Posts posted by mk2marty
Definitely try Zebra. Both Mk5s were fairly complete last time I was there. They were V6s too... There was a beige Mk5 at Pickapart a month or two ago, but it's probably scaffolding in China by now.
Start a build thread for the Cortina, always keen to see more Mk5s around the place.
Spotted this tidy-looking HR sedan in a carpark on Albert St in the city. So awesome.
6
I need a MK5 Cortina wagon with a hot Pinto
This.
Looks like a really neat place to stay as well, and that teardrop trailer is so cool.
Top work man
+1 for starting threads for all the others..
Was neat seeing this in the flesh today too
This is awesome. Looks like a decent conversion too
4
I'm running this setup at the moment:
Twin compressor/twin trumpet system. Has a pretty deep tone, so I added a high tone trumpet as well later on. Loud as fuck, and barely any delay in getting air pressure
Failing that, a decent lo/hi tone clamshell setup seems to work well
Can't match the big events of the previous few updates, but i've been making small improvements to it
Got another L/F guard and windscreen from a Mk5 at Pickapart. Some moran that owned the car prior to me has attacked the screen with really harsh grit sandpaper in an attempt to remove the bit of black paint where the interior mirror mounts, so the new one will find it's way into the car in due course.
Not long after this, the GCs at Zebra Manukau got a Mk5 2.3 Ghia in at their yard, so I had to visit and grab some high-spec goodies from it.
Ended up with a glovebox light, clock, interior light and spotlight grill, and an intermittent wiper relay and switchgear, since Ford neglected to fit mine with one.
The clock in it got really loud and then it died, so I bought another one. It didn't go either, but since I now had two of them I figured i could fuck with one, so I pulled it apart, filled it full of CRC (because I couldn't see anything else wrong with it), and now it works. Guess all it wanted was lubrication..?
Did the same to the other one, and I now have two working clocks. Go figure.
I put the one from Zebra in, since it was nicer. Installed another (working, at least for now) electric aerial
Fitted the spare guard, or what has turned out to be dangerously close to a 'feature panel' as Honda fanboys call them. To avoid the associated stigma of having such a panel i'll probably get it painted to match the rest of the car once the panelshops reopen after new years.
It looks like this now:
I'll probably put the left mirror on the new guard at some point. Shame the lower valance still looks like a cheesegrater though...
It's a bit hard to see in the photo, but note the crappy (even by Cortina standards) panel fitment around the door line, rust/bog/dents, crap paint, and wonky wheelarch profile, legacy of the frontal this car probably had in the past
It looked worse in person, believe me.
Got some mudflaps with blingin' chrome bits on them, so they went on too.
Big thanks to Ben (Zebra Dude) as well for donating me some taillight lenses.
Also, found some ancient Trademe photos of when it was all standard and mint and old folks spec.
Awww..
Might try find it another monsoon shield now...
Tell me to keep the rat-look panel here: //oldschool.co.nz/index.php?/topic/41622-mk2martys-83-cortina-estate/
Maaayte
(Its not a KE30, but you get the idea).
Get some Turbos. Greatest wheels ever
Sorry, someone had to...
If all else fails talk to Murray at Weber Specialties. He's a GC and knows what he's talking about. In fact he could probably sell you a carb to go with Rookie's manifold.
Type 9 5 speed?
Loving the colour scheme on this by the way
Some photomagraphs and stuff
So pleased someone else finally brought another Mk5 along
Really just echoing the sentiments of everyone else here, but what a simply awesome day.
Cheers to all involved, especially BDA780 for organising it and making it possible, met some cool people and saw some amazing things.
I was too busy walking around in awe of everything to take many photos, so here's one:
So the rear axle overhaul I promised this thing more than six months ago has finally happened.
The collapsible pinion spacer arrived from Palmside, so i really had no more excuses to procrastinate over it.
Decided that the bearing noises had to go, so the best way to get rid of them was to replace all the bearings, so hopefully i'll never have to have it apart again (unless I win Lotto and decide it needs an LSD). So that meant getting axle bearings, diff side bearings, pinion bearings, a pinion seal, and the aforementioned spacer. It all came apart fairly easily, and for a couple of weeks while I waited for bearings to arrive it looked like this:
All bare and oily-like. Hmmm.
While waiting for some side bearings to turn up, it seemed like a good idea to take advantage of the axles being out of the car to replace the brake shoes, in an attempt to cure a slight rear brake imbalance that VTNZ reckoned was there. So now it has some nice new brake shoes (the wheel cylinders I replaced about 6 months ago), and not long after they were fitted a box of very expensive goodies turned up:
Dad pressed the bearings on, and with his help it started coming together. The pinion went in and got torqued up to set the bearing preload and crush the spacer, the pinion flange needing a bit of a squeeze with the vice to get the dirt deflector to stop fouling the pinion seal (which was a different design to the OEM Ford one). The crownwheel and diff carrier were next in:
Shiny new bearings. Turns out that the crownwheel side bearing was probably the worst and probably caused most of the noise.
Did up the bearing caps and tested the backlash, which was within what Ford reckoned it should be. Just as well, cos otherwise it would have meant finding shims and running the risk of damaging the bearings pressing them on and off while we got the amount of shims right.
