Posts posted by Benno
8 hours ago, yetchh said:
Is the factory colour peppermint green?
Nah, factory colour seems to be beige. Will be painting it Oxford Blue eventually
A guy on facebook was giving away some motors and parts, after finishing his project. Drove over to Greymouth to collect them. Now got 4 parts motors, so should hopefully have enough good bits when it comes to building a motor for it.
Finished stripping the engine bay, removed suspension and cross member. I have made a start removing the underseal from the guards, only been finding some light surface rust so far. Will continue removing the undereseal and make a start bare metalling the engine bay next.
17
I got mine from herbos for around $130. I'm really happy with it, is working great for me.
https://www.herbosequipment.co.nz/products/argon-twin-gauge-regulator
Been making some slow progress on this. Go the guards and front valance off and engine bay nearly stripped now. Just got to take the steering box and column out now. No nasty surprises so far which is nice.
In more exciting news, I've got my hands on some triple carbs for it. Not sure what the condition of the SU's is like, but externally they look all good.
17
Starting to chip away at the paint on this. Bare metalled both sides of the bonnet, treated with some phosphoric acid then painted with epoxy primer. Didn't take any photos once I'd finished bare metalling, below is after the paint stripper starting on the bits close to seams and cavities.
Got the first side done, will flip it over once the paint has dried and do the other side. Few wee runs, but generally happy enough with how it has come out.
13
1 hour ago, Bling said:
Can you prep and seam seal the areas you'll be working on? Capillary action between layers means shit will get drawn in further than you'll ever be able to clean out. Might be able to get seam sealer that is solvent resistance and so would stand up to the rest of your work. You'd still need to be super careful around the seams though.
I'm starting off with prepping and painting the bonnet. It's easy to get to and will hopefully be easy enough to spot if there is any returning rust. I'm planning on carefully taping off the seam at the front giving myself around 20mm to the seam.
Is seam sealer paint stripper resistant? I have some turgostrip from RJP, it's pretty powerful stuff.
How careful do I need to be with paint stripper and seams? I am planning on paint stripping (clean off with water), treating with phosphoric acid (wash off with water), rubbing back with scotch-brite/prepsol then painting with 2K epoxy primer. I was reading some threads online that recommended maintaining min 20mm from any seams to stop the stripper tracking.
Provided I wash the stripper off carefully with water, is this something I need to be concerned with? How about with the phosphoric acid, do I need to do similar with this?
On 22/09/2019 at 13:42, Yowzer said:
Can't remember the date but yup, if they weren't fitted from factory they don't need them.
If however the car is being re-registered, you'll need to fit them.
So if a car did not have rear seat belts from factory but is de-registered, it would require rear seat belts to be installed for re-vin?
Got the dash all finished off, pretty happy with how it looks now. Got a colour matched rattle can and a can of matte clear. Looks fairly close to the original.
Found someone on facebook who had adapted a factory manifold to suit a weber 32/36 carb, similar to a geddes speed one.
I think I'll give it a crack, I've got a couple of spare manifolds so doesn't really matter if I screw one up. Plan is to cut off the raised mount, make a new carb flange out of 10-12mm Al plate, get that welded on then have a go at matching with a die grinder.
10
Stil haven't got much major progress on this, ticking away on the little things.
I've been slowly working on cleaning and polishing the trims by hand with some autosol, most of them are coming up nicely.
The original dash had been hacked up to take a head unit. The car came with a replacement, but it had some rust. Cleaned that up, painted with some Brunox and got a colour match can and some matte clear. Also made a new tray, will cover with some vinyl.
Came with a set of extractors that had a couple of rust holes. Welded up the holes, cleaned off the surface rust and painted with some hi-temp paint. Doubt it will last long, but will hopefully keep the surface rust at bay until I get the car up and running.
14
1 minute ago, kyteler said:
Just make a manifold with 6 branches to siamese at the port?
Could be an option. Otherwise I have a twin choke Weber off the escort I could probably make a manifold up for
7 minutes ago, kyteler said:
6 FCR 41mm Keihins?
Three, it shares inlet ports between 1/2, 3/4, 5/6 but something like that could be the go if I decide to keep the zephyr six motor.
