension where-as it should be compressing, otherwise it would most likely tear the rubber in half.
Also made some gussets for the 4 link brackets since they didn't quite look strong enough. Might make some to tie in the other side as well.
Need to make a start on the fuel tank soon. Any recommendations on an in-tank fuel pump to use? Don't really know much about them, 255LPH should be enough? Tank will be about 220mm deep if that matters.
- 18
2 hours ago, Seedy Al said:
Flexi if you're going to use fairly solid mounts pal. You will regret it later when shit starts cracking.
Sweet as, just bought a couple of AdrenalinR ones. They're probably needed since the exhaust runs very close to some of the crossmembers anyway
Got just a few flanges laser cut.
Got most of the exhaust tacked together. Couldn't pull out the part with the resonators so they're going to need a couple more flanges welded on either side.
Looks so good though!
Will it need any flexi's up the front?
I'm thinking it will be mounted at the front of the resonators and at the back where the shock mounting bar is with some quite stiff rubber mounts.A package finally arrived from America.
New floor panels!
- 24
Went out to buy some resonators, realised how overpriced for how simple they are, so decided to make my own. Rolled up some perforated sheet, wrapped in stainless steel wool and fibreglass strand.
Will probably make another couple to put in behind the diff, which hopefully will make it reasonably quiet.It's a real shame no-one is going to see underneath here once it's done.
- 35
Thank you everyone for all the kind words!! Trying to keep progress happening even though I'm very busy at work.
Done a little bit more. Tried the x-flow underneath but there wasn't really enough room.
Move it back to here and looks pretty good. Can be dropped out from here as well.
Resonators go somewhere around here.
Ran out of stuff to do on the exhaust since I don't have the pipe or flanges yet, so went and filled in some more holes in the floor.
- 20
Finished this patch
Made a start on the exhaust and realised I have a problem with it fitting between the crossmembers. It's going to have to be made of lots of different sections with a heap of flanges, otherwise it won't be able to be removed or fitted. It's fairly tight just to get the x-flow bit in. Might be better if I put the x-flow underneath, so then that whole section to the headers can be one piece and just drop straight down to remove. Only problem with doing that will make the exhaust sit very close to the ground, but should be fine as it won't be as low as the running boards. Will run a resonator on either side in the middle and hopefully those sections can be slid out the back if there's a flange just before the diff kick-up.
Some cars from the Shannon car show today
Got the cab back from sandblasting. Has also been etch primed. They did a very good job of it.
Patch panels for the right hand side floor should be here in the next week or two.
Made up a plate to replace the door hinge captive nuts that were turning.
Plug welded it in.
Pic for thread because these updates aren't that exciting and so I don't forget how cool this will look once it's done.
- 37
Finished off the outer patch, then cut out the rust on the inside and welded in a new piece. Was a very difficult shape to form.
Went to remove the left hand door and got 3 out of the 6 bolts out, but one had a stripped head and the other two's captive nuts started spinning on the inside. Sorted the stripped one by welding another bolt to the head and then undoing that. There was some rust holes on the inner panel so cut it out to gain access to the nuts as well. Ground off their heads and punched them through, so now need to make up a plate with a couple of tapped holes and plug weld it in there.
Pulled off the door strikers and a few other bits so the inside and underneath can get sandblasted this week. Hopefully they stay within my paint-pen lines and not blast any of the outer body!
Back to fixing the lower cab corner rust. Look at that nice 1950's welding!
- 20
Cowl vent patch is now welded in. Welded like crap because it was still a bit rusty and thin in places, but should clean up nicely with some paint. Gonna have to learn how to airbrush patina or something haha.
Started a collection of dashes. Picked up the middle RHD one last weekend from a guy just 5 minutes up the road. Including mine there's now 3 50's Chevy pickup projects within about a 10km radius and that's out in the country haha. Bought the one that's been very badly modified to fit a commodore dash cluster a few years ago, not sure why because it's a hideous thing! At least it's in good condition where the unmodified RHD one isn't, so it's going to get cut up.
Got it sand blasted and primed. The left side is mint, the right side is quite holey but it's fixable.
- 16
Some more rust, this time the cowl vent.
The channel where the rubber seal sits needs to be completely replaced. The other piece that is spot welded underneath just needs a few small holes patched up.Attempted to use a shrinker/stretcher to make up individual pieces but it wouldn't stretch enough for the tight radius.
So then I thought about other ways and decided to try and form it out of one piece. Drew up some cad drawings and got them laser cut.After one hour of smacking it with a hammer.
Came out way better than expected.
Just needed to fold the inside up now. The inner corners required heating as they needed some decent stretching.
The shape and fitment turned out as good as my measuring and cad drawing skills.
- 35
A little more rust fixed. Getting good at it now!
- 15
Matt's 1951 Chevy Pickup - Discussion
in Project Discussion
Thanks!
At home it's the complete opposite actually, just a cheap non-branded single phase welder, ain't the greatest for heavier stuff. Otherwise the ones I have at work are big 3 phase Lincoln ones