Note the special blank-face dial test indicator...
The diff hat also got in the way of some chrome paint. I actually kinda like it, it turned out better than I thought it would:
The axles went in, a gasket was cut for the hat, the diff got filled up with oil and all was well. Really impressed with the difference (ha, geddit?) it's made to the car, it is a lot quieter to drive, and I no longer have to worry that if I take it on long journeys the diff will implode. Win!
While all this was happening, the centric rings turned up and they got fitted too, which helped get rid of some of the vibration at motorway speeds, something the slotted wheels and shank nuts weren't that great at. All they need now are some centrecaps.
Scored another 4 channel AWA Clarion tapedeck from a wrecked Daihatsu Mira, which solves the in-car entertainment problem for the moment, until I get sick of the fact it won't actually play tapes and pull it out again. This one is a 450M, the little brother to the deck I had previously (a 650P), which as far as I can tell was only really fitted to high-spec mid-80s Mitsubishis.
Found a centre console with a clock as well, which it needed since I replaced the instrument cluster for one with a tacho (the clock having formerly resided in the centre of the cluster), and a lower console/gear lever surround as well, which tidies things up a bit.
And so to celebrate, I took it for a blast up the Kaipara Coast for labour weekend. It went like a train, aside from the exhaust getting hot and hitting the underbody in a couple of places. Achieved about 33 miles per gallon for the trip too, which was cool. Really pleased with how it handles the open road.
Can't even tell it's been up a long gravel road in this one
Discuss: //oldschool.co.nz/index.php?/topic/41622-mk2martys-83-cortina-estate/
4
It's looking brilliant so far, looks like just the right shade of Brigade Red too.
Nice work man
Cheers mate, if i'm honest the mirrors don't really do a lot. It lives under a car cover, so they get bumped every time I take the cover off, so usually I get a close-up view of the ground. But yeah, i reckon they look better than the OEM ones haha.
Had this thing a year now. Scary.
So I got donated a Springalex steering wheel by my Grandad. According to advertising bumf from the 70s it's an SA100 wheel, if that means anything. It used to reside in his HA Viva, but since he sold it nearly twenty years ago it's been sitting in his garage. I had been looking at changing the steering wheel for a while so the Springalex was perfect, it's suitably retro, and it looks cool.
It didn't fit the car however, so I needed to find a bosskit to suit it, and while eBay had listings for Escorts, there were none for Cortinas. But, thankfully Ford parts lego logic prevailed again, and it turns out that a Mk2 Escort has the same steering column shaft diameter and spline as a Cortina (only the column length differs due to the Cortina's collapsible section), and after trying the wheel from Dad's car to prove it, I decided an Escort bosskit would work. So about a week later, this arrived in the letterbox:
Unfortunately, due to the differences in column length, it needed a bit of modification. It wouldn't fit with the column shroud as the cylindrical bit on the back of the boss was too deep, and consequently the wheel sat too far forward to engage the splines on the shaft properly. This was easily rectified, however:
Cheers to Grandad for the use of his Myford, too.
Great success! It fits, and it looks pretty decent too. Makes twisty roads way more fun than with the factory wheel, which given that it's about two inches smaller isn't surprising.
Very happy with it.
On another, slightly sadder note it seems the awesome Clarion tapedeck has passed on. Bereft of life, it rests in peace, so the Sanyo has stepped up to take it's place, and teamed with a junk equaliser it fulfills it's role as a means of playing cassettes. It'll do until I can find another proper 4-channel cassette deck at a wrecking yard, anyway.
I still haven't done anything about the rear axle noise, but at least it doesn't seem to be getting any worse. Seems like Palmside are the only place in this country that has listings for an Atlas axle collapsible pinion spacer, so with any luck there might be one finding it's way here soonish, so i can finally pull the back end apart and find some bearings for it. Really want to get them done before the Leadfoot cruise.
And, buoyed by the success of the eBay bosskit experience, i've found some hub-centering rings that might fit, and hopefully they'll be downloading themselves into my letterbox shortly.
Cheers to Gizahoon for ordering the parts.
Discuss it here: //oldschool.co.nz/index.php?/topic/41622-mk2martys-83-cortina-estate/
7
Yeah, I wasn't all that serious with the last one.
I knew the one at the front was up to something. It looked a bit shifty. Damn ducks.
And yeah, there's plenty of scope here.
An amusingly named road/those modified bump signs/someone doing snakies next to a 'slippery when wet' sign etc...
Anything really
Righto.
How about a photo of your ride next to an amusing road sign? Has that been done already?
3
Thread dredge.
A picture of my car and some ducks.
Next challenge?
5
This sounds brilliant. Shall be attending also, likely in a Cortina.
Should be along as usual in the Cortina. Hope the weather stays clear
BTW do we not get the $1 Spud fries anymore? Although a free drink sounds good..
Pretty sure this was the one that belonged to the guy who busked outside the New Lynn train station. Used to see it there quite often.
And those RS 4-spokes look good already..
Cortina 1.6/2.0L dipstick length
in General Car Chat
Mine was 410mm, if that helps
measured like this:
Chur.
