Posts posted by bigmatt4
All good thanks it actually drives real well don't chirp the tyres under normal driving just clicks while turning into roads .
Are lock rite ratchet type diff lockers road legal they run open until under load then they lock
booked my van at the end of the month for certs do i have to have a wheel alignment sheet?
I do my own alignments with stringlines and camber gauges and never had an issue with tyre wear or handling issues.
wickymyster was his trademe name does that ring a bell or somthing of the sorts
Exhaust would be where I would start looking u clamp loose or something.
Also after you car has done the 3 month minimum you don't have to back pay your rego even if you have put your reg on hold for 12 months and put it back on the road after 4 months
Ltsa send me a letter in the post when my resto reg comes up got both my cars come up at the same time easy online less than 5 mins just need yr drivers license number
Ok Rad! How difficult are they to wire yup?
Quite easy best thing about them is they will control your whole car programable relay and fuse box run one heavy batt cable to it and then run power feeds out. cooling fans fuel pumps water pumps ect no extra relays or fuses required. fitted the last one to Curran brothers racing 26b quad turbo rx2 and it runs everything nitros line lock trans brake 3 cooling pumps 4 o2 sensors 2 step ect and can be all controlled so this will only work when this does that sort of thing so the ecu only needs to control spark and fuel everything is can bus back to the ecu temperatures and so on
Racepack smartwire are the shizz wired in 3 of them now data logging full canbus just keep adding sensors
Specialty cars in matamata Dave green
Shed skid has to be done on the completion of a car as a sign of respect for the mighty shed haha
sooo i had a couple and needed to test something for end of year workshop duties arm was twisted a little perhaps as well
Gluing in 4mm thick lexan windows in the rear all my rubbers were stuffed cost me around half the price of rubbers and glass
Bias pedal box is defiantly worth the effort for engine bay space
Bias pedal box is defiantly worth the effort for engine bay space my brakes work really well without a booster
It drives really nice apart from the diff whine very low geared 4.7 screams its head off but it loves it.
almost got the tune sorted just trying to iron out a rich cruse and slight hesitation off idle but runs great. Suprisingly those lockrite diff lockers are quite streetable does u turns tight corners with no scuffing few clicks but locks well when wanted.
My experience in running in a new engine is make sure it's warm and then give it a hard time without too many rpms don't let it idle for to long find a big hill and drive it hard but watch temp
dosnt even look like the back seat has been sat in what a score
So the deal is 3 owner car first owner from 1970 1973 mileage 25000 mls 2nd owner from 1973 to 1994 mileage 81000mls 3rd owner from 1994 to 2015 mileage 81600 has been parked since they bought it about 22 years in a dry shed. it has a few little bumps and scapes but overall very tidy and original.
So got it home and washed it drained all the rank as rotten fuel out (that shit smells bad) cleaned out the fuel lines replace perished fuel line. Added water in the top which in turn all fell out the bottom radiator is rotten as well. but anyway fitted 2nd hand dissy and coil that i knew were good as it had no spark cranked for a bit and away she went sounded like a tight little engine under all the exhaust noise that is also rotten.
but progress.
So the bad thing are the shocks are stuffed the bushes have all perished and the brakes are siezed but as ive been collecting ford parts for a long time i have most of the bits requred to fix it so all in all i think i have a real sound project.
And what i found was all this golden oily treasure fully rust proofed from head to toe even the original carpet hasnt even worn through yet fully undersealed have been fairy well over it and not found 1 spot of rust and only i little respray touchup on the front left guard all the rest is ridgy didgy
Will be a bit sad to see mk1 go but it hardly ever got driven and need a change can't keep every car I've built un fortunately but this one was too good to pass up
Smitty's Toyota Corolla Ke70 Wagon - Discussion
in Project Discussion
Was the steering locked or unlocked
