Posts posted by bigmatt4
stoked with this score 1300 column chang bench seat i can smell the summer cruising in this already
//oldschool.co.nz/index.php?/topic/50549-bigmatt4-new-mk-2-cortina-project/
So ive grown up a bit have a family and now need a 4 door family cruiser and have been hunting for a good one of these for a while. sadly means my mk1 is officially for sale but worth it i think Well i found it a very original 81000 mls mk2 cortina been parked in a shed for 20 years or so. 100% all there and tidy doors still close like it was new went over the car well and couldnt find any rust apart from a few surface dots pick it up hopefully on sunday
//oldschool.co.nz/index.php?/topic/50550-bigmatt4-new-mk-2-cortina-project/
- 7
Has anyone run one of those lock rite diff lockers on the road do they unlock unpredictably as in feathering while sideways
Try cortina auto one they are straight and longer than the escort one
Who would be the best person for dyno tuning carbs in chch palmside dont want to know lots do efi but no one lists carbs
toyota r154 pretty strong box
r100 rx2 rx3 rx4 basic schematic wiring diagrams not sure if anyone has found this site before but looks handy
gearbox looks rx somthing by starter and clutch location
imo leave the carb free up the exhaust give a little timing and good tune up standard 1300s dont need a bigger carb unless you cam them with a gt cam or somthing and with different carb from a different engine family i doubt it will run very nice without re jetting lots of time requred for little reward .
Exhaust no bigger than 1 7/8 will do nice for a hot little 1300/1600 in the future 2 inch i find are to droney.
why waste time and money for somthing you may not use again if you upgrade the engine anyway easyer to find an 32/36 weber carb that will bolt onto a factory manifold that will fit factory linkages.
yes but they are spring loaded so the tab just sits on one flat of the opposing triangles and will self return like most tps and they can be flipped over for so can use clockwise or anti clockwise
looking at a hiace on tard for work can anyone run there eyes over it for me see if its worth me flying down to look at it cheers in advance
matt
http://www.trademe.co.nz/Browse/Listing.aspx?id=854948361
voltage drop in the start wire ? sure they run down beside the battery cable check voltage to that wire under crank should be no less than 9 volts if so fit relay to that wire
044s are an awesome pump but noisy as shit especially hot. intank pumps are they way to go way quieter and cheeper unless you are chasing power 350kw plus
ahh maybe it got the same issue that SRs get do they have hydraulic lifters? the old SRs used to do that you would thrash them round then park them up and all the oil drains out of the lifters.
Go to start next morning no compression. Hold foot flat to the floor and crank over till it catches one cyl at a time and away they would go.
Usually if they were over due for a service
put a testlight on the neg side of the coil and crank the engine and does it flash?
yes---- check condensor or coil
No----- make sure the points arent shorted to ground.
check for an earth wire on the distributor plate should be one so it isnt earthing through the vacume advance slider thingees.
also have found if you dont clean brand new points with thinners or the like then they burn up as the have a preservative oil on them to stop rust
bigmatt4 new mk 2 cortina project
in Project Discussion
Yea like the patina look wil fit my 1600 in it with side drafts keep it looking old no shiny bits lower it with a set of wide steelies keep the bench seat but maybe change to floor change box will hopefully pick it up on sunday
