chriscross
Posts posted by chriscross
or do what aus doz? but yeah i think keep it how it is, it works fine and its alot safer on the roads, and its a piece of mind for you knowing your car is checked to make sure it safe for you and your kids every 6 mounths!
bug eye 2dr hatch's are getting harder and harder to find, just sucks! be keeping an eye out on trade me for sure.
its on facebook its getting big now! hopfuly something pops up!
lol haha i just painted that pink v,w at work for insurance job lol! its candy colour to!
last time i got my t50 rebuilt it was 360$ inc gst for the bearings, its cheaper in the long run to rebuild the box! just because you know what has been done to it,and your not buying some other dudes heap of crap, i know 1st and 2nd are the first to shit out!
if you buy another box make sure its mint, or you will be in the same boat your in now!
try jack the car up check that nothing is loose,check all the rubber bush's in the leaf springs are still ok,
turn the wheels and see how they feel, and see if there any noise comming from them! ke70s are pretty simple car so souldnt be to hard to find what is the prob
lol yeah that to! and thats why im a car painter!
yeah id get some 2000 grit sand paper wet or dry. use water and and lightly sand the over spray off then get a good cutting conpound and hand buff it up! this works better with a small buffer but your hand will do fine,just takes longer! press hard and fast when doing it by hand!
never ever use 2pac thinners on any plastic trims etc, it will melt your lights, 1k thenners can melt them to so just watch it!
as for windows use a shape razer blade, dont use anything else, keep using shape ones!
hope this helps
i had a b1600 diff that i ran behind my 4age ke35 for a while, just an open spinner. you can get the later model lsd to fit them etc, it was pretty tuff! i sine's upgranded to hilux rear, i welded on 2inch steel blocks to the housing, used the b1600 u bolt and shock plate, and used b1600 shocks. never looked back, hooks up mint and even do track days in it!
i know that ke70s use the same diff housing,head,shocks etc so sould work on a dx!
if you cant aford a hilux, go f series az they have good lsd options and come with disc brakes(ae86) drums(ae85) same stud patten
just cut the mounts off and remake new ones for leaf sping ke70, i think the f series came out in the 80s ceilca and JAP SPEC corona azwel
hope that helps
kool az man thank you for that info! yeah the chank shaft was off an auto engine. had to change the bush spigot to a mannal one when i rebuilt the engine! got that spigot from nissan, even tho it look like an after market one!
im replacing the clutch,and flywheel etc, and throt id better sort the leck at the same time or it wood be a wast for time!
ill have to get the gaskit that seals that plate azwell. ill get a price throw work at nissan and see how a go!
cheers dude!
gearbox oil man! the rear seal was replace when the engine was rebuilt 2 and bit years ago, i smelt the oil and it smells like the shit gearbox oil doz lol. but i will check that in case azwell
hay guys, iv got a rb20det box witch has alot of gear oil in the bell housing!
i noticed that its lecking around the input shaft plate etc!
is there a seal and gaskit that i have to replace there or is more to it than that?
and are they easy to replace,or a bitch to get to?
cheers chris!
iv seen a r32 at pukie drift comp a couple of years ago, its flywheel was lighten and when it let go it went thow the fire wall, dash and bonnet etc! some of the fiywheel landed in the car park lol! that put me off lighting my one for sure!
pretty sure its the rb20det 9 bolt flywheel man! but id have to check it to make sure before a buy one. the motor is a gts4 rb with mods to the rb20det sump to fit the oil pick up, but yeah got to make sure!
the autoclutch been in there for around 4 years now i think, so just old and warn out thats all!
plus got to fix the input shaft seals etc so just going to do the lot at the same time.
yeah man thats another way to look at it ,rember lifting the box in last time by mysef, almost shit mysef lol!
yeah i hear you you man lol ill just keep saving my coins up! iv got an autoclutch in there at the mo its lasted a while i pay a bit for it,but diff had my fun with it!
exedy sounds like the go, guess you get what you pay for
hi guys iv got a a31 that iv been using on and of track for the last 6 years! its an rb20 with the same old same bolt ons etc
the clutch has just started sliping when you dump it etc and feeling very old at the moment.
what im asking is the cheap clutchs that you see on trademe for 400$ for a 5puk any good,or am i wasting my time and money and its best to keep with the well knowing ones for 600$ or so?
i dont have alot of coin so if anybody has or used these cheap clutch's, tell me if you like or not?
any info wood be wicked cheers chris
where abouts are you located, if auckland i can point you in the right way!
paint striper doznt get the bog off (if there is any)so you might have to grind those area's! make sure you sand the paint with 40 grit first so that the paint striper eats in good! best to treat the metal once all the paint bog etc is off! then 2pak etch it!
i restore cars az a job and found if you got bog in the panel that your taking back to bare metal, best to use a 8,10 inch grinder
its faster and less mess, and just lightly grind it so you dont heat up the panel to much!
this is my way and it works for me, but there are loads of other ways to go about it just what ever works for you, hope this helps dude!
yeah i just put the old ones back in, saw a cef on trademe with tinted lights and purpize it had just got a new vtnz wof because it had tinted lights so yeah there it is,learn from other peoples ffff ups!
cheers for the info guys,hope this tread will help others with this type of thing!
the ve commys do its an opitons i think! i know the ae111 levin have pretty dark, but yeah!
i asked the wof man at the garage up from work today interesting,
said that it inpends on the person checking the car for a wof really, he said that as long as you can see them light up in the day time and can be see it souldnt be a problem.
iv found over the years of mucking with cars that certs,wofs, and the cops have different rules for anything to do with mods!
one thing could be sweet for a cert but not for a wof eg stetched tyres. you cant get a cert with them,but a wof you can, and cops can green sticker it for them!
its anybodys guess lol!
mean man i like the concept ay! very tidy!
iv got the 626 coupe of this shape az a work hack,
oh cool man cheers for that dude! sucks you cant tint them, i reckon it looks cool, but oh well back to plane jane!
cheers for the info guys!
haha that wood of been a mess man!
i just bugs me that you cant just make your car look different from the rest with out getting the fuzz all over you!
iv spent alot of money certing the cage,motor,rims,coilovers so so on etc and a little thing like tinting your lights can get you into crap!
im from west auckland az well lol!
cheers guys! yeah iv got a high stop light on the car, i had to put on for a wof many moons ago.
it says that they have to be red when there on or braking etc and to have a red reflecter somewhere on the rear. they light up red and there still bright.
az much az they look kool, but probperly not wroth another green sticker.
its the type of car that is allways get picked out buy the cops,i reckon id be sweet but you get that one cop that can end it all!
PAINT THREAD
in Tech Talk
