mo999
Posts posted by mo999
  1. One more of the engine in
    26382834152_c599426464_b.jpgcars021
    At this stage I got the Fordson out, took the motor and box back out and welded up the rest of the underside. I have also started on the framing for the firewall and the rear of the body.
    You can also see the centre mounted tramp rod I added to the diff to stop the leaf springs winding up under power - but still allowing for plenty of travel on the rough stuff. Also to be seen is the mount for the Steering Rack.
    25872314843_aba68709e0_b.jpgcars079
    25870271314_d0f25c1aeb_b.jpgcars080
    The framing of the body is just 1/2 inch galv water pipe, hand bent around a from. I love the smell of galv burning off when welding!
    BTW the car is not a Justy.
    • Like 5
  2. By this time I had mounted the steering rack - complete with welded tie rods (no certs needed here :-))
    Time to test fit the motor and box - just hook it up to the front-end loader and drop it in - I just needed to straighten out the inner chassis rails and in it went.
    25872315303_433dfcb848_b.jpg6 17-04-2016 3-53-00 PM
    Built a rear crossmember support and bolted in the OG Holden one - job done
    25872315153_241b5d4b55_b.jpgcars020
    26202288410_69565f647a_b.jpgcars022
    10 Points for an ID on my car in the background?
  3. Following the successful design of one my cousin built. I started on a new creation.
    It involved the chassis from one of these 12247770206_7c883d3e9e_n.jpgThames van by David, on Flickr
    and a V8 of some sort
    So I got a chassis 26449227096_8d0516b5ed_n.jpg5 17-04-2016 5-59-18 PM 26382834772_73158c5b9f_n.jpg4 17-04-2016 3-52-51 PM
    As these vans are forward control, I cut about 2 feet off the front - and converted it to rack and pinion (thanks to an Avenger) you can see the rack  ready in these pictures. Also at about this time I got these wheels and tyres for $50 from the McLeans Island Swapmeet - these vans are standard Ford 5 stud, stud pattern.
    I also got a Bedford diff (more on that later) which very nearly fitted the springs.
    26449226866_9d3a67d624.jpg7 17-04-2016 3-52-55 PM
    • Like 7
  4. Well its been 4 months and no progress - life gets in the way!
    Got a few hours this weekend and did this.
    Tacked the new inner sill in
    24917675313_ef6d9b5f5c_c.jpgIMG_6576
    Over the break did another order to Germany and got these new inner wheel arches, at about 15 euro each I couldn't pass them up
     25518252126_4fd54f4e90_c.jpgIMG_6578
    Decided if was better to just use it for a repair section - a lot less work then unpicking the whole thing.
    25544382565_75b8ca2c35_c.jpgIMG_6580
    Ready to stick in - tacked up the top join but the original steel is so very thin I need to get some .6mm wire for the MIG before I go much further.
    24913865354_651825a0d8_c.jpgIMAG0698
    But at least some progress. It will be another month before I get another chance now  :(
    • Like 7
  5. There is not much that can go wrong with these gearboxes that can completely remove drive with out it making a lot of horrible noises!
    Does it feel like its going into gear at all?
    Are both the drive-shafts connected to each side of the gearbox? (look down the back of the engine with a torch)
    Unfortunately unless it's a completely worn out clutch plate (possible!) you are in for engine removal to fix anything else.
    How is the rust in the body?