1 hour ago, yetchh said:
Are you gonna twin crab it?
Keeping a casual eye out for a twin carb manifold, something might crop up. I'm yet to decide if I'm going to stick with the original motor or do a barra swap, so not too keen on sinking big money into bits for this motor yet. Will see how it runs once I get it on the road.
Just been doing little things on this. So far I've rebuild the starter motor, windscreen wiper motor and a carb with the best bits from several.
Found a wee bit of rust on the guard, fixed that.
Fixed the transmission tunnel, someone had cut it out for a floor shifter with what seemed to be an axe
16
I got one of these https://www.herbosequipment.co.nz/collections/welding-supplies/products/160a-inverter-mig-tig-arc-welder
Comes with a 10A plug so no dramas with needing a 15A outlet. Really happy with it so far, even a shitty welder like myself can lay some alright beads with it.
5 minutes ago, tortron said:
Bolt through the B pillar.is pretty standard on old stuff
So no dramas with revin even if not factory? Fairly confident that a bolt like that isn't factory.
The motor that came with it had been pulled apart, most key bits were there but was missing a piston. The brother of the guy who sold it had a mk2 motor that was running when removed from a car 15 years ago. I picked that up at the weekend. Turns over, seems to have compression. Even if it's a dud it should have all the bits I need.
A previous owner has poorly installed bucket seats and aftermarket seatbelts. The seatbelts have been bolted through the B pillar.
I am sure this will be a problem with the revin. How are the seatbelts supposed to work? Do they anchor from the B pillar from factory? My workshop manual has the following, but most of the pictures I have found online seem to have a mounting point on the B pillar.
Found myself a new project.
Car was last on the road in 1993, then the registration went dead but the rego is still in the system. Previous owner bought the car around '98 with plans of putting a 302 into it. A few years later he took the car to a panelbeater to get some rust fixed and bodywork done. The bill came back a lot more then expected so the car got mothballed to a hay shed. A mk4 zodiac came up a few years later that had already had a certified V8 conversion so he snapped that up and the mk3 stayed in the shed.
The car only had minor rust (guards, doors, boot etc) to begin with, there was no damage to the chassis or sills. A bit of minor rust has come back since then, but a sweet barn find.
The car was in Methven and had a heap of spares with it. It was pretty heavy towing back.
It came with the engine pulled apart and a heap of heads, manifolds and bits. The guy that sold it to me knows someone with a mk2 motor that ran when pulled out, so I will snap that up.
Long term plans for it once revinned will be some slam, wide steels and eventually an engine swap to a V8 or a barra.
Am I best to get a repair certifier to come and look at it so I can get the rust signed off before I strip it back and paint? I'm thinking that might be easier while everything is pulled apart rather than taking through revin in primer, then pulling everything back apart to paint. Any ideas on how hard this would be and cost?
Discuss here:
30
Discuss here.
Been pretty useless updating this. Scrapped the front lip, decided it didn't really suit the car.
Since my last update, I've done a few things. I've fitted a set of DHLA 40 sidedrafts and a new rocker cover. The sound of the side drafts is amazing and throttle response is much better.
Got a new rocker cover. Purchased from jrcast.com, took a couple of months to arrive but worth the wait. Stoked with the quality and finish.
I 3D printed a FORD badge to attach to my oval style front grille. Really happy with the result, can only tell it's not real when looking clsoely at it.
Got a new project coming soon, will put a thread up when I get the car.
14
Yeah, I'm planning on making an appearance
What software did you use? I used to use eagle before it was sold to autodesk. Haven't tried it lately, dunno what the free license is like now
Diode probably not really necessary, there to protect against any back EMF from the automotive circuits. Battery should basically act as a massive sink and absorb any spikes from large motors such as the starter but I already have a few 1N4007 diodes lying around which should do the trick.
I'm generally not stressing about protection etc, if the rev limiter fucks out then I won't be any worse off then I am currently. I'm not planning on revving to hit limiter every time I drive it or anything.
Ben's mk3 zephyr discussion
in Project Discussion
Yeah, the otira gorge was a bit slow but made it all good. Stoked with all the bits, thanks!
