mccrazy13
New Members
Everything posted by mccrazy13
  1. Whats up, Its been ages since ive updated this so though I might put a few recent pics up and a quick little catch up blurb. Also me and my mates started a facebook page for Acacia Customs so check it out, like it and watch it unfold hahahaha http://www.facebook....ustomsSpeedShop Have been driving the shit out of RAT040!!! pretty much daily driven to work and back and anywhere i need to go unless the B1800 ute is needed. Have now fully patina'd the whole car,added some web pin striping, some more acacia customs stickers and added sounds. Made new glove box from old number plates to house head unit, 2 6x9s in parcel tray and 6" in the dash and tweeters there also. Been through a few sets of tires and now have fresh white and red wall tyres. Still running 13" standards. Car is mod plated removed lowering blocks and had new leafs made with tramp bars. RAT040 is coming out of rego end of this month and I have plans to carry out some pretty extreme modifications and add some more rad shit. Been thinking what I can do to improve handling which isnt going to cost to much and hasnt been done before. Also interior upgrade and definitely staying rat rod style, all going well RAT040 will be something completely different from anything done before and should be able to get it back on the road pretty quickly. Interior: 4 x bomber style seats with 50 cal ammo boxes between seats for drink holders/armrests/storage. Ive searched and search to find bomber seats forsale which they arnt in Aus and if they are they are super pricey. So i have made my own seats, They are profile cut from 3mm ally then folded and a small amount of tigweld to stick the seat base corners together. sides are sections riveted together with plennty of rivets, brass ones to add radness. I have all 4 seats but only one fully together but with only a couple rivets so i could see final product. Currently have drilled all holes and just need to assembly them all and get railts to mount them. Roof is going to get chopped off and lowered a couple inches and welded back on. Jaguar independent rear suspension and cradle going in. Customer front suspension set up, still unsure what way to go, possibly chop complete front off and make tube frame front and weld front gaurds, bonnet, grill section all together and make it a flip front!!!!! I'm thinking this is the way to go. Also line lock kit will be fitted and other cool shit!!! Also will be rebuilding engine and giving a massive port job, upgrading gearbox to FC series 5 RX7 turbo box. Few pics of RAT040 @ Greazefest and other newer pics
  2. Discuss //oldschool.co.nz/index.php?/topic/37176-mccrazys-13b-rt40-corona/ Whats up, Thought I would throw up a few pics and a story about my 1969 toyota corona RT40. Ok so I scored the car for $550 off Ebay over here in Brisbane, picked the car up from Goldcoast. First I did all the rust repairs, ball joints and suspension. Then de-loomed the engine bay while it was running the 1.5L rat port power plant. Then scored an 18RG set up which went in for 2 months but the RG just didnt cut the mustard so out it cam and in went a 13B 6 port engine from a series 4 RX7 with 51mm IDA weber. The mazda power plant is far better than the RG, front end was to heavy with the boat anchor RG. With the 13B conversion it needed a lot more cutting to make fit. custom transmission tunnel and also notching of the front crossmember. Reversed sump and a custom pick up made The set up is: 1988 13B 6 port with aux port inserts removed 51mm IDA Series 2 RX7 electronic dizzy Gilmer drive EL falcon alternator Goss fuel pump Holley reg 3/8 fuel lines 2" extractors into 2 3/4" through 2 mufflers Series 1 RX7 gearbox Custom 3" drive shaft Standard RT40 diff welded up - still deciding what diff set up to run
