NVMPAJ
Posts posted by NVMPAJ
Here you go mate , I used a sealer not just ordinary glue
Just feed the relay with a switched 12volt supply. For the sensor I use an old temp gauge sender and removed the guts then glued in the control sender. I don't think it matters too much where you mount it .
Great choice for the fan controller mate , also they hold their setting memory . So no worries when ignition is off
http://imageshack.us/a/img812/7105/7bnt.jpg
Right back again , have trial fitted the driveshaft loop just need to drill some holes in the floor and bolt it up .
Looking great .
Very impressed with your work
Another test , power steering pump is abit noisey. Same with fuel pump. Idle is good ,as is oil pressure , water temp to (found dash and triple gauge water temp earth wasn't the best all good now tho.)
Power steering .....I hope Ive fixed , will do another loud road test tomorrow. I found jacking the car off the wheels and turning the steering from lock to lock ,then shutting down , caused a nice big bubble of air to escape from the reservoir .
Still to do:
Exhaust
Driveshaft loop
Oil leak from remote filter set-up
Move fuel pump (too loud where it is)
Stereo
Cert and WOF
Well a double blonde moment yesterday , I did actually film a brief drive of the first test drive
Well finally drove the Pajero today , down the drive way and back , she changed gear .......woohoo . Few issues the fuel pump is pretty loud so may look at mounting this in the tank . Worst issue is the power steering hose blew off , need to get a one piece pipe instead of two joined together! ( very unprofessional ) but it moves and drives , and I've got a garage again.
351 is 5.8 litre carjam says its 4740cc which equates to 289. Probably carjam is wrong . http://www.fordification.com/tech/engineID-V8.htm heres some info that might help . But I wouldn't worry what V8 it is , it'l be a great car all the same
Got the oilpump primed again after getting the oil cooler all plumbed up. Ran her for awhile , wouldn't start first off , bloody hose came off the fuel pump , now I'm low on gas!
Derale 15746 is it I'm hoping I've ordered the right thread . Great work by the way .
http://imageshack.us/a/img827/8971/z3mr.jpg I've just ordered one of these that you may be interested in , it allows the hoses to mount a bit closer to the block so avoiding the chassis . $47 on Amazon or $70 odd from edge here in NZ
http://www.amazon.com/Derale-15746-Engine-Spin-On-Adapter/dp/B004XONTWK
This will keep the oil lines away from the chassis , just hope Amazon hurry up
Got my oil lines off eBay and installed need to get elbows for the adaptor so the pipes don't foul the chassis
The beautiful sound of the 1UZ .......can't beat good work mate
What sort of money are they after for the celica or starion ya reckon?
Uploaded with ImageShack.com
Think I've got this image shack thing going
http://imageshack.com/i/5h3z1ij
Hopefully this works
Wired in my fan controller , set it to 80 degrees for now . Found that the tachometer works on 4 cylinder with the sensor wired to the negative of one of the two igniters . Then out of the blue the bloody alarm wouldn't reset , found all the wiring under the dash Jesus those alarm installers are rough buggers . Then all of a sudden she worked again , nothing worse than an intermittent fault!
Sorry photobucket is being stupid
The kickdown cable could be a bit longer , and the throttle cable needs a more permanent install , will do for now though . Am very close to driving the old girl , have a difficult bell housing bolt to tighten up , and a slight adjustment on the engine mounts. Off course there's the exhaust and drive shaft loop , but I just want to drive the thing !!!
Will do , that won't be to far off either!
By the way have you wired your tachometer using the wire on the igniter mine goes full scale , with just the ignition on so not sure if I've done it right or maybe its the cheap repco Autogauge I got
The warning light is easy to find . The other two are either straight to the battery or ignition .
Shakotom's 1985 Toyota HiLux
in Project Discussion
1UZ in Hilux , even tho its common as mud to do , its a proven swap.
